December 5th, 2012, 06:53 PM | #1 |
Join Date: Jan 2012 Motorcycle(s): Blue 08 250 - Blue Magic Posts: 162
LED Integrated Tailights and Stock Turn Signals
Hey all!
I recently got my Motodynamic integrated taillight and I'm stoked to get it installed. As most integrated taillights do, it serves as both the rear turn signals and the tail light. However, I don't want to get rid of the stock turn signals either. More lighting can't hurt, right? My brother has done the same thing on his R6 with the Motodynamic taillight and LED rear turn signals so that the tailigh and signals flash. Can I use the stock turn signals and the integrated taillight to do something similar? Would I just remove the resistors and splice the taillight into the turn signal feed? Any insight would be appreciated! |
December 5th, 2012, 07:05 PM | #2 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Yes you can and Yep, that's exactly what you need to do... I'm assuming you've already installed the resistors/flasher relay you would need for this setup.
December 5th, 2012, 07:22 PM | #3 |
Thanks for the reply Hans! I haven't installed anything yet, bone stock. The tailight came with the factory harnesses to clip into the feeds for the turn signals. Those wires each have the resistors built in. (There are two "boxes" on each of those wires before the clip for the factory harness). If that's all I need then I will just cut the leads before the resistors and then splice those lines into the stock turn signal feed.
December 5th, 2012, 07:36 PM | #4 |
You'll need a new relay to manage the LEDs or they won't work properly. @CThunder-blue can probably hook you up from his site modmy250
December 6th, 2012, 12:21 PM | #5 |
Razor's Edge
Join Date: Nov 2012 Motorcycle(s): 2007 Sportster XL1200C Posts: 196
Phych0hans, what's up with your sig? LOL!
Rider, keep us updated in this. I haven't seen this done? DIY? |
December 9th, 2012, 09:28 AM | #6 |
Absolutely! I'd be glad if it's never been done before. It could be a while as I first should decide what is the appropriate fender eliminator. Plus it's getting cold where I live and my garage is not heated
December 9th, 2012, 10:24 AM | #7 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
Momaru's bike is this way, I'm effectively doing the same thing for my front blinkers (mirrors and flushmounts), and eventually plan to do the same to the rear.
Here's some DIYs/supplies for you: http://www.ninjette.org/forums/showthread.php?t=24500 discusses the "Diode mod"; you can also buy the kit as discussed if you prefer. This prevents turning your turn signals into hazard lights. http://www.superbrightleds.com/morei...asher/782/836/ <- will keep your 'blinks' in sequence even if resistance changes. You may not need it, but if you have weirdness -- e.g. the turn signal turns on and not blinking -- this will fix it. Otherwise some stranded wire, soldering iron, and heat shrink tubing will be the majority of what you need -- create the proper "Y"s and you're set. If you want to do it with nice connectors then you want these: 2 Position 050-HC Connector available here:http://www.easternbeaver.com/Main/El...onnectors.html These are the same connectors the existing lights use, which means you can -- if needed -- connect either set to stock make sure they work, then just swap in the "Y"s to complete the circuits. Makes maintenance a lot nicer. |
Integrated Taillights w/ stock (or replacement) turn signals | Old Guy on a '08 | 2008 - 2012 Ninja 250R Farkles | 6 | September 9th, 2012 11:15 PM |
