June 16th, 2009, 05:47 PM | #1 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
Rear end feeling squirrelly
Hey can anyone tell me what might lead to the rear end feeling alittle haywire in tight sharp turns.
I was out today and was taking some turns more aggressively than usual and the rear end felt abit hairy and unstable. 145lbs,rear shock on step 2,tires max psi, not much near to the nipples.
June 16th, 2009, 05:53 PM | #2 |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
Road condition? Weather? Tire type/size?
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
June 16th, 2009, 05:55 PM | #3 |
June 16th, 2009, 07:24 PM | #4 |
Various but average conditions/80 degrees clear/Stock dunlops
28Front/32 rear
June 16th, 2009, 07:43 PM | #5 |
have you done any chain slack adjustment or rear wheel alignment recently?
June 16th, 2009, 08:08 PM | #6 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
I hold by my own thoughts... ditch the stocks and replace with "sticky" tires.. I've done 1 set on the 2007 and 1 on the 2009.. always love the sticky and grip with the Pirelli Sport Demons.. tones down the stock IRC or Dunlops skittish response in tight, quick turns.
June 16th, 2009, 08:11 PM | #7 |
Kim.... tell me something. On the 2007 the front end on tight turns always stayed planted and if I slid further to the back of the seat I could really plant the back end and force the turn more without the front diving down a little. I've noticed on the 2009 I have of course little room to slide back and when I do go into a quick tighter turn the front end dives alittle which gives me a little feeling that a highside might come up if I push it any further so I slow down and regroup thru the turn... and personal experience and suggestions? That I think would be considered a "squirrely" front end.
June 16th, 2009, 11:03 PM | #8 | |
in your case, the 2009s came with IRC tires, which are proving to be not so great a sticky tire for the 250. If you are referring to the dunlops on your pregen, they were notoriously crappy tires (different model) and are not to be confused w/ the 501s that came on the 08s. the sport demons seem to be the stickiest of all the bias ply tires available in stock OEM sizes. |
June 16th, 2009, 11:05 PM | #9 | |
June 17th, 2009, 05:01 AM | #10 |
IC2(SW)
June 17th, 2009, 06:16 AM | #11 |
Thanx Kelly thats the method of turnin I do... maybe cranking to much on turnin the front end and not leaning enough... and gotcha on the '08 tire models.... u lucky people!
July 15th, 2009, 02:05 PM | #12 | |
Thanks for the replys guys. I did lower the tires 2 psi and its still alittle funky.
July 15th, 2009, 02:21 PM | #13 |
yes, it could be that your chain is too tight or you are misaligned. how did you align your rear wheel?
July 15th, 2009, 02:25 PM | #14 |
measured the bolts
July 15th, 2009, 02:27 PM | #15 |
...and your chain slack?
July 15th, 2009, 02:32 PM | #16 |
tight. like .5
July 15th, 2009, 02:35 PM | #17 |
that's the problem. You want at least 1" of play midway along the run of the chain. back off the adjusters some to get the proper 1" play and see if that doesn't solve your problem.
July 15th, 2009, 02:39 PM | #18 |
will do. Im due for an lube/adjustment. will post back when complete.
July 15th, 2009, 02:44 PM | #19 |
Giggity Giggity
Join Date: Feb 2009 Motorcycle(s): 08 ninja 250R aka Hiryu Posts: 481
are you entering the turn a little to hot and the front and rear may not have the desired 60/40 balance? Not sure but from what some people are mentioning it could be how much force is on each tire in the turn not the tires themselves?
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods |
July 15th, 2009, 03:12 PM | #20 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
If it were me, I would put the rear back to the first position. Were close in weight and I thought the 2nd position on the rear shock made my bike a little squirrley.
Dont forget to lose some of that air in the tires. Max pressure is way too much.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
July 15th, 2009, 03:35 PM | #21 | |
I havent ruled out technique.
July 15th, 2009, 03:44 PM | #22 |
Join Date: Jul 2009 Motorcycle(s): Working towards one Posts: 27
I honestly have nothing to contribute to this thread, but the word "squirrelly" in the title made me laugh.
July 15th, 2009, 04:26 PM | #23 |
haha. I dont know where I got that from.lol I think I heard it from another member. It was the best way I could describe how its acting. It is silly though.
July 15th, 2009, 07:03 PM | #24 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
Aye... im feeling a slight wobble... but dont notice it in turns, i noticed it as im doing like 5MPH, in bumper to bumper traffic yesterday. I did adjust my chain/rear wheel the other day. Then what you guys are saying Conferms my first thought... my Chain is too tight! I bought some stuff from JC whitney.com last week, and to top off my Order of $99.99 for FREE S&H, i got the Motion-Pro chain alignment tool. Used it, and with the Chain-Adjuster Bolts Threads/Equal thing... i think i got the rear tire and sprockets all set up good... i just set my Chain too tight. After work Thurs. ill be working to Fix this!
July 15th, 2009, 08:50 PM | #25 | |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
do your turn smooth and within your limits and you should be fine. read "twist of the wrist 2" if you really want to get into the physics of where your weight is.
Las Escobas -- Track Bikes Save Lives JonBroom.com |
July 15th, 2009, 09:08 PM | #26 |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
July 16th, 2009, 12:38 PM | #27 |
July 16th, 2009, 05:08 PM | #28 |
Well after looking over the Bikes rear wheel alignment, and chain alignment... they checked out just Fine .(not perfect but close as possible)
Checked the chain slack... OMG tighter then my Sister!!! lol When i did my adjustment days ago, i mustve ****ed up and used the 'Loose' chain slack for the starting point. Anyhow i got the chain slack to 1" -ish, tightened everything down as spec'd,etc! Took Nate for a Test ride around the block afew times, up to 45MPH and down to 5 MPH... all "Noise" and Handling seems, Sounds all normal and such. I will be keeping an Ear/Eye on it this weekend! So my rear wheel had a slight wobble to it, during bumper to bumper 5 MPH traffic, Loud "Noise" from the front sprocket and such. All because of a Tight Chain, that when i did a quick adjustment... 'Eyeballing the slack and such" wasnt a Good measure! lol my tires PSI front:27 rear: 28 my weight: 166 Lbs. So if once you get your rear wheel alignment and chain slack adjusted Right, doesnt solve your Noise* issue or whatever, Then maybe the Output Shaft or a Bearing is going bad instead? Hope this helps! |
July 17th, 2009, 06:37 PM | #29 |
so, Joe... did you readjust the chain?
July 20th, 2009, 09:10 PM | #30 |
Thanks Tim. Glad to be back. Let me know when you'll be back in the area again. Hopefully you guys enjoyed yourselfs at niawanda park. BTW:canal fest is going on this week up until Sunday.Its right around that area. "I'm on a boat" all of Sunday. I Might take a ride up there Sat. I should have my chain squared away by then atleast. I plan to get the enhanced license soon too so I can get over the border again. I'll let ya know Brah.
No Kelly. I had plans to do it Sat. but that fell through cause of work. I had to spend 4hrs Sunday washing just the outside of my car! lol The inside is still filthy. After that I attempted to work on the chain but fought with that stinking A-tech fender for 20 mins trying to figure out how the hell I got it on there without breaking it, then gave up! So the rest of Sundays daylight was spent pampering the XJ with very fine steel wool. I do have alot of things going on at once with my little ninjette at the moment and the chain is No.1 on the list. I'm also still having problems with the front end at 35-40mph which is becoming more noticible at higher speeds. I retorqued with no different result. I think the bearings were pressed wrong and might just have to take it in. I just want the bike to ride smooth and it doesnt. I believe its supposed to be raining mid week and I will attack the chain then. Will post results ASAP. BTW: I caught ur discussion with Alex months back about chain alignment.lol. Do you think measuring the bolts is good enough?
July 20th, 2009, 10:38 PM | #31 | |
for now, though... use the bolt method. |
July 22nd, 2009, 11:38 PM | #32 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250R, Cbr 600RR Cbr600F4i Posts: 75
Those stock tires... are quite piss poor in my opinion! I would ditch them and get some new ones!
August 2nd, 2009, 10:05 AM | #33 |
So First I did the chain maintence. It eased things up some but the rear still felt like it was getting away from me so then I back off on the rear shock and that seemed to help the most. The feeling was really only present when turning city corners. Now with the suspension on 1 I dont like the way thing feel on long sweeping turns on the highway!! sheesh. I am still running soft on the tire pressure. so I'll play around with that now to see if that helps on the highway. If not im just going to go to level 2 on the rear an go slower around corners.
Sorry for the late reply guys Ive had alot going on lately. Thanks Im gonna have to wear these stockers down first before I look at getting new rubber. Seems like the economical way to go for me. rry. Ive been pretty busy
August 2nd, 2009, 10:16 AM | #34 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
One thing I have noticed on all bikes I have ridden, is that if you come to a section of road where the pavement is uneven (or hilly as I like to call it... Kinda like washboard, but smoother and further apart) The bike will tend to track arround those little hills. This is even more pronounced when going slow and even more still when breaking. There is this one section right infront of my office where the road is terrible and it feels almost like the back tire has no traction what so ever. I have found that it is more pronounce with the stiffer preload setting, but I like the stiff preload when on the highway so I decided I can live with it.
When this first happened to me years ago I though there was something wrong with my bike. I checked everything out and it all seemed to be okay. Plus I never noticed it except when on those roads with "hilly" pavement. I would look at the roads where it has felt funky and see if that is your problem.
Addicted to anything that has an engine and rolls. |
August 2nd, 2009, 10:23 AM | #35 |
ya. I think ur right. Ill have to find a happy median and live with it.
I'll check the corners where Ive felt it and post back. Off the top of my head I know that one is a high traffic main route that probably does have slight tire grooves worn in. I remember the pavement looks like its coarse too. So probably when turning that corner the least thats going on is Im getting some of those grooves while while entering my line.
August 3rd, 2009, 11:10 PM | #36 | |
August 12th, 2009, 12:31 PM | #37 |
bumping preload from 1 - 3 made big difference on same roads, might back down to 2 tomorrow to see if that is a good compromise for me.
Squirrelly back end | Proteus | Riding Skills | 27 | October 16th, 2014 12:27 PM |
[motogp.com] - Crutchlow searches for more front end feeling | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2013 01:40 PM |
[crash.net - MotoGP] - Rossi: Ducati front-end feeling 'not far' from Honda | Ninjette Newsbot | Motorcycling News | 0 | February 2nd, 2012 09:50 AM |
[crash.net - MotoGP] - Rossi: Ducati front-end feeling 'not far' from Honda | Ninjette Newsbot | Motorcycling News | 0 | February 2nd, 2012 09:10 AM |
Was Stoner really squirrelly or what? | dyeclan | General Motorcycling Discussion | 9 | April 24th, 2009 11:32 AM |
