Old August 5th, 2009, 09:55 PM   #1
mista350z
Motorcycle(s): 08 CBR600rr, 08 Ninja 250r - sold
Slip on exhaust runs hot?
Ok so I installed the 2bros slip on exhaust last week. I rode a couple times for about 45min/per ride. My bike ran extremely hotter than usual. The gas tank was super hot. The weather was like any normal day and this just started happening when i installed the exhaust. Another thing I noticed was that my idle went from 1500 to about 1800-2200 at times. I didnt do any other modifications to the bike yet. Is this normal? I am kind of scared of over heating my bike.
mista350z is offline   Reply With Quote
Old August 5th, 2009, 10:43 PM   #2
you are running lean. lean conditions produce more heat. how lean is too lean? dunno, but if I were you, I'd at least shim the needles if not do a rejet.
...but gee, doesn't that exhaust sound good?
Old August 6th, 2009, 12:24 AM   #3
mista350z
Exhaust sounds mean. Kinda loud at night. Afraid to wake the neighbors....So will anything happen to the engine if I dont shim or rejet? I plan to eventually, just to lazy to actually sit down and rip apart the bike.
Old August 6th, 2009, 01:15 AM   #4
most likely not, but it can burn valves if too lean. best way to tell is to do a plug color check, but if you're too lazy to rejet I suspect you won't be interested in a plug check either.
good luck
Old August 6th, 2009, 02:12 PM   #5
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
if you dont want to shim the needles yourself Im sure a local shop can hook it up for cheap
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods
Cali619 is offline   Reply With Quote
Old August 13th, 2009, 05:50 PM   #6
a10forwar
Motorcycle(s): 09 Ninja 250R SE
I shimmed my needles two days ago and it was alot more difficult than I thought it would be. SO BE CAREFULL. Here is a list of things you need to pay attention too.
1. When removing the gas tank be carefull for the electrical connector, mine had barely enough slack to disconnect.
2. When removing the plastic caps on the carb, use alot of pressure on the screws. They are hard to get to and you may end up striping one out. And that would be bad.
3.Rt side is easier to do, by far. 4 black screws with nothing in your way sorta. I started with this one first for confidence of completion.
4. Lt side has 3 silver screws and 1 black screw. 1 silver screw for the choke cable bracket and 2 silver screws for a vacuum valve of some sort. The choke cable bracket is easy to move out of the way. Just move it forward. The vaccuum valve on the left has two hoses that go between the rt and lt carbs. I moved the vacuum valve with bracket lt and aft to get the best clearance. The hoses then split the carbs for easy removal of cap.
5. Be very carefull with each vacuum due to the fact that these are made to be a very thin membrane. Make sure when putting them back on you take your finger and ever so slightly rub the circumfrence of the vacuum to position the seal into the groove.
6. Take your time, mark everything and have fun. This is not intended to be a full HOW-TO. Just key details I thought might be important.
a10forwar is offline   Reply With Quote
Old August 13th, 2009, 07:38 PM   #7
Yep, James... all valid points.
So, how does the bike feel after shimming? have you pull off the snorkel yet?
Old August 15th, 2009, 01:16 AM   #8
Sound Wave
Ramen Rider
Sound Wave's Avatar
if you use a pair of tweezers and grab out the needles, then you don't have to remove the diaphragms. still would be a good idea to double check their position before putting the caps back on though.
Old August 15th, 2009, 11:15 AM   #9
a10forwar
Never thought about tweezers good idea. But I looked down there to see the needle before I pulled it though.
Funny thing it backfired as soon as I started it. It does start better though will probably never usr choke, never did before though either. Havent been in cold season yet. Oh well. Rides good. Little better control and gears seem longer. Mostly 3rd ?? I hope I didnt put too much shim on it. Two washers .032 total. No mods on eng yet. No exhaust mod either.
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
slip on exhaust? NinjaLINY 2008 - 2012 Ninja 250R Tech Talk 7 April 30th, 2014 07:00 AM
Slip on exhaust? m_curtin52 2008 - 2012 Ninja 250R Tech Talk 2 April 11th, 2012 10:40 AM
[topix.net] - Ben Spies Runs Hot Lap Around Indy Ninjette Newsbot Motorcycling News 0 July 2nd, 2008 02:45 PM
[motorcycle-usa.com] - Ben Spies Runs Hot Lap Around Indy Ninjette Newsbot Motorcycling News 0 July 1st, 2008 03:59 PM
