Old August 27th, 2011, 10:50 PM   #1
Navigator
Motorcycle(s): 2011 Ninja 250R, 1979 Elsinore 125R
Home-made Shift Light is now running!!!
Here's a short video of my shift light in action. You'll notice that the 2 red LEDs at the top of the screen will light up at ~8,000rpm. I can set it to light up anywhere from 4,500rpm ~ 13,000rpm, in 600rpm increments, using DIP switches.
The LEDs are great in the dark but somewhat hard to see in bright sunlight. I need a different type of indicator I think.
Overall it's great to have because it is so much easier to use than the tach. I now focus more on the road ahead because I can see the light from the corner of my eye, no need to shift my focus to the tach while I ride.
BTW this is an analog version of a shift light, there's no microprocessor in there.
Installation is simple only 3 wires to connect. First wire to +12v, 2nd wire to ground, and the 3rd wire is wrapped around (no connection) the sparkplug wire, 5 turns only, to act as a pickup antenna.
Navigator is offline   Reply With Quote
Old August 27th, 2011, 11:44 PM   #2
Good job! Looks like ninja250/KC has some competition!
Old August 28th, 2011, 12:11 AM   #3
TheMojoRider
Motorcycle(s): Ninja!
Dang that is cool! I want one but with brighter/larger light
TheMojoRider is offline   Reply With Quote
Old August 28th, 2011, 02:27 PM   #4
leed
leed's Avatar
Motorcycle(s): Time will tell
Try a more powerful LED, but also a Blue or Violet light. They tend to stick out more. Red is the worst.
Old August 28th, 2011, 02:33 PM   #5
ducducgooseit
Motorcycle(s): ...
And now for additional feature requests - Can you program an array of leds so that as you approach the programmable limit more of the leds light up? Using say 5 leds, the first four blue and the actual limit light as superbright or physically larger red led?
ducducgooseit is offline   Reply With Quote
Old August 28th, 2011, 02:45 PM   #6
Indy250r
Indy250r's Avatar
Motorcycle(s): 2011 KTM 990 ADV
You could try this: http://search.digikey.com/scripts/Dk...AN-CY0C0461-ND
Super bright (~20,000 millicandella) Same current most likely as what you are using now. It will probably be way too bright at night though.
Indy250r is offline   Reply With Quote
Old August 28th, 2011, 03:46 PM   #7
Navigator
Thanks everyone!!! The LEDs are actually much brighter than what can be seen on the video. The camera angle was off to one side and missed the LED light beam entirely. I also increased the current to the LEDs and they are so much brighter now. I'll post another video soon.
I need to make a board for it since what I have is just a rat's nest held with tape to the bike. Testing the concept first before making the final version.
@ Ducducgooseit: This version does not have a program running. The function was implemented using a different concept and would need a lot of additional components to include the functions you requested. But I do agree it would be nice to have!
Old August 28th, 2011, 07:01 PM   #8
Navigator
I need to tidy things up a lot!!!
Amazingly this contraption held fast for >120kms distance travelled.
Old August 28th, 2011, 07:46 PM   #9
trevor_shiggs
trevor_shiggs's Avatar
What the FU*K hahahhaha. Wow.
2010 Ninja 250 Danmoto Carbon Slip On,Factory Pro Jet Kit,K&N R-0990 Air Filter,10000K HID's,Carbon Fiber Shogun No Cut Frame Sliders & Swingarm Spools,SSR Lowering Links and more....
trevor_shiggs is offline   Reply With Quote
Old August 28th, 2011, 08:37 PM   #10
jonnyc
Motorcycle(s): 250
Please tell me you were kidding
Good mod still. Prob will do myself. Thank you.
jonnyc is offline   Reply With Quote
Old August 28th, 2011, 10:15 PM   #11
Navigator
Here's a much better video that shows the light better. Brighter too.
Had to lower the trip point to 5,000rpm so as not to stress the engine so much (no load + high rpm). In actual use I set it at ~11,000rpm for hard break-in.
Old August 28th, 2011, 10:38 PM   #12
Actually, human eyes suck at blue. It's why they switched from blue to red backlighting in version 2 of the Logitech G15 keyboard. Despite the backlighting, you still couldn't read the keys in the dark!
Old August 28th, 2011, 11:48 PM   #13
Navigator
No I'm not, that's how it's wired actually.
Old August 28th, 2011, 11:50 PM   #14
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
green (I think..) is the brightest color your eyes see. Just like in lasers, green is much brighter at the same output as a red or blue
----> My Youtube! <----
Old August 29th, 2011, 09:05 PM   #15
ducducgooseit
Motorcycle(s): ...
I need to tidy things up a lot!!! ...
So, uh, indeed, you did use a different concept than some programming.
Home made stand made from 1" black pipe Motofool General Motorcycling Discussion 11 September 4th, 2014 12:28 PM
home made fun alex.s Off-Topic 1 July 30th, 2013 12:04 PM
Home Made American Exhaust ninja250r81 General Motorcycling Discussion 15 February 22nd, 2013 05:58 PM
Home-made new-gen integrated tail light? Need white/red bulb+socket recommendation. CZroe 2008 - 2012 Ninja 250R Farkles 14 July 24th, 2011 10:33 PM
Home made wind screen Mr Quality 1986 - 2007 Ninja 250R Farkles 5 November 9th, 2009 09:47 AM
