Old March 25th, 2019, 08:27 PM   #1
Ratboy14
Motorcycle(s): 2001 Ninja 250
Another ticking sound thread
Hey guys, new to the Kawasaki life and so far it’s been a ride.. so my girlfriend got her first bike (2001 ex250f) and we have slowly been bringing her to life. After a carb clean and oil change we got her to fire up for a few seconds but had to shut it off because of a loud ticking sound. I’ve tried to search for the problem but came up with many possible answers. Do you think it could be a bad CCT? I tried to clean it but the tensioner shaft does have some scratches so we ordered a new one.
The P/O stated the bike sat around 7 years so I’m wondering if this could have caused the timing chain to stretch?
https://www.youtube.com/watch?v=6nW1yTvwfkQ
Thanks!
Ratboy14 is offline   Reply With Quote
Old March 25th, 2019, 11:43 PM   #2
Hi, welcome to Ninjette!
Nah, sitting around won't do anything to metal.
I take it you've already changed coolant and oil? Filled to upper line on site glass?
Get yourself workshop manual and perform following service:
-:valve-clearance adjustment, use 1/4" torque-wrench to tighen lock-nut
- cam-timing, make sure both cams are timed correctly (all marks line up properly)
- install new CCT while you're there.
After above procedures been performed according to manual, engine will be smooth and quiet.
Old March 26th, 2019, 04:34 AM   #3
Ratboy14
Yeah we changed the oil and coolant, timing was ok but I have not had a chance for the valve check.. CCT should be here tomorrow so I plan on doing it then. Hope all goes well and I’ll update after I do it.
Thanks!!
Old March 26th, 2019, 06:12 AM   #4
dodgerdad
dodgerdad's Avatar
Wow, that's pretty loud. CCT would be my first suspect. Hope swapping it out takes care of it.
Old March 26th, 2019, 06:43 AM   #5
Ratboy14
I was messing with the bike before work and I noticed I can lift the cam chain up about 2-3mm off the intake cam which I am guessing is a good diagnosis for the CCT? I tried to back off the CCT bolts very slightly( bad I know )and let the tension out just to test it and it did not tension any better so I’m hoping it’s just that..
Old March 26th, 2019, 07:46 AM   #6
greg737
Motorcycle(s): -
The speed at which the "tick" occurs tells you where the problem is located:
If the ticking sound = indicated engine RPM it's coming from the crankshaft
If the ticking sound = 1/2 indicated engine RPM it's coming from the valves
If the ticking sound = less than 1/2 indicated engine RPM it's coming from the cam chain (maybe being made by a couple of rigid/seized links that make a noise each time they bump up and over the bottom edge of the rear cam chain tensioning guide)
A cheap "mechanic's stethoscope" from Harbor Freight is a good tool for narrowing down both the frequency of the noise and the location of the noise.
What is this sound? Is this what out-of-spec valves sound like? CZroe 2008 - 2012 Ninja 250R Tech Talk 24 November 15th, 2021 05:48 PM
2007 kawasaki ninja 250r ticking sound GixSixR1S3Ninj 1986 - 2007 Ninja 250R Tech Talk 30 July 5th, 2017 09:32 AM
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
ticking. awful, awful ticking... Insan3guy 1986 - 2007 Ninja 250R Tech Talk 6 March 25th, 2014 05:32 AM
Engine ticking sound Nosajong 2008 - 2012 Ninja 250R Tech Talk 4 May 21st, 2013 07:57 PM
