December 6th, 2012, 06:45 PM | #1 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
Track headers!!!
Anyone been in there yet? Looking for a good pic of what is going on for future fiddiling around...
Last futzed with by old3; December 7th, 2012 at 07:27 PM. |
December 7th, 2012, 07:48 AM | #2 |
This cat is not out of a Ninja 250, but another Kawi. You can expect to see something very similar.
December 7th, 2012, 09:31 AM | #3 |
There is none in the California oem pipes. I don't expect there to be one in any of them if cali models don't have them
December 7th, 2012, 01:06 PM | #4 |
Join Date: Aug 2012 Motorcycle(s): '13 Ninja 300, '99 SV650 tracked Posts: 378
I think its all the back in the muffler, not the pipe.
December 7th, 2012, 02:29 PM | #6 | |
Kidding, right? I though I read a second cat was in the area of the mid pipe? If it is only in the slip on, great! I've "seen" quite a few so know what they look like. I was expecting to need to cut & gut the mid to get a good look at one for the 300. Far better if it isn't there to be "looked" at. |
December 7th, 2012, 02:38 PM | #7 |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
on the FI 250 there is 2 one as shown and another in the mid pipe
Be safe ride smart .....a dumb rider is a dead rider |
December 7th, 2012, 02:51 PM | #8 |
So, where's the reverse?
You'd have to open up the muffler to know for sure. The pdf brochure from Kawasaki on the 300 states that the cat is only on the collector pipe and not in the silencer. The ambiguity is whether this is different for Euro vs. Cali vs. 49 state spec.
December 7th, 2012, 03:14 PM | #9 |
Yeah, I have a feeling there is one in the collector too and that will require surgery to be seen.
I asked the Area P guy about it too, I'll follow up if I find anything else out. |
December 7th, 2012, 03:41 PM | #10 | |
you can test this by sticking a snake down the headers. it comes out the other side. wouldn't happen if there was a cat. edit: just realized this is 300s... not sure if its the same. probably different with efi.
December 7th, 2012, 03:52 PM | #11 |
Originally Posted by kbryant
OEM Cat is in the new left side collector (Headpipe) - not in the muffler. So, there it is, in the collector/header. I thought you were stating that perforated tube was the cat buddy. I must have misunderstood ya! |
December 7th, 2012, 03:58 PM | #12 | |
paging @cynicalkit from your experience in tearing open your exhaust... is there a cat in the oem headers?
here is the relevant info: post #59 http://www.ninjette.org/forums/showt...header+exhaust Quote:
December 7th, 2012, 04:22 PM | #13 |
Cats are a substrate that exist in honeycomb or even screen styles. I have screen style hi-po cats in my car exhausts.
Looks like the header will be coming apart! |
December 7th, 2012, 04:24 PM | #14 |
la pussy gata
Correctomundo. I can take pics of my stock exhaust later. I cut open the header and there is nothing in there. Two cats in the slip and a resonance header in the exhaust. That is it.
December 7th, 2012, 04:31 PM | #15 |
December 7th, 2012, 04:33 PM | #16 |
la pussy gata
This was on my 250. Not sure about the 300.
December 7th, 2012, 04:39 PM | #17 |
Ah, OK, different animal there. I'll post up what I find unless someone gets one open first.
Thanks |
December 7th, 2012, 04:51 PM | #18 |
Yeah, this is the 3-hunsky forum, doods/doodette, and b/c of the EFI the 300 only needs 1 cat, not 2 like the two-fiddy.
December 7th, 2012, 05:31 PM | #19 |
you probably should stick a firm tube down the header before you cut anything open... if the tube goes through you can be sure there isn't a cat there.
December 7th, 2012, 07:06 PM | #20 |
December 7th, 2012, 07:07 PM | #21 |
December 7th, 2012, 07:08 PM | #22 |
That is debris in the bottom pic where you should see the two header tubes. It is easily cleaned out and ready to weld back together from what I read.
No actual animals were injured in this series of pics. Saw, drill, hammer, flat screwdriver and 10 minutes of time. Add a breakfast to bribe a welder buddy and track only headers ready to go. I'll have them back on the bike by tomorrow morning for weekend track testing. |
December 8th, 2012, 08:41 AM | #23 |
Test ride today after welding it back together. No noise increase over my Akra open Ti slip on, feels like it has a real hit off the bottom, pulls the forks to top out harder for sure. I can't feel any "jetting" problems, fuels just as well as stock. No popping on decel, maybe a slightly louder burble when you just touch the throttle on decel but no real difference there.
All good and it cost me a lunch for my buddy and under 30 minutes total wrench time. Tuner time!!! |
December 8th, 2012, 12:42 PM | #24 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
lets see some pics!
VROOOM vrooom >.> |
December 8th, 2012, 04:13 PM | #25 |
The relevant pics are posted above. The re-attached pipe looks just like stock with a bead of weld around it.
December 8th, 2012, 05:22 PM | #26 |
Ninjette wanabe :D
I ment with slipon :S
VROOOM vrooom >.> |
December 8th, 2012, 05:25 PM | #27 |
December 8th, 2012, 05:58 PM | #28 |
DIY USB Cable with Voltage Converter | Ralgha | 2008 - 2012 Ninja 250R Farkles | 15 | April 2nd, 2015 10:49 AM |
Ninja cat pics | Ninjinsky | Off-Topic | 8 | September 2nd, 2014 10:20 PM |
07' Ninja 250 Farkles (pics pics pics) | instinct | 1986 - 2007 Ninja 250R Farkles | 4 | April 15th, 2014 06:26 PM |
Turbo'd 2008! pics! pics! pics! Dyno run video! | TheDuck | 2008 - 2012 Ninja 250R Tech Talk | 38 | September 19th, 2013 08:28 PM |
[roadracingworld.com] - Kevin Erion To Work With Catalytic Converter Manufacturer ACA | Ninjette Newsbot | Motorcycling News | 0 | December 12th, 2012 06:20 PM |
