June 25th, 2010, 12:12 AM | #1 |
high altitude power problems
is there any way to help a naturally aspirated engine in high altitude without adding compressed intake?
June 25th, 2010, 12:14 AM | #2 |
jetting it correctly for the altitude helps.
June 25th, 2010, 12:21 AM | #3 |
don't suppose anyone makes a carb with multiple sized jets (for different altitudes) that can be switched while the bike's running? (oh yeah it's called efi)
June 25th, 2010, 12:26 AM | #4 |
what's your main sizes now and what altitude differentials do you see? I run from sea level to 3800 ft with my jetting... no EFI on my bike. runs fine.
June 25th, 2010, 03:03 AM | #5 |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
If you got an original air intake, i would think opening it up or removing the snorkel would help. And then plug it when your going back down from the mountains.
June 25th, 2010, 11:49 AM | #6 |
Kkim, not sure on which jets it's on. full exhaust and jet kit were done by my brother while I was away. was jetted for sea-level, but when I get above about 5 to 6k feet i experience the loss on my top end (>10krpm gets a sudden power drop)
If this is purely fuel/air ratio issues (i have no doubt that it is) i'm wondering if its a bad idea to be running the engine in such varying altitudes without some type of adjustment? running rich can overheat your valves fairly easily, right? guess i'll invest some time in making a convertible snorkel... thanks for the suggestion guinss
June 25th, 2010, 01:23 PM | #7 |
do you spend the majority of time at sea level or altitude?
Guinss had a great idea with the snorkel... you may want to consider a dei quiet insert... that would help richen the mixture at lower altitude levels. If you read the owner's manual, they recommend you rejet leaner at higher altitudes. |
[topix.net] - High-altitude launch for Ducati Team at Madonna di Campiglio | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2013 10:50 PM |
[hell for leather] - 2011 Kawasaki ZX-10R: mo’ power, mo’ problems | Ninjette Newsbot | Motorcycling News | 0 | December 11th, 2010 04:10 PM |
Having power problems while running track speeds... | NorCal_250R | Ninjettes At Speed | 13 | July 20th, 2010 11:53 AM |
What are your high altitude experiences? | headshrink | General Motorcycling Discussion | 5 | July 5th, 2010 05:07 PM |
[motorcyclenews.com] - Yamaha R1-High Altitude | Ninjette Newsbot | Motorcycling News | 0 | August 8th, 2008 09:46 AM |
