Old March 27th, 2011, 05:16 PM   #1
Cloud Strife
Hot Wheels
Motorcycle(s): 2010 Kawi Ninja 250R
Exclamation Having some troubleshooting issues...
Hello all! Been snooping the boards and must tip my hat the the extremely knowledgeable personnel here. Now I need some personal guidance...
I went away last fall for a few weeks and when I got back, it was winter. I didn't do any winterizing and now I am obviously paying the price. After pullin it out a couple weeks ago, she wouldn't turn. I charged the battery which fixed that. It would then turn, but wouldn't catch. Swapping the spark plugs solved that problem.
Then, I was able to have her idling with the choke on, but would die if I turned it off. I took out the old gas and filled it up with premium and added some SeaFoam. Then I was able to get it idling with the choke off, although somewhat choppy.
Then I was faced with the problem of the engine dying the moment I opened the throttle. I though that maybe the fuel lines may have been kinked or something so I pulled off the tank and checked the lines to make sure they weren't kinked or depressed by anything. I put the tank back on and now it won't even start.
I know what my next step will likely be but I wanted some more experienced assistance before pullingthe carbs and cleaning them. Does this sound like the problem or could it be something else?
It's a 2010 250 and has 600 miles on it.
I appreciate the feedback!
Cloud Strife is offline   Reply With Quote
Old March 27th, 2011, 05:24 PM   #2
Chad,
Sorry to say, but it does sound like you'll need to pull the carbs to clean them at at this point.
have you seen this thread?
http://www.ninjette.org/forums/showthread.php?t=65198
may I also suggest if do end up pulling the carbs out that you remove the plug caps on the mixture screws and shim the needles while you're in there?
Old March 27th, 2011, 05:25 PM   #3
If the bike was a-ok when put away, but is having starting and running issues months later, dollars to donuts it's carb-related. Step-by-step details on what to do next from kkim's thread here. Good luck!
edit: I clearly didn't hit post quite quick enough.
Old March 27th, 2011, 05:27 PM   #4
clearly...
Old March 27th, 2011, 05:28 PM   #5
Cloud Strife
Hot Wheels
Chad,
That's actually the thread that made me decide to join the forum. Great stuff in there! The DIY help is seriously priceless.
I probably will do that while I have the carbs out. I might as well take care of everything that I can so I don't have to rip them out again. Simply a mistake that I won't make again but at the very least, I've learned a great deal about motorcycles in the last two weeks which I wouldn't have learned otherwise.
Old March 27th, 2011, 05:32 PM   #6
the shimming and removing the plug caps are so much easier when the carbs are removed. I highly recommend you buy some JIS screwdrivers if you are going to be doing carb work.
you have a PM.
Old March 27th, 2011, 05:37 PM   #7
Cloud Strife
Hot Wheels
you have a PM.
And those can be purchased at most tool / hardware stores, I assume?
I was going to pull the carbs and clean them once I took the tank off but when I saw the airbox assembly, I totally chickened out...
Old March 27th, 2011, 05:45 PM   #8
most likely not. here's a source if you can't.
http://www.ninjette.org/forums/showthread.php?t=49003
do your homework before tearing into the bike. there are threads around which show how to pull the carbs out when you still have the airbox.
http://www.kawiforums.com/ninja-250r...ll-re-jet.html
Old March 27th, 2011, 05:51 PM   #9
Cloud Strife
Hot Wheels
Yeah, I saw that thread but it wasn't until after I put the tank back on. All good though; I now know where to go once I get to that step. I'm not about to dive into something that I'm not comfortable with so I've read the info a few times over and now have another source for information thanks to you.
Old March 28th, 2011, 01:51 PM   #10
Cloud Strife
Hot Wheels
Ok so I've made it up to the point where I'm supposed to pull the air box back so as the allow the carb room to be pulled out. I double checked to make sure that I unscrewed everything but the air box doesn't seem to want to move back at all. It wiggles, but not enough to clear the carbs. How much is it supposed to be able to move?? Seems like there's no where for it to go...
Halp! Lol
Old March 28th, 2011, 02:06 PM   #11
did you get the one in the lower right hand in this pic?
did you remove the battery case?
Old March 28th, 2011, 02:09 PM   #12
Cloud Strife
Hot Wheels
Yep, got that one and the battery case is gone as well. I have it wiggled back about a quarter inch...I could probably force the thing out if I had to but it'd be impossible to wedge back in. I'm just checking again to see if it's hung up on something.
Old March 28th, 2011, 02:33 PM   #13
Cloud Strife
Hot Wheels
Managed to get the carbs out w a little strength. Time for a cleaning
Old March 28th, 2011, 02:39 PM   #14
if things were a bit tight getting them out, it will be a chore getting them back in. A trick that works for me is to lube the rubber pieces with a light coat of rubber protectant like Armorall when reassembling any rubber pieces. It makes installation a breeze and parts simply slide into place.
remember to blow/clean out the passages that the jets screw into as well as cleaning out the jets themselves.
be very careful with the diaphragms when shimming the needles. they are delicate and expensive.
Old March 28th, 2011, 03:12 PM   #15
headshrink
headshrink's Avatar
This make ALL the difference! Think of it like lubing a tire when you install it on the rim.... you sure wouldn't get it on there without lube.
Old March 28th, 2011, 03:36 PM   #16
Cloud Strife
Hot Wheels
Update: Opened up the carbs and checked the jets. They were clean. One was arguably a little dirty so I sprayed sone cleaner into it then rinsed it off. I still have to blow out the passages that the jets screw into before I put it all back together. Also, I shimmed the needles with two washers each and was very careful not to damage the diaphragms.
Anything else you recommend me doing so that I have all my carb-related bases covered?
Old March 28th, 2011, 04:11 PM   #17
did you remove the cap plugs over the mixture screws? if not, do that, too. it will ease carb tuning in the future if you can access them.
Old March 28th, 2011, 04:35 PM   #18
Cloud Strife
Hot Wheels
Yes, I did indeed do that as per your suggestion! I don't have access to compressed air; is there another means by which to clean out the lines within the carbs (ie manual blow) or is that really the only way to clean them?
Old March 28th, 2011, 04:39 PM   #19
many use carb cleaner in an aerosol can and stick the red plastic tube to direct the cleaner through those passages. That will work, but watch out for the carb cleaner... it's nasty stuff and you don't want that flying all over the place. A rag over the carb when you use that would be a good idea.
Old March 28th, 2011, 04:52 PM   #20
Cloud Strife
Hot Wheels
Perfect. Will the carb cleaner itself damage the fuel lines (the rubber ones leading to the carb)? I know it can do a number on the diaphragm so should the lines be removed prior to sending carb cleaner through the unit?
Old March 28th, 2011, 04:57 PM   #21
I can't say... I don't use that stuff on my carbs, but just test it out on a small portion of tubing and see if it deforms/eats it. I would think it would be relatively safe if you work fast and don't leave it soaking on the rubber parts for very long.
just to be clear... this kinda stuff or something similar is what I'm talking about...
Old March 28th, 2011, 05:20 PM   #22
Cloud Strife
Hot Wheels
Yep, that's the kind of stuff I have. Came with a nifty red tube for spraying. Should I rinse the units out afterwards before putting them back together?
Old March 28th, 2011, 05:33 PM   #23
if everything is relatively clean after you spray, wiping it down with a clean cloth should suffice.
with carb work, the cleaner you are with your work, the less chance of something getting stuck in one of those little holes you just cleaned out. cleanliness is essential.
clean out you jets with the carb cleaner too, while you're at it.
Old March 28th, 2011, 05:42 PM   #24
Cloud Strife
Hot Wheels
Thanks Kelly! I'll get to all that tomorrow morning and will post updates
Old March 28th, 2011, 05:45 PM   #25
looking forward to good news.
gl...
Old March 29th, 2011, 06:56 AM   #26
cwb48
Mature motorcyclist
cwb48's Avatar
Motorcycle(s): 2008 Ninja 250R, blue
Chad;
No one else seems to have mentioned this, but make sure that you have removed and cleaned the pilot jets as well as the main jets while you have the carbs apart. They are easy to miss, as they are in a well at the top of the float bowls, and must be removed with a small straight blade screwdriver to be cleaned properly. Clean them until you can see daylight clearly through the tiny hole that is the actual jet. Check Kelly's other posts linked above for photos.
Chris
cwb48 is offline   Reply With Quote
Old March 29th, 2011, 09:55 AM   #27
Cloud Strife
Hot Wheels
Update: cleaned out the carbs an the interior components. Carba finally back in and hooked back up. Just about to put the tank back on. Fingers crossed...
Old March 29th, 2011, 10:13 AM   #28
randomwalk101
self wrencher
randomwalk101's Avatar
good luck. after the bike is running good, make sure you synch the carb too.
Old March 29th, 2011, 10:14 AM   #29
Cloud Strife
Hot Wheels
Alright, so I got the tank back on and hooked up the battery. Turned the petcock to prime and let 'er rip...
It's turning over very readily and it wants to start but She's showing no signs of catching. This is reminiscent of earlier in the process when I had to replace the spark plugs in order to make that happen.
EDIT: Success! Adjusting the idle speed nozzle seemed to do the trick!!
Old March 29th, 2011, 11:48 AM   #30
CZroe
CZroe's Avatar
Awesome. No reason to suspect foul play from Shinra or Sephiroth.
Old March 29th, 2011, 12:01 PM   #31
headshrink
headshrink's Avatar
Cool, glad you got it. Idle speed nozzle?.... you are talking about the black thumbscrew idle adjustment you can reach with your fairing on.... I assume.
Old March 29th, 2011, 12:02 PM   #32
Cloud Strife
Hot Wheels
Haha well you never know...they might be responsible for the carbs being plugged up anyway!
On a side note, and I assume this is a result of the shimming, she sounded SO much better when I was revving her. Lots more throttle response right off the bat : )
Old March 29th, 2011, 12:05 PM   #33
Cloud Strife
Hot Wheels
Yeah, that's the one. giving it a bit of a twist allowed her to get running. I then had to readjust after it started warming up to keep it in the proper range.
Old March 29th, 2011, 12:10 PM   #34
http://www.ninjette.org/forums/showp...55&postcount=5
congrats!
Old March 29th, 2011, 12:53 PM   #35
Cloud Strife
Hot Wheels
Now it's time to actually put my work through the paces
Just ordered some Protons and an integrated tail light to spruce things up. Any good sources for solo seat cowls? The cheapest one I am able to find is $99.99 + shipping.
Old March 29th, 2011, 12:56 PM   #36
go ride the damned thing and have some fun with it before sinking money into it.
Old March 29th, 2011, 01:00 PM   #37
Cloud Strife
Hot Wheels
Haha touche, but it'll be a few weeks before any packages arrive for me anyway!
Away I go : D Thanks for your help!
Old March 29th, 2011, 03:59 PM   #38
Cloud Strife
Hot Wheels
So, took her for a nice rip and am reporting back. Overall I'm thrilled to have her back on the road and zipping about. My only concern with anything is some hesitation below 4000 rpm. I can take her off the line quick without a problem but if I want a slow start (ie like when I'm stuck in traffic) then there seems to be some choppiness up to about 4000 rpm.
Oh, and it's still a bit cold
Old March 29th, 2011, 04:08 PM   #39
sounds like it's running better... is it?
bring me back up to date. any mods to the intake or exhaust other than the 2 shims added to the needles? the shims should have made the lower rpms a lot smoother/fatter than they had been.
did you have any riding time on the bike to find out what the low rpms were like prior to you having your recent problem?
Old March 29th, 2011, 04:45 PM   #40
Cloud Strife
Hot Wheels
Oh it's definitely running better than it was since before this carb cleaning I couldn't get it moving! No mods done besides the needle shims.
When I rode the bike last year, I didn't really have any problems with hesitation in the low RPM range. Seemed to pick up as fast as I would ease off the clutch and open the throttle. At least I never noticed any hesitation. I didnt have much power in this range last year in terms of being able to accelerate quick off the line so it seems to be better in that regard now however she seems to be struggling, even 'putting'' at times with slow acceleration from the low range...strange.
Troubleshooting my Ninja zenmike 2008 - 2012 Ninja 250R Tech Talk 7 December 6th, 2014 07:26 PM
Troubleshooting Battery/Alternator Help bkh2 2008 - 2012 Ninja 250R Tech Talk 2 February 20th, 2012 11:45 AM
Return to idle RPM troubleshooting Momaru 2008 - 2012 Ninja 250R Tech Talk 11 June 12th, 2011 05:35 PM
Troubleshooting '08+ CDI with '88-94 Service Manual g21-30 2008 - 2012 Ninja 250R Tech Talk 3 November 11th, 2009 03:06 PM
Troubleshooting Help (External Link) g21-30 2008 - 2012 Ninja 250R Tech Talk 3 September 20th, 2009 02:47 PM
