Old October 25th, 2009, 03:00 PM   #1
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
Is 9000 rpm too much at 70?
2009 - 1800 miles - I'm 150 lbs.
I think I may have a tach or ignition problem (from pass post) - I went for a ride today and keep a mental note of the RPMs - 55 mph about 6200 rpm -
70 mph about 9000 rpm - does this seem high? Doing some research on the forum - I found posts about the tach and the IC ignitor - could I have one of these issues? Bike is still under warranty.
austexjg is offline   Reply With Quote
Old October 25th, 2009, 03:31 PM   #2
NickH
NickH's Avatar
Motorcycle(s): 2009 Buell XB12Scg and 2009 Kawasaki Ninja 250R
I usually hit 8000 rpms at 70. I'm around 225lbs......weight will make a difference.
-Nick-
Posted via Mobile Device
NickH is offline   Reply With Quote
Old October 25th, 2009, 04:02 PM   #3
-Nick-
In the same gear, it's not supposed to. If it works harder/burns more fuel/gets hotter and has the CDI issue, yeah.
Old October 25th, 2009, 04:04 PM   #4
bob706
bob706's Avatar
70mph @ around 9k rpm doesn't sound like a problem. I wouldn't worry too much.
Old October 25th, 2009, 04:11 PM   #5
andrewexd
andrewexd's Avatar
Motorcycle(s): 07 GSXR600 (N250 sold :( )
im at the same. you might want to check your clutch freeplay
andrewexd is offline   Reply With Quote
Old October 25th, 2009, 04:11 PM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
I find in top gear, stock gearing, stock tires, my revs are about 1,000 more than my speed. 7000 rpm at 60, 8000 rpm at 70.
Old October 25th, 2009, 05:57 PM   #7
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
put a 15 tooth up front...run at 9k in 6th..smile
QTRltrPWR
nate-bama is offline   Reply With Quote
Old October 25th, 2009, 07:06 PM   #8
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
I think the tach is just about worthless on these bikes, mine shows anywhere from 7500 to 10k at 70. Seems like ambient temp and bike temp have a role in the different readouts.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink
Cedilla is offline   Reply With Quote
Old October 25th, 2009, 07:25 PM   #9
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
Cedilla, that sounds like the infamous CDI problem.
LazinCajun is offline   Reply With Quote
Old October 25th, 2009, 07:52 PM   #10
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Not sure how much of a difference there is in rpms between the pre-gen and the new-gen. However, on my 1994 ninjette in 6th I run between 1k to 1.5k higher in rpms then mph. So for me at 70 I'm usually around 8500 or so. Since mine is modded for more power it could be you don't have a real problem. But I'm not an expert.
sombo is offline   Reply With Quote
Old October 25th, 2009, 07:58 PM   #11
Probably normal, wouldn't worry about it.
Old October 25th, 2009, 08:02 PM   #12
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Sounds about right to me
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old October 25th, 2009, 08:03 PM   #13
Angel-be-Good
Angel-be-Good's Avatar
Motorcycle(s): '08 Ninja 250, '11 Street Triple R
After my speeding ticket, I stick strictly to indicated 70 mph on the freeway and the tacho is consistently showing 9,000 rpm.
The Sunday Best | Current mileage: 50,000
Angel-be-Good is offline   Reply With Quote
Old October 25th, 2009, 08:16 PM   #14
killerkay3
killerkay3's Avatar
Motorcycle(s): 2009 Yamaha R6 / 2008 Green Ninja 250 (Sold)
im also 150lbs and at 70mph im at 9000rpms too, so i dont think theres a problem
killerkay3 is offline   Reply With Quote
Old October 25th, 2009, 08:23 PM   #15
rider weight has no effect on engine rpm at a particular road speed. it is a set mechanical function between the engine, f/r sprockets and tire diameter.
Old October 25th, 2009, 11:24 PM   #16
paterick4o8
paterick4o8's Avatar
Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636.
70mph in 6th = 9K really?
I am almost certain that at exactly 70mph I'm never @ 9K... usually below whenever I'm at that speed in that gear and I have not made any sprocket changes either
paterick4o8 is offline   Reply With Quote
Old October 26th, 2009, 12:36 AM   #17
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
I am not saying that mine was correct but I had 8500 at 75 mph, what is important is that it reads the same every time.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old October 26th, 2009, 04:19 AM   #18
ScorpionNinja
ScorpionNinja's Avatar
rider weight ...(the More you weigh, the less your Top Speed will be from a 100 lbs rider off the 100MPH mark)
When i ride 2-UP with dawn on back, my Top end is cut to 90 MPH, solo riding i hit 100 MPH. "IDC about the speedo 10% off thing, blah blah. "
Old October 26th, 2009, 08:26 AM   #19
Does the tach show less revs as well with a passenger. My thought would be the added weight reduces mph as you stated, and then rpm would also be less.
Old October 26th, 2009, 08:33 AM   #20
Weight doesn't affect what revs show up on the bike at a particular speed. In fact, nothing affects what revs the engine is turning at a particular speed, other than gearing changes. If the passenger causes you to go slower, then sure, the revs would be lower, but only because the speed was lower the same corresponding amount.
Old October 26th, 2009, 09:15 AM   #21
Originally Posted by Alex View Post
...nothing affects what revs the engine is turning at a particular speed, other than gearing changes...
Well worded. We all know that heat can affect what the tach shows with a faulty CDI, but not what speed the engine really is.
Old October 26th, 2009, 09:41 AM   #22
g21-30
g21-30's Avatar
The biggest problem with the faulty CDI is the rev limiter will cut in sooner, before you're truly at the engine's rev limit!!!!
Old October 26th, 2009, 11:11 AM   #23
Midnightrider
Motorcycle(s): Black 09 Ninja 250
I have run my Ninja up to 14000rpm and the rev limiter has not cut in. I too believe my tach is reading high. Does the rev limiter work off the tach or the cdi unit? Is it possible the cdi unit could be sending a faulty signal to the tach but the signal could be correct going to the rev limiter?
Midnightrider is offline   Reply With Quote
Old October 26th, 2009, 01:18 PM   #24
g21-30
g21-30's Avatar
Mike,
Off hand, I don't remember what the rev limit is; however, a search will probably reveal same. I thought it was like 12,500 RPM. It may be the tach is receiving a bogus signal and the RPMs are really less than the rev limit. When the CDI is bad, the displayed RPMs are higher than the actual RPMs!
Old October 26th, 2009, 02:43 PM   #25
tjkamper
tjkamper's Avatar
Weight doesn't effect the actual speed your engine is running. 9k at 70 is about a grand too much. That means the tach is reading wrong. This problem is common with a CDI Malfunction.
Old October 26th, 2009, 03:10 PM   #26
austexjg
austexjg's Avatar
Good thing it still under warranty - I'm considering the GTPP now - should I have this issue repaired ASAP, or wait until the first major service (with GTPP)? How do I convince the dealer that there is indeed an issue?
Old October 26th, 2009, 03:18 PM   #27
Just checked out the www.gearingcommander.com site. With stock gearing and stock tires on a 2008+ ninjette, at 9000 RPM in 6th gear the expected road speed is 73.1 mph. Our tachs have a fudge factor, and our speedos certainly have a fudge factor, so I wouldn't be immediately alarmed. It may be reading a little higher (or a little lower) than other bikes, but it doesn't mean there is anything particularly wrong with the bike. There very well may be. , but this data point alone isn't enough to come to that conclusion.
Old October 26th, 2009, 03:34 PM   #28
austexjg
austexjg's Avatar
What other things should I keep an eye out for to help add info. to determine if I have a true problem, or am I just wishing for a 7th gear?
Old October 26th, 2009, 03:42 PM   #29
The only likely problem is the CDI issue that seems to affect a number of our bikes. Check the wiki in the troubleshooting section for more detail than you'd ever ask for on the issue. In a nutshell, an overheating CDI causes the tach to do screwy things. Read higher when warm. In some bikes, that is accompanied by running problems as well, while on some bikes the problem seems to be exclusively a display problem on the tach. So if you see different engine speeds on the tach at different times of day, even though you're going the exact same speed on the speedo and are in the same gear, then perhaps you're experiencing the CDI issue.
But it's not likely. The ninjette runs high revs on the highway. With only a small handful of torque, it has to in order to have nearly enough horsepower to push us down the road at highway speeds. It's just the nature of the machine. Some folks do put on a larger sprocket in front to gear the bike a little taller, and lower revs somewhat on the highway, but it's not going to be a night and day difference.
Old October 26th, 2009, 03:53 PM   #30
austexjg
austexjg's Avatar
It does seem to read different RPMs as the heat goes up (guessing without a temp gauge), but the RPMs do seem to differ as the ride progresses. I will check out the wiki, thanks.
Old October 26th, 2009, 06:46 PM   #31
Cedilla
Cedilla's Avatar
Ill have to look into this as well, I just figured the tachs were garbage. Can the faulty CDI mess anything else up? My tach as not been reading right since day one, and it otherwise runs fine, the tach being off does not bother me much though.
Old October 26th, 2009, 08:19 PM   #32
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
Same here. For 60, 70, 80, and 90 my tach reads almost exactly 10,000rpm over the speedo.
The rev limiter should be between 13.5 and 14 if I remember right.
Reswob is offline   Reply With Quote
Old October 26th, 2009, 08:27 PM   #33
I can't believe no one has done this yet...
I hate DBZ so much.
Old October 27th, 2009, 03:45 AM   #34
g21-30
g21-30's Avatar
Before I converted my CDI to the '88-94 version, my tach red 7000 RPM at 50, 7500 RPM at 55, ..... when warm. When cold, it read 6000 RPM at 50.
Converted, it ALWAYS reads 6000 RPM at 50, whether hot or cold! The rev limiter is set higher than I want to take it!
Check out the DIY CDI conversion:
http://www.ninjette.org/forums/showthread.php?t=26765
Old October 27th, 2009, 08:28 AM   #35
My question was mainly the added weight of a passenger would reduce the top end mph, therefore revs would also reduce. So if at 10K rpm solo I am doing 90 mph (speedo indicated), and I add a passenger I would expect to hit 80 mph for example, and revs would be around 9K.
Another way to think of it is riding a single speed bicycle. If my legs spin the crank at 60 rpm and I can go 20 mph, then a passenger gets on the bicycle, the added weight reduces my crank rpm to 30 rpm and my speed drops to 10 mph. Not real numbers but just to make a point.
Old October 27th, 2009, 08:50 AM   #36
Regardless, the passenger is just a distracting detail. The RPM relates to the speed. Of course the top speed relates to the added load but that doesn't change that relationship any more than manually backing down you speed using the throtlle in the same gear. Not only that, top speed isn't as relevant as RPMs at a given speed.
Old October 27th, 2009, 08:57 AM   #37
That is what I am saying revs and mph (assuming same gear) move together. Adding a passenger (weight) puts more load on the engine thus reducing revs and mph. The same is true climbing a hill - revs and mph increase more slowly. Going down a hill revs and mph increase quicker.
Old October 27th, 2009, 09:15 AM   #38
No one's saying you're wrong. It's just clouding things up. Going up hill, you slow down. Going down hill, you speed up. Speed is what is relevant to RPMs... not the hills causing it. That means that they are a distracting/irrelevant detail. Lots of things other than weight or grade can slow you down by sapping power (or speed you up by reducing strain), including headwinds/tailwinds, elevation, etc.
Old October 27th, 2009, 09:17 AM   #39
Reswob
Reswob's Avatar
You answered your own question. Climbing a hill, if you don't downshift, the revs slow, and so does your speed. Engine speed and rear wheel speed are mechanically locked together. 8,000rpm in 6th gear will always be 70mph, etc.
Old October 27th, 2009, 09:28 AM   #40
A corner can also cause a change in rpm. As the bike is leaned and the tire is put on edge, the effective diameter changes, thereby changing the effective ratio. Probably not noticeable on the road, unless fully tapped before and through the corner.
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
[roadracingworld.com] - Sonoma Raceway Food Drive Pulls In Over 9000 Pounds Of Items Ninjette Newsbot Motorcycling News 0 November 19th, 2012 06:10 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
weird sound around 8500-9000 rpm rsamtani 2008 - 2012 Ninja 250R Tech Talk 26 June 12th, 2010 10:09 PM
[motorcyclistonline] - Suzuki GSX1300R Hayabusa - $9000 Streetbike Surgery Ninjette Newsbot Motorcycling News 0 June 23rd, 2009 08:00 PM
