May 1st, 2016, 12:54 PM | #1 |
Confirming rear wheel size & width
I'm about to go buy a new (well, used, from a store) rear tire for my '08. This whole time I've been reading the ninja250.org page on tire options, assuming the measurements were for/the same as a 250r. Now it seems that instead of the EX250's 16" wheel and 2.5" rim, the 250r uses a 17" wheel and 3.5" rim. Is that correct?
Thanks. |
May 1st, 2016, 02:30 PM | #2 |
Vintage Screwball
MOTM - Mar '16
Yes.
Stock is 130/70-17 You can also run a 140/80 if you want.
Goin' fast on slow bikes! |
May 1st, 2016, 05:35 PM | #3 |
Oh, really? I thought it's risky to go up in width due to manufacturer differences. I was planning on doing 120/(80-90)-17 or 130/(70-90)-17.
May 1st, 2016, 05:57 PM | #4 |
Vintage Screwball
MOTM - Mar '16
The tire manufacturer will tell you the appropriate size tire for your rim. Typically, three different widths will fit, one up and down from stock.
What brand are you looking at?
Rear wheel spitting up onto the fender & rear seat. Solutions? | uKER | 2013 - 2017 Ninja 300 Farkles | 21 | July 29th, 2013 01:00 PM |
08-12 front and rear rim width | Kangxi | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 17th, 2012 03:23 PM |
wheel stand width question | ubnewbie | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 14th, 2012 06:13 AM |
