Old August 2nd, 2009, 10:23 PM   #1
Rafalski
Motorcycle(s): Ninja 250R 08
Cant start with choke or stalls
So i cant start the bike with the choke on. and when i open the choke while warmin it up, the revs start dropping the lower the choke i move toward myself.
Which is a little odd.
08 ninja btw.
Rafalski is offline   Reply With Quote
Old August 2nd, 2009, 10:25 PM   #2
are you turning the throttle when you have the choke on when you are trying to start it? does the bike start w/o the choke?
Old August 2nd, 2009, 10:54 PM   #3
Rafalski
Yeah choke is farthest away from me. Bike starts up, then i let it idle to warm up, now if i move the choke toward me the revs begin to drop.. so i put it back far away from me so it doesnt stall.
Old August 2nd, 2009, 10:57 PM   #4
how long are you letting it warm up before you move the lever toward you?
Old August 2nd, 2009, 11:00 PM   #5
Rafalski
I was doing it right away, as your supposed to warm it up with a choke right?
Old August 2nd, 2009, 11:39 PM   #6
yes, start the bike with the choke on and let it rev about 2-2.5K. Keep moving the lever towards the off position in increments, but keep the revs in that range. As the bike warms up w/ the choke on, the revs will want to climb, so readjust the choke lever when it does that. After a few minutes (depending on the bike) you will be able to turn off the choke completely and the bike should be able to idle with the choke completely off.
Old August 2nd, 2009, 11:57 PM   #7
Rafalski
It doesnt turn on with the choke on. Thats the thing. If i start it with choke off itll go up to 1.2 k then if i move the choke on the rpms drop down below that. and go lower as i move the choke on. So i turn it off.
Old August 3rd, 2009, 12:06 AM   #8
zartan
zartan's Avatar
Motorcycle(s): 08 250 R
has it been rejetted or shimmed?
I rarely ever use the choke I have both rejet and shimms
Mine just warms up on its own with a couple blips of the throttle.
"Don't let adverse facts stand in the way of a good decision" Colin Powell
zartan is offline   Reply With Quote
Old August 3rd, 2009, 12:17 AM   #9
check your choke cable slack adjustment. it's outlined in the owner's manual.
has it always done this or is the bike new to you?
Old August 3rd, 2009, 04:28 AM   #10
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Pulling the choke lever towards you closes the choke, making the bike run rich for cold starts. As the bike warms up you open the choke by pushing the lever forward (away from you). You're just doin it backwards.
Old August 3rd, 2009, 07:23 AM   #11
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
Yeah, I was just thinking the same thing. The lever should be closest to you when starting the bike, not farthest away. You push it away from you as the bike warms up.
TrueFaith is offline   Reply With Quote
Old August 3rd, 2009, 09:58 AM   #12
Rafalski
Really because everything i read on the 08 model the choke closest to you opens it, farthest away close's it.
Old August 3rd, 2009, 10:07 AM   #13
rockNroll
rockNroll's Avatar
Yes, really
Old August 3rd, 2009, 10:13 AM   #14
Rafalski
Yes, really
They should really put which way is on and off. SO i been riding with the choke on all the time then. Let me try it the other way. Choke away move it down after a min or 2.
Old August 3rd, 2009, 10:32 AM   #15
Rather than open/closed, let's use on/off. You want the choke off when you're riding normall, but you want the choke on to start it, in most cases. So you sit on the bike, pull the lever all the way closest to you. Start the bike and the revs are probably up in the 3k - 4k range. Back out the driveway, start riding as normal, and after 30 - 60 seconds you can push the lever all the way back forward to turn the choke off and you're good to go.
Old August 3rd, 2009, 02:30 PM   #16
TrueFaith
TrueFaith's Avatar
Yeah, don't get hung up on "open" or "closed". Towards you to start, away from you to run normally.
Or if you're looking at the choke from the very end of the bar it's on it's right to start, left to run.
Old August 3rd, 2009, 04:16 PM   #17
Rafalski
When the choke is closest to me it drops in revs. i turn it on choke far away itll be at about 1.3k idle then as i move it toward me it drops below that.
Old August 3rd, 2009, 07:17 PM   #18
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
Old August 3rd, 2009, 11:20 PM   #19
Rafalski
as i pull toward me the idles drop. So when i use the choke my idles drop. IT does not explain that in there.
Old August 3rd, 2009, 11:45 PM   #20
if it does that, something's wrong with your choke. (obviously)
has it always done this? new to you bike? just started doing this?? ... more info is needed.
Old August 4th, 2009, 10:41 AM   #21
elars
Motorcycle(s): None
When I was young and cars still had chokes (okay I was like 5, haha) I always thought the choke symbol was an N for neutral, and got really confused by the turtle and rabbit. I thought it was like, go slow and go fast mode They should put the turtle and rabbit back on there. Nostalgia. :P
elars is offline   Reply With Quote
Old August 4th, 2009, 02:48 PM   #22
TrueFaith
TrueFaith's Avatar
You seem to be posting that a lot lately Kelly.
What's going to happen when the cold weather gets here?
Old August 4th, 2009, 02:58 PM   #23
well, if I do as suggested by another forum member here, I shouldn't even bother posting that.... I should just not respond to repeated questions that make me sigh.
Old August 4th, 2009, 03:13 PM   #24
Banzai
Psychic war veteran
Banzai's Avatar
It runs in cycles (edit to add=little bike joke there!). We'll eventually reach the critical mass where anyone will post the correct answer, and the rest of us will just read it, nod our heads in agreement, forgo the discussion and debate (again), and the thread will cycle to the bottom in short order.
Old August 4th, 2009, 03:59 PM   #25
lol... on other forums I've been on, when it gets to that state, I tell them to search.
Old August 4th, 2009, 10:54 PM   #26
Rafalski
Always done it let me give you a better explanation.
Choke is farthest away from me.
I put in key in ignition turn it on killswitch is off.
click starter
Starts up
Begins idling at my set amount of 1.3k
Runs fine.
Pull choke closer to me to warm baby up.. as it passes the play portion and is engaging revs start dropping
The closer it goes the lower the rpms.
Then i pussy out cuz i dont want it to bottle up and stall so i move it back farthest away from me.
And it goes back to idling at 1.3k
Then i just let it heat up like that and ride away.
New bike, had it since july 28th ish.
Old August 4th, 2009, 11:03 PM   #27
Something isn't right with the bike. The closer you pull that lever to you, the higher the revs should go. The farther you push that lever away, the lower the revs will go. If the engine is completely cold, some of them will not start without the choke, and will not hold enough revs to stay running with the choke pushed all the way away from you. It does sound like your bike is behaving in the exact opposite manner. I guess there's a chance that the choke cable is somehow mounted incorrectly and is manipulating the choke opposite to how we'd expect, but that sounds like quite a longshot.
Old August 4th, 2009, 11:12 PM   #28
try this... pull choke towards you all the way, then hit start button w/o touching throttle. bike will stumble to life and rev to about 3-4000. adjust the idle so it idles at 2500. rev the throttle a bit and the bike will rev higher... keep adjusting the choke so the bike stays at 2500.
after a few minutes, you'll be able to turn the choke completely off then the bike should idle at your preset idle. I set mine to 1500 after the engine is completely warmed.
are you the original owner?
Old August 4th, 2009, 11:15 PM   #29
Rafalski
Ill try this and post my findings.
Never tried starting while in full choke but starts fine with choke off.
Question i adjust idle using the little side thing but wouldnt that mean re adjusting it everytime i ride, so that it can go back to a steady idle.
Owners manual says to keep it at 1.3k
Old August 10th, 2009, 11:54 AM   #30
Rafalski
So i did it that way and it works. But sometimes it wont start up itll stall right away, so it takes 1 or 2 or 3 starts before the whole thing starts up with choke open while with it closed its first time everytime.
Old August 10th, 2009, 03:30 PM   #31
g21-30
g21-30's Avatar
Maybe I missed something! If it starts without the choke, then don't use the choke and be VERY grateful! When the weather gets colder, do you think it will still start without the choke? If it does, what more could you ask for?
Are we trying to create a problem by forcing the use of the choke? Adjust your idle with the black knob on the left side beneath the seat, after the bike is warmed up. Next, go ride it and stop worrying. If there is a real problem, I'm sure it will present itself at a later date.
EDIT: I considered your situation and here is some additional info that has been alluded to previously by others (Zartan):
If the prior owner changed the jetting this would allow starting cold with little or no "choke". This would also cause the bike to die with any choke applied while warm. A dyno-jet kit could and would change the jetting. One or two sizes up on the pilot jet almost eliminates the need for the choke.
Do the plugs look black like its running rich? If yes, maybe the choke (enricher) is staying on just a little, not sealing. This would happen if the cable is mis-routed or poor adjustment. This would cause the bike to run slightly rich all the time. The choke cable operates both carbs. (two enrichers). YMMV
Last futzed with by g21-30; August 10th, 2009 at 03:40 PM. Reason: Reconsidered my comments
Old August 10th, 2009, 10:31 PM   #32
Rafalski
HOw do i check the plugs looking black. Well is it odd that with choke it wont start but withought it does. It has been pretty hot. Will see what happens.
Old August 10th, 2009, 10:40 PM   #33
Raf,
I take it you bought this bike used... is that correct? As Zartan said early on, it could be already rejetted/shimmed and that's why you don't need to use any choke at startup.
Old August 11th, 2009, 12:30 AM   #34
Rafalski
Raf,
Yes but im sure she would have mentioned that when i purchased it. it only had 1500 km.
Question if it was rejetted shimmed just let it warm up a bit and go that should be fine?
Old August 11th, 2009, 12:38 AM   #35
yep, that should be fine as long as the bike doesn't bog or stall when you're starting off from a stop. You may have one of the good bikes that was properly set up from the factory.
you might want to ask the previous owner, if you can, if anything was done to the jetting.
in the end, don't worry about it as long as you can get the bike started, warmed up and it runs great after being warmed.
Bike doesn't need choke on start up ieathonda 1986 - 2007 Ninja 250R Tech Talk 5 April 7th, 2015 11:05 PM
After warm up, moving off of choke stalls engine ricomtzjr 2008 - 2012 Ninja 250R Tech Talk 5 December 16th, 2012 11:24 AM
Can't start w/ Choke on FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 6 September 4th, 2012 06:57 PM
Engine Stalls Without Choke Samer 2008 - 2012 Ninja 250R Tech Talk 11 September 1st, 2012 11:32 AM
Help with cold start (without choke) d16soda 1986 - 2007 Ninja 250R Tech Talk 4 August 31st, 2011 01:17 PM
