May 30th, 2012, 12:47 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): 2008 Kawi Ninja 250R, 2013 Honda CRF450R, 2008 Honda CRF250R, 2001 Honda XR400 Posts: 301
Couple bolts (Fairing/body pieces and windshield)
Sup guys!
Looking for two fairing bolts. Specifically, the top ones by the gas tank (if that even matters). I also need their little rubber washer thing. I'm also looking for something, but don't know what it is. I swapped my windshield to an aftermarket one. When I went to screw in the bolts, the top two went in fine. The bottom ones won't. There is literally nothing for them to screw in to. So, I need whatever it is I lost....maybe little nuts? I dunno. Help me out here. The last thing is for under the passenger seat. If you take off the passenger seat, there are two bolts holding on the rear body pieces. One of those bolts are missing. I can get a picture if needed. Hit me up!!! |
May 30th, 2012, 01:04 PM | #2 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
I highly recommend sportbikebolts.com. You can't buy individual bolts, but their complete kits are very reasonably priced. They also sell the very-hard-to-find rubber well nuts.
I went this route after finding that the hardware stores don't have bolts exactly like the Kawasaki OEM, and they don't have anything comparable to the rubber well nuts. Another option is places like cheapcycleparts.com where you can order exactly the parts you need. On the windshield bolts..I believe there are little black nuts that fit in the holes in the fairing, and they fall out as soon as you remove the bolts. They're probably resting down inside the fairing near where the windshield mounts. |
May 30th, 2012, 01:29 PM | #3 |
Sweet, thanks man!
June 10th, 2012, 04:18 PM | #4 | |
Those two on the exterior of the windscreen have a different part number. For shame, Kawasaki. This means you knew about the bad rubber problem (also affected my trip meter reset, shift pedal boot, clutch cable boot, and more). |
