Old March 13th, 2011, 09:54 PM   #1
Dat_Ninja_There
Shinobi Rider
Dat_Ninja_There's Avatar
Motorcycle(s): 2010 Passion Red Ninja 250R
Custom iPhone 4 Otterbox mount
So I took the idea from setasai, over on ninjette.org, from his write up on a custom garmin gps mount here
Basically, I wanted to mount my iPhone so I know when someone important calls while I'm riding, like my girl or the office. Unfortunately, all the prefabbed mounts I found only worked with the iphone while it is not in a case. I wanted to be able to use a mount for my iPhone 4 while still in the trusty and durable Otter Box Defender case. So heres what I did....
1. I ordered an extra Otterbox beltclip/holster from ebay.
2. I removed the beltclip from the holster
3. Went to Home Depot for some 1/8" thick, 3/4" wide aluminum strip metal, nuts, bolts & washers
4. Used a metal coat hanger to bend up a stencil for the design of the cross bracket, using the 2 lower bolts of the windscreen in the dash area as my mounting points
5. Bent my aluminum strip at the same angles of my metal hanger stencil.
6. Marked where all the holes needed to be drilled on the aluminum bracket
7. Fabbed up an L-bracket to mount to the cross bracket
8. Mounted the holster to the L-bracket
Extra Otter Box Holster
Beltclip on back that I removed
Otter box holster without iPhone
Otterbox holster with iPhone
I'm gonna take the bracket off and apart tomorrow and spray it with primer and flat black paint so that it blends better with the dash area.
Also, mounted my garage remote with some velcro between the handlebars, lol. Works out great.
Last futzed with by Dat_Ninja_There; March 23rd, 2011 at 07:37 AM.
Dat_Ninja_There is offline   Reply With Quote
Old March 14th, 2011, 05:53 AM   #2
dubojr1
dubojr1's Avatar
Old March 14th, 2011, 02:27 PM   #3
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Looks good
slolane is offline   Reply With Quote
Old March 20th, 2011, 04:33 PM   #4
Dat_Ninja_There
Shinobi Rider
removed the bracket today and painted it and reinstalled it. Looks much better now that its all black
Last futzed with by Dat_Ninja_There; March 23rd, 2011 at 07:30 AM.
Old March 20th, 2011, 05:47 PM   #5
Cazper
ninjaholic
Cazper's Avatar
Thats a great idea... I think it would work better if it didn't block the top half of the spedo... but you are limited with space with the stock windshield. With a double bubble it could be up higher. I may have to rig something up like this for my garmin phone and then supply it power...
Thanks for the pics and the ideas
09' SE Ninja 250R
$2,547.83
Old March 20th, 2011, 08:05 PM   #6
Dat_Ninja_There
Shinobi Rider
Yeah that's my only grievance too. But you're right I was limited on the space. I do hate not being able to see my neutral and turn signal indicators. But I do like being able to use my gps and speedo apps, and knowing when someone important has called, like the office.
Old May 9th, 2011, 08:37 PM   #7
slolane
Motorcyclist
slolane's Avatar
I went ahead and did this tonight...
Mount: bent up some scrap metal, made an L bracket to attach, marked and drilled holes.
Holster: removed belt clip, drilled hole to mount to L bracket, used drill to route out bottom of case so power may be supplied while in holster. I will be adding a velcro strap to clamp it in as extra security as I didn't want to put velcro directly on the back of my case.
I have a Double Bubble windscreen so it is able to sit up above the stock gauges no problem...
Mount:
Phone mounted:
I use MotionX GPS on my iPhone and iPad and it works really well.
Old May 9th, 2011, 08:40 PM   #8
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
Looks good slolane, so next up is the ipad mount, right?
Live2ride is offline   Reply With Quote
Old May 9th, 2011, 08:47 PM   #9
slolane
Motorcyclist
slolane's Avatar
Thanks man.
Heck yeah, I would have to get the touring windscreen (thread here) and then maybe I could fit it... humm.
Old May 9th, 2011, 08:54 PM   #10
Dat_Ninja_There
Shinobi Rider
Yeah I need to get the double bubble, so I can see all my gauges again lol
Old May 11th, 2011, 06:31 AM   #11
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Mount:
Phone mounted:
I use MotionX everyday for work. Logged 1000's of miles on that app and it is fairly accurate most of the time. Any address I'm trying to find on major highways end up saying I arrived 15 miles before I actually get there. Everywhere else, it's spot on. I might have to come up with a similar mount for my iPhone so I can have my navigation up for work days. On days I'm not working, I'm just as happy to not have it and ride a random road to find out where it goes. Reminds me of all the driving I used to do when I was younger and gas was 85¢ a gallon.
geeker is offline   Reply With Quote
RAM iphone 4 mount Snowy 2008 - 2012 Ninja 250R Farkles 15 May 12th, 2015 09:23 PM
iPhone 5 mount erbarry88 General Motorcycling Discussion 12 February 22nd, 2013 05:34 AM
Iphone mount Yhames879 2008 - 2012 Ninja 250R Farkles 7 August 7th, 2012 12:40 PM
My iPhone Mount enko11 2008 - 2012 Ninja 250R Farkles 2 May 9th, 2012 09:04 AM
iPhone 3G, 3Gs OtterBox Defender Cases for $18.50 dubojr1 Miscellaneous 3 October 6th, 2010 07:53 PM
