June 19th, 2008, 04:45 AM | #1 |
[motorcyclistonline] - 2008 Overland Motorcycles Terra Mostro 695 - First Ride
The Terra Mostro is not the first Ducati-based dual-sport motorcycle. There were single-cylinder Scramblers in the mid-'60s and V-twin powered Elefants 20 years later. The Terra Mostro story actually begins with the Elefant. Overland Motorcycles President Blaine Dehmlow has owned six such machines over the years, and absolutely loved the booming V-twin's abilities both on road and off. So when Dehmlow set out to construct his version of the ultimate dual-sport, he started with his favored Desmodue motor and worked from there. Now he's ready to sell you one, too. Working together with partner Kent Harle, the duo built the first Terra Mostro (Italian for "Dirt Monster") prototype in 2006 from a salvage Ducati M750 and a pile of Triumph, Husaberg, Cagiva, Honda and KTM parts-"more Mad Max than Massimo Tamburini," Dehmlow says. The bike worked, though, and over the next two years the pair spent thousands of miles refining their creation. Now they have begun production as far from Bologna as you can get, in Brentwood, California. We sampled Terra Mostro #4 on the roads and trails of Marin County, high above San Francisco's Golden Gate Bridge. This was the first regular production bike, based on a brand-new 695 Monster and retaining the Ducati chassis, engine, EFI, fuel tank, headlamp, dash and wiring loom. Overland adds a longer, extruded-aluminum swingarm (stretching the wheelbase from 56.7 to 60.5 inches), longer-travel suspension front and rear (over 8 inches at both ends), 21-inch front/18-inch rear wheels and various other aftermarket dirt bits, including an Acerbis front fender and enduro bars and triple clamps from Applied Concepts. The Terra Mostro is quite a bit heavier than the stock 695 Monster (a claimed 395 lbs. dry, compared to 370 lbs. stock), though the front/rear weight bias is an acceptable 48/52 percent. Most of the extra pounds come from the heavy-duty wheels that consist of Takasago Excel alloy rims laced with heavy-duty stainless spokes to Grimeca hubs. It's not too much trouble for an average-sized rider to throw a leg over the 35-inch-high Ducati Performance seat, and a wide, tapered-aluminum handlebar contributes to a very comfortable cockpit. Generous, 11.25-inch ground clearance allowed Overland to reposition the rearsets lower and farther forward for a more enduro-style stance that further increases control. Though the chassis is completely reconfigured, the 695cc Desmodue engine is mostly as Ducati intended, except for the custom Bassani high-rise headers, DMC silencer (with a USFS-approved spark arrester) and a Dynojet Power Commander remapped to suit. Lower overall gearing (14/48 teeth) further enhances power delivery compared to the notoriously overgeared stocker (15/42). A broad, easy-revving power spread makes the engine relaxing on the road and easy to control on the trail. The Terra Mostro is surprisingly sure-footed in the dirt, where light, precise handling and smooth power delivery make this a great ride, especially for inexperienced off-roaders. The dirtbike-inspired chassis geometry makes it easy to stay on track, the long-travel suspension is plush and forgiving and the IRC Trail Winner dual-sport tires give unexpectedly good grip on all surfaces. The single, 300mm Brembo front disc brake retained from the original Monster could do with more aggressive pads-you won't risk locking the front wheel in a panic street stop, but it also won't catch you out in the dirt. The smaller, 245mm rear disc actually has more bite than the front, which is as it should be off-road. We were less than impressed with the Ducati APTC (Adler Power Torque Clutch). This wet, slipper-type clutch offers very light but somewhat unpredictable action, engaging only at the very end of the lever travel. This abrupt, grabby action made it hard to smoothly pull away from a stop, but this was hardly Overland's fault. The Terra Mostro is sold exclusively over the company's website, for $16,590-a considerable increase over the Monster 695's $7995, but a relative bargain when you consider the effort it would take to build your own. Dehmlow says he is considering making a kit so customers can convert their own Monsters, as well as a 19-inch front wheel option for riders who spend more miles on pavement. Overland is also pondering development of a second, two-passenger dual-sport, tentatively dubbed the Telluride and based on the GT1000 Sport Classic. That will wait for the future, however, as demand for Terra Mostros is presently occupying all their time. Ten bikes have been delivered to date, and the company is now building the next 25. Sounds like Dehmlow wasn't the only one who wanted a proper Ducati dual-sport. Tech Spec Evolution Ducati's baby Monster if it were raised by wolves. Rivals Aprilia's RXV550 is the only other mid-sized, dual-sport V-twin we're aware of. TECH Price $16,590 Engine type a-c 90-deg. V-twin Valve train SOHC, 4v Displacement 695cc Bore x stroke 88.0 x 57.2mm Compression 10.5:1 Fuel system Marelli EFI Clutch Wet, multi-plate Transmission 6-speed Claimed horsepower 73.0 bhp @ 8500 rpm Claimed torque 44.9 lb.-ft. @ 6750 rpm Frame Tubular-steel trellis Front suspension 46mm Kayaba fork adjustable for spring preload, compression and rebound damping Rear suspension Single Wilbers shock adjustable for spring preload, compression and rebound damping Front brake Single Brembo two-piston caliper, 300mm disc Rear brake Single Brembo two-piston caliper, 245mm disc Front tire 80/100-21 IRC Trail Winner GP-110 Rear tire 110/100-18 IRC Trail Winner GP-110 Rake/trail 26.0/na Seat height 35.0 in. Wheelbase 60.5 in. Fuel capacity 3.6 gal. Claimed dry weight 395 lbs. Colors Black/black, black/red Available Now Warranty 24 mo., unlimited mi. Contact: Overland Motorcycles 413 Amber Leaf Way Brentwood, CA 94513 877.667.8761http://www.terramostro.com Verdict A little heavy but surprisingly effective off-road. Why doesn't Ducati build this already? Photo Gallery: 2008 Overland Motorcycles Terra Mostro 695 - First Ride - Motorcyclist Magazine Online Read More | Digg It | Add to del.icio.us Click here for full story...
[motorcyclistonline] - Husqvarna TR650 Terra vs. Kawasaki KLR650 vs. KTM 690 Enduro R | Ninjette Newsbot | Motorcycling News | 0 | May 13th, 2013 06:10 AM |
[motorcyclistonline] - Fly Racing Terra Trek Jacket | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | May 8th, 2012 11:50 PM |
[motorcyclistonline] - Fly Racing Terra Trek Jacket | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | February 9th, 2012 01:40 PM |
[motorcyclistonline] - Terra Modena Supermoto - Terra Modena 198 - Future Rides | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2008 04:53 AM |
[motorcyclistonline.com - first rides] - 2008 Overland Motorcycles Terra Mostro 695 - | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2008 01:06 PM |
