June 14th, 2011, 12:46 AM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2009 Ninja 250R Posts: 5
Need Help! Dropped juice straw inside clutch cover
Hello,
I am new to this forum and need your help guys. I was siphoning some oil via the clutch cover using a syringe and a juice straw when suddenly the straw came off the tip of the syringe and dropped inside the cover. I've pretty much used all kinds of tools to fish it out but to no avail. It was very deep inside the cover. Will this cause severe problems if I run the engine? I really don't want to dismantle the clutch cover. Thank you and looking forward to your responses. |
June 14th, 2011, 12:54 AM | #2 |
take the clutch cover off to retrieve the straw.
June 14th, 2011, 01:02 AM | #3 |
I see so I guess i am taking that route. Should I drain the oil first before removing the cover? Sorry for the noob questions, just trying to be DIY'er here.
June 14th, 2011, 01:08 AM | #4 |
June 14th, 2011, 07:34 AM | #5 |
ModMy250.com
Why were you siphoning oil from the bike?
The www.ModMy250.com guy |
June 14th, 2011, 08:15 AM | #6 |
Obv he was thirsty and his MOM told him to use a straw/syringe
Lol overfilled oil I guess Posted via Mobile Device |
June 14th, 2011, 09:18 AM | #7 |
Yup. Overfilled it with oil. Did not really want to drain it because I don't have a torque wrench.
June 14th, 2011, 09:20 AM | #8 |
Will most likely need a new clutch cover gasket.
June 14th, 2011, 12:11 PM | #9 |
Personally, If I overfilled it with oil and the oil wasnt hot, I'd use the drain bolt, slowly loosen it and use a finger to plug the hole, once you drain enough just quickly switch your finger for the bolt and add oil if you drained too much. Might be messy but it works.
June 14th, 2011, 05:50 PM | #10 |
So, where's the reverse?
I hate having a juice box at lunch with no straw.
June 14th, 2011, 06:08 PM | #11 |
Alternatively, you could pull the oil drain filter and see if you can get to it that way. It'll force you to drain the oil, but might save you having to go in via the clutch cover.
By "Oil drain filter" I don't mean the oil filter itself, but a filter that protects the drain, where stuff collects at the bottom of the engine. The red-circled parts in attached diagram are the oil pre-filter, its gasket and the section of the crankcase that holds it on. The bolt at the bottom of the red circle is the oil drain plug, to give you a better idea of where this thing is. This isn't a sure bet though; the straw may not be reachable/visible from there, but it does open to a good portion of the aft crankcase, so there's a fair chance it'll be right there once you drain the oil. The catch is, this has a gasket too, but I haven't had to replace it the two times I've gotten this piece off. Here's a pic of the filter itself, after I pulled it looking for something in my engine in March last year and found more than I'd expected. The gasket is in the background.
June 14th, 2011, 07:27 PM | #12 | |
June 14th, 2011, 11:03 PM | #13 |
Took my chances this morning and drove the bike to work since I only live less than a mile from the office. Warmed up the bike for 5 mins and did not notice or heard anything unusual from it so I drove away. When I got home later in the afternoon, I thought maybe I should check the clutch cover. So I opened it, and there was the straw right in the open! So I took a tweezer and plucked it right out. The straw was not damaged at all so I guess and I am hoping that everything will be alright with the bike. Lesson learned indeed... Thank you guys for the responses. This forum is a boatload of information.
June 14th, 2011, 11:58 PM | #14 | |
June 15th, 2011, 12:03 AM | #15 |
Yes, very risky move... you should plan a trip to Vegas soon, as you're also very lucky.
Had the straw got ground up into bits, it would/could have been circulated through the engine and possibly have clogged oil passages. If that had happened, you would be looking at a toasted engine due to oil starvation. glad things worked out for you. |
June 15th, 2011, 04:59 AM | #16 |
The "Ninja" god was looking out for you.
June 15th, 2011, 05:05 AM | #17 |
IC2(SW)
WOW.... Lol
June 16th, 2011, 09:45 AM | #18 |
Former ninjette rider
Join Date: May 2010 Motorcycle(s): 2011 Honda CB1000R Posts: 121
We've witnessed your human capacity for war. It would absolutely bring more harm than good. |
June 16th, 2011, 03:20 PM | #19 |
All dark, no juice | planet-beaver | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 21st, 2012 06:00 PM |
i dropped my ninja lastnight..(Pics inside) | venmichaels | !%@*#$%!)@#&!%@ I crashed! | 14 | July 20th, 2011 01:01 PM |
Garbage truck juice | rockNroll | General Motorcycling Discussion | 13 | May 1st, 2011 09:31 PM |
Play in Clutch Basket Normal? *Video Inside | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 2 | April 21st, 2011 04:52 PM |
Dropped bike..need parts. (right handle bar, a crankcase cover, more) | mnevets3769 | !%@*#$%!)@#&!%@ I crashed! | 4 | October 22nd, 2010 07:17 AM |
