Old April 3rd, 2012, 08:39 AM   #1
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Measuring sag by yourself?
I want to set my preload properly, by measuring sag. I've done some homework and understand what preload adjustment actually does... that's not what this post is about, so please hold the advice on that front, thanks.
This is about getting a measurement if you don't have a willing assistant handy. I'm helper-challenged. Hard to round up anyone.
Conventional wisdom is to unload the suspension and measure it (easily done by putting a jack under the shock linkage while the front is up on a stand), then get on the the bike while wearing all your gear, have a helper stand it up while you assume the position and measure again. Sag is the difference between the two measurements.
Instead of using a helper, why can't I just put the bike on a track stand and hop on? Assuming I can figure out a way to get a measurement while on the bike, I can't think if any reason why this would not work.
Anyone?
Old April 3rd, 2012, 10:12 AM   #2
I think that's about it. If you can get around that issue, seems like you should be able to get a decent reading.
Old April 3rd, 2012, 10:33 AM   #3
adouglas
adouglas's Avatar
Thanks.
Somebody sells a device for this purpose, marketed to dirt bike riders. It's stupid-expensive.
I'm taking inspiration from it, though. I'm thinking of this:
1) Fasten a Sharpie under the tail, in a defined/stable/repeatable spot, facing outboard. Maybe tape it to a dowel and tie the dowel under the tail. Something like that.
2) Fasten a strip of wood or PVC pipe to the swing arm/axle in a defined/ stable/repeatable spot, with said strip/pipe extending vertically.
3) Unload the suspension, wiggle pipe/wood against sharpie to make a mark.
4) Get on the bike, bounce the suspension to settle it. Then reach around, grab the wood and wiggle it so the sharpie makes a second mark.
5) Measure.
Old April 3rd, 2012, 11:19 AM   #4
Wouldn't it be easier to offer a beer to the individual in the next-door cell to help out for a few moments?
Old April 3rd, 2012, 11:47 AM   #5
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
Werd. Beer is the universal currency.
kamikaze is offline   Reply With Quote
Old April 3rd, 2012, 01:25 PM   #6
cuong-nutz
cuong-nutz's Avatar
Sorry, I don't know where sag is measured at but couldn't you just put a zip tie around a fork and shock and measure the difference after it moves?
HalfFast Racing Team
Old April 3rd, 2012, 01:29 PM   #7
adouglas
adouglas's Avatar
If the rear suspension had forks then sure.....
In fact the zip tie trick is exactly what I intend to do for the front, since I've just ordered a set of preload adjusters.
The problem as I see it is that just sitting on the bike doesn't quite give you an accurate reading. You have to bounce the suspension and let it settle. That will make the zip tie move beyond where it winds up. If I can't find anyone to help it'll have to do, I guess.
Old April 3rd, 2012, 03:10 PM   #8
use one of those locking tape measures. set the lock half-way on and secure the base to the ground. position it so the tail pushes down on the end of the tape measure (the rear passenger peg is good for this), but cant pull on it. sit on the bike. get off bike. observe reading.
if you need to bounce your shock to get an accurate sag reading (if going down vs going up is more than 5mm difference) then your fluid needs changing or your valving is clogged.
Old April 3rd, 2012, 03:19 PM   #9
adouglas
adouglas's Avatar
Brilliant!
Old April 3rd, 2012, 05:10 PM   #10
duckracer
duckracer's Avatar
Motorcycle(s): Ducati 1098 and 04 Ninja 250 race bikes
For the front I just use the old tie wrap trick, hell I never even remove the tie wrap! For the rear when no help is around I use a dowel taped vertical to the tail section. Loosely tie wrap the bottom end of the dowel to the track stand leg so it can slide, but not too loose. Then take a second tie wrap and put it loosely on the dowel even with the top of the tie wrap on the track stand. Then with all your gear either worn, or setting on the tank sit on the bike. the lower tie wrap will push the upper tie wrap up. get off the bike and remove all the gear. now just like the forks you measure the gap between the two tie wraps and that is your sag.
duckracer is offline   Reply With Quote
Measuring valves Nemesis 2008 - 2012 Ninja 250R Tech Talk 75 August 4th, 2019 06:59 AM
Need measuring help: im in Thailand baz666 1986 - 2007 Ninja 250R Tech Talk 5 February 21st, 2014 08:18 PM
[crash.net - MotoGP] - Gresini CRT 'measuring up' after just a few hours Ninjette Newsbot Motorcycling News 0 March 24th, 2012 03:10 AM
Measuring tire pressure when tires are hot... Mr.E 2008 - 2012 Ninja 250R Tech Talk 10 January 22nd, 2012 05:17 PM
[superbikeplanet.com] - Ducati's Measuring Stick Ninjette Newsbot Motorcycling News 0 October 20th, 2011 04:30 AM
