Old December 30th, 2008, 04:38 PM   #1
SF-Dug
SF-Dug's Avatar
Never washed a motorcycle before. Any tips?
Is there anything I would need to know before, during and after I wash my motorcycle tomorrow? Would I need to reapply lubrication on the chain after washing it? What about the other parts of the motorcycle which are grease/oiled up for mechanical reasons. Should In be concern with these parts as well? Should I use warm or cold water? Any tips would be helpful.
SF-Dug is offline   Reply With Quote
Old December 30th, 2008, 04:47 PM   #2
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
you should be concerned with hiting any moving or mechanical parts with a pressure washer (ie: anything with lubrication or electronics). don't put anything slick like armerall on stuff you don't want slick (ie: tires).
thats about it really.
click here
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old December 30th, 2008, 06:24 PM   #3
BlackKarma
BlackKarma's Avatar
Motorcycle(s): 2004 Chrome Yellow Ninja 250
Don't Armor all your seat! And a skinny tire brush works wonders...
Well, either you're part of the problem, part of the solution,.....or you're just part of the landscape. - lndeed. "Hatzofeh Lifnei Hamahaneh"
BlackKarma is offline   Reply With Quote
Old December 30th, 2008, 06:48 PM   #4
Angel-be-Good
Angel-be-Good's Avatar
Motorcycle(s): '08 Ninja 250, '11 Street Triple R
Do not shine your tires.
The Sunday Best | Current mileage: 50,000
Angel-be-Good is offline   Reply With Quote
Old December 30th, 2008, 06:51 PM   #5
I've got one of those Mr. Clean auto washers that does a pretty good job. If my bikes are really dirty, I'll start with that. It's just an attachment on the end of a hose that has settings for wash, soap, and ionized/filtered water to dry. It's not nearly strong enough coming out of the hose to get past seals, but it's enough water to help make washing the bike pretty darned quick and easy.
After it dries, I do use plexus on just about all the painted or shiny surfaces; adds a bit of protection and gives it that "shiny/wet" look. If I did use any water, I do make sure to clean/lube the chain afterwards.
If the bike isn't too dirty, I'll just use the plexus and go from there.
Old December 30th, 2008, 06:53 PM   #6
SF-Dug
SF-Dug's Avatar
Okay I get the not shinning the tires part. I don't want to endanger my only two means of traction. Would using an old tooth brush and for the hard to reach areas be okay? Would I have to re-grease or lube anything after I am done?
NVM: Alex you hit most of my questions.
Old December 30th, 2008, 07:06 PM   #7
Syphen
Some weird Canuck!
Syphen's Avatar
Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i
I don't wash the bike TOO too much. I give it one or two complete clean and waxings during the summer and the rest of the time just dust it off with microfibre clothes and use car detailer. Brake parts cleaner on a rag to clean chain before re-lubing (do not spray it on directly... or drench the rag, it will KILL your o-rings).
It may sound pretty cheap, but one thing that I found that seemed to clean the bike really good, and all of the bug splatters: plastic & vinyl house siding cleaner. It comes in a bottle that you screw right on the end of a garden hose. It premixes soap and water and works really well. Just stand back about 10 feet from the bike.
You can see the bottle of cleaner attached to the hose in this pic. Make sure to dry the bike off with some really nice absorbent shammies after washing. Water marks suck.
In terms of greasing & re-lubing? I lube all the pivots for shifters and levers, as well as the axles once every year. Right before I take the bike out for spring. The chain should be cleaned and re-lubed every 1000km or so. (I've let it go longer but you shouldn't.)
Last futzed with by Syphen; December 30th, 2008 at 07:07 PM. Reason: I cannot spell, nor write a good sentence. I went to school for electrical engineering...... not english.
Syphen is offline   Reply With Quote
Old December 30th, 2008, 07:14 PM   #8
This is for basic washing of the bike-
Wash the bike like you wash your car. No high pressure. I use a garden sprayer attachment on a hose, bucket of soapy water, a wash mitt for the plastics, a 4" painters brush to get in the hard to reach areas. I stay away from the really greasy areas like the drive chain.
After you're done washing and drying the bike, start it up and let the the engine warm up to dry out any parts that may be sensitive to water. If you have the time, take it for a quick spin to blow out any water left in the crevices and come back and lube the chain.
Every 6 months or so (or when I ride in the rain ), I remove the front fairings, front fender, seat and rear plastics and wash the plastics (inside and out), engine and frame thoroughly. This is where the painting brush comes in very handy.
Old December 31st, 2008, 11:27 AM   #9
BlueTyke
So slow I'm first!
BlueTyke's Avatar
Motorcycle(s): 06 Kawasaki Ninja EX250
Get a Sud Buddy to clean it?
Learn from the mistakes of others, you cannot make them all yourself. Save yourself the trouble and Learn.
BlueTyke is offline   Reply With Quote
Old December 31st, 2008, 11:43 AM   #10
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
^ and be sure to take pics for us
Old December 31st, 2008, 12:09 PM   #11
Sailariel
Sailariel's Avatar
Very good advice. One thing no one mentioned was the exhaust. When I wash the bike, I usually put a cork in the exhaust.
Old December 31st, 2008, 01:53 PM   #12
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
Good idea. If water does get into the exhaust, fully warming the bike after a wash will cause it all to boil and evaporate.
NJD022588 is offline   Reply With Quote
Old January 1st, 2009, 01:35 PM   #13
SF-Dug
SF-Dug's Avatar
Thanks for all the advice folks. Keep it coming if it has not been mentioned already.
Old January 1st, 2009, 01:38 PM   #14
lol... you mean you still haven't washed the bike??? what are you waiting for???
Old January 1st, 2009, 04:35 PM   #15
g21-30
g21-30's Avatar
Take it to my dealer: http://www.ninjette.org/forums/showthread.php?t=11014
Old January 1st, 2009, 06:11 PM   #16
SF-Dug
SF-Dug's Avatar
Originally Posted by g21-30 View Post
Ummm.....Feel free to PM that "dealer" address at anytime !
Old January 2nd, 2009, 07:38 AM   #17
sprale
Dead-thread Necromancer!
sprale's Avatar
Motorcycle(s): K5 V-Strom
I found out the hard way on my first motorbike in high school...
In 21k miles, I think I've already washed my bike at least four times.
2007 Kawasaki Ninja EX250 ZG250 Quarter-Concours commuter Gone
2005 Suzuki V-Strom DL1000 Big Black Vee future hack?
sprale is offline   Reply With Quote
Old January 2nd, 2009, 07:45 PM   #18
BlueTyke
So slow I'm first!
BlueTyke's Avatar
I think... It was in regard to Sud Buddies... I do not see Sud Buddies there.. Just Sud Bunnies...
Old January 2nd, 2009, 09:00 PM   #19
g21-30
g21-30's Avatar
BlueTyke... I was telling him to take it to my dealer for a wash. Didn't mean to get you and noche_caliente's hopes up!
Old January 3rd, 2009, 12:26 AM   #20
aloh
lolwut
aloh's Avatar
I just use a hose and the regular automotive detailing products i use on my own car. I usually just use a light auto shampoo and pat dry with a waffle weave microfiber towel. I only use the hose on areas like the seat, plastics, wheels, etc, and use a wet towel on the controls/gauges/sensitive areas. I plan to wax it every month or so depending on how much I ride
For "in between" cleanings I use a quick detailer spray on the paint.
Detailing is a little hobby of mine. The results always make it well worth the time spent!
Here's a pic i took after a fresh detail:
08 Blue Ninja 250R
aloh is offline   Reply With Quote
Old January 3rd, 2009, 03:24 PM   #21
BlueTyke
So slow I'm first!
BlueTyke's Avatar
I was taking no form of offence what-so-ever. I am not sure where Walnut is though... Is that in Virginias?
Old January 3rd, 2009, 04:27 PM   #22
HKr1
IC2(SW)
HKr1's Avatar
Note to self ....... "Bikes need a washing"
Old October 22nd, 2009, 05:13 AM   #23
g21-30
g21-30's Avatar
Found this on MCN:
http://www.mcnews.com/mcn/technical/...ilDetails1.pdf
http://www.mcnews.com/mcn/technical/...ilDetails2.pdf
http://www.mcnews.com/mcn/technical/...ilDetails3.pdf
http://www.mcnews.com/mcn/technical/...ilDetails4.pdf
http://www.mcnews.com/mcn/technical/...ilDetails5.pdf
Old October 22nd, 2009, 05:50 AM   #24
My bike is so dirty, I don't want to put the cover on it for fear that the dust will scratch.
Old October 22nd, 2009, 06:44 PM   #25
sprale
sprale's Avatar
At over 27k miles so far, I think I recently washed the bike maybe five times. I also spend more time riding than trying to be the top poster on the forums
Old October 22nd, 2009, 07:29 PM   #26
Snake
Snake's Avatar
Sounds like you need to wash the bike in a bad way.
Old October 22nd, 2009, 09:17 PM   #27
andrewexd
andrewexd's Avatar
Motorcycle(s): 07 GSXR600 (N250 sold :( )
I dont bother washing much because i dont have a garage and its black. I just go to the car wash places, spray with water on low pressure put some suds on and wash it off, dry.
andrewexd is offline   Reply With Quote
Old October 22nd, 2009, 11:13 PM   #28
ManyCavies
ManyCavies's Avatar
Motorcycle(s): . . . . . . . 2000 Suzuki Intruder VS800 "Suzi", 2008 Kawasaki Ninja EX250 "Yoshi"
I washed my bike today!! It has been awhile .
But I do love a clean bike.
GO GREEN!!
GOT MY PINK ON!!
ManyCavies is offline   Reply With Quote
Old October 22nd, 2009, 11:50 PM   #29
Ryosen11
Motorcycle(s): CBR600RR Ninja 250R(sold)
I wash my bike mainly with ONR(Optimum No Rise)
http://www.optimumcarcare.com/onrwns.htm
This is a very good product especially if you don't have access to a water hose such as in apartment complex. You just need a bucket and couple microfiber towels. Very quick and easy
I also use this on my car regulary for in between washes or when I don't have time to do a full wash. You can also use this as quick detailer or clay bar lube depending on the amount you mix with water. Their spray wax is very good too.
...wow, I should get paid by them
Ryosen11 is offline   Reply With Quote
Old October 23rd, 2009, 12:21 AM   #30
The problem is that I commute with it daily and so it has to remain uncovered during my graveyard shift. Every morning, I come out of the office to go home and it is soaking wet with dew. That dew traps dust which builds up daily and stays behind when it dries. I'd have to wash every other day to stop it.
Old October 23rd, 2009, 01:34 AM   #31
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
I have to wash mine after every ride (Bug Guts) then it gets a cover till the next ride.
Old January 15th, 2010, 01:21 AM   #32
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Washing the bike
Any tips on washing the bike? I'm thinking of just taking a bucket, soap+water, and washing it that way. Then wax after. Are there any areas I should avoid getting wet? Thanks!
Betlog is offline   Reply With Quote
Old January 15th, 2010, 01:51 AM   #33
http://www.ninjette.org/forums/showthread.php?t=11311
Old January 15th, 2010, 02:27 AM   #34
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
I have a brush on the end of a hose and use a small water flow; this brings off all the dirt without the risk of drowning the electrics or damaging seals. If you have tar stuck on the bike a soft cloth with some gas on it will bring it off. Then polish it as much as you like.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old January 15th, 2010, 07:30 AM   #35
Snake
Snake's Avatar
Avoid using harsh chemicals, especialy gasoline. If you have road tar you can buy a can of "bug and tar remover" at an auto parts store. Also do not use detergents, use car wash soap.
Old January 15th, 2010, 08:43 AM   #36
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
don't blast the bike with high pressure. especially radiator fins, swingarm pivots, linkage, etc.
Old January 15th, 2010, 08:43 AM   #37
especially avoid drive thru car washes, you'll be soaked all the way home.
Old January 15th, 2010, 09:23 AM   #38
tjkamper
tjkamper's Avatar
That's how I always do it. That way my gear is sqeaky clean too.
Old January 15th, 2010, 09:28 AM   #39
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
I'm giving the IT guy your email address....you can explain all the water that is dripping off my monitor. Had a mouth full while I was reading that
Using Pedal Power
divingtigger is offline   Reply With Quote
Old January 15th, 2010, 09:36 AM   #40
Haha, I actually had an experience in a car one time at the car wash. I somehow missed the little roller that pulls the car, so I tried to drive the right speed through the carwash. It was tricky, the second I got out of that thing I sped off towards the highway.
Need help washing UltraHarley1 2008 - 2012 Ninja 250R Tech Talk 16 June 9th, 2014 11:43 AM
Washing tip algs26 Videos 13 March 3rd, 2014 08:33 PM
Cleaning/washing your gears toua70 Motorcycle Gear 16 July 21st, 2012 08:49 AM
Washing Bike w Fairings Off Francis 2008 - 2012 Ninja 250R Farkles 4 March 27th, 2012 06:24 AM
Washing my helmet headshrink General Motorcycling Discussion 28 June 11th, 2010 01:22 PM
