Old December 3rd, 2011, 04:54 PM   #1
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
tachometer issues
so my tachometer has a strange issue and I was wondering if someone has an idea as to what the cause is. when I turn on my bike it doesn't do anything until about 10-30 seconds later at which poin t it seems like the right amount of revs are indicated. Also the fuel meter doesn't do anything until a few minutes have passed. Any ideas are much appreciated
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old December 3rd, 2011, 05:14 PM   #2
DaBlue1
DaBlue1's Avatar
http://www.ninjette.org/forums/showp...47&postcount=4
http://www.ninjette.org/wiki/Battery
Old December 4th, 2011, 07:44 AM   #3
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
When I start my bike, my tach won't start working until I rev it past 2500 rpms...from then on it works fine. If the bike starts and idles at 1200, the tach stays at 0 until I blip the throttle. Is this caused by the battery, or does the tach have an issue?
cbdallas is offline   Reply With Quote
Old December 4th, 2011, 09:23 AM   #4
Robinhood
Robinhood's Avatar
Motorcycle(s): 2008 Ninja 250, 2007 GSXR 600
I have the same problem, and figured that the tack needle is "sticky." Give it a smack, and it should work right away. I plan on opening mine up to lube it. I'll let you know how it goes.
Robinhood is offline   Reply With Quote
Old December 4th, 2011, 11:56 AM   #5
mine only does this when it's below 50 out. if the lubing helps, I'll look into doing that.
Old December 4th, 2011, 02:32 PM   #6
00NissanNinja
I hate driving...
Battery eh, I'll check it and make sure the connections are good and its holding proper charge. It is quite cold out here but last year I never had any issues with it even when I started it up in the 20's. Thanks guys
Old December 4th, 2011, 02:56 PM   #7
DaBlue1
DaBlue1's Avatar
The tach runs off electrical input from a sensor, so no lube is necessary. If checking and correcting issues with the battery does not resolve the problem, also check to make sure the crankshaft sensor connector is connected good. There is a possibility the tach could be bad, but rule everything else out first.
Old December 4th, 2011, 04:29 PM   #8
00NissanNinja
I hate driving...
I checked the battery and its holding its charge well (has a charge of 12.66V). Connectors were tight as well. I'll try cleaning up the crankshaft sensor connector with some electrical cleaner next see if that gets the tach working like it used to. I'll be tearing the bike apart next week so I'll just dig around until I find the issue.
Old July 11th, 2012, 05:08 PM   #9
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Did you ever open yours up? I'm having the exact same problem. Needle is stuck at 0 until I smack the gauge and then it works.
The www.ModMy250.com guy
Old July 11th, 2012, 05:38 PM   #10
startup is a rough time on the electrical system. it should not be an issue. cut the girl some slack when shes just waking up.
Old July 11th, 2012, 08:49 PM   #11
CThunder-blue
ModMy250.com
The tach didn't always behave this way. It's only happened recently within the last few months. I've ridden through some heavy down pours and I wonder if the mechanical part of the tach has begun to rust. I know the gauge is water proof, but I don't know if it's air tight, which I kind of doubt.
Old July 12th, 2012, 02:14 AM   #12
well its just a coil on an axle with a spring. you could spray some lube on it i guess? i would do a draw test on the battery
Tachometer problem Aman13 2008 - 2012 Ninja 250R Tech Talk 1 October 3rd, 2013 07:19 AM
light went out on tachometer... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 4 June 16th, 2012 09:36 PM
Inaccurate Tachometer ahoy11 2008 - 2012 Ninja 250R Tech Talk 14 May 2nd, 2012 08:43 AM
Tachometer fluctuation at stop and idle issues naturalphenomena 1986 - 2007 Ninja 250R Tech Talk 6 November 28th, 2011 12:24 PM
09 ninja tachometer kyle98927 2008 - 2012 Ninja 250R Tech Talk 9 June 30th, 2009 10:12 AM
