Old April 21st, 2009, 10:30 AM   #1
hzrnbgy
hzrnbgy's Avatar
Motorcycle(s): 2009 Black Ninja 250R, 2004 Yellow Ninja 250R
HMF slip on misalignment
i recently installed an HMF slip on and i can't seem to align the muffler and the foot peg arm for proper installation... it is off for a good inch or so and no rotating of the muffler can fix it. The one shown on their web site is for ninja 250r 2008 model and i have a 2009 but i ordered it anyway as I was told its basically the same bike.
as for now, the muffler is held by the clamp located on the header. I am worried that too much vibration might cause it to slip and fall off
hzrnbgy is offline   Reply With Quote
Old April 21st, 2009, 09:20 PM   #2
Sound Wave
Ramen Rider
Sound Wave's Avatar
hmm... looked up their instructions... kind of junk instructions, huh? no pics either.
http://hmfracing.com/files/exhausts/...general133.pdf
although, looking at the pic on their website, you don't have the bracket that goes around the muffler like the one in the pic. although... the end caps look different. is it possible you forgot to put yours on? or they forgot to give you one? http://hmfracing.com/files/exhausts/275/kninja250.jpg
Old April 22nd, 2009, 12:00 AM   #3
hzrnbgy
hzrnbgy's Avatar
i have the vector end cap, the one on their web page is the euro end cap
i have the bracket that goes around the muffler. its the one causing me problem as i can't seem to align the hole for the bolts to go in when its wrap around the muffler
if you look at the picture above, the two red lines should be parallel in order for me to wrap the thing and insert the bolt between. but theyre not. ive tried rotating the muffler and it seems that im still off like an inch or so between centers (for bolts)
Old April 22nd, 2009, 12:13 AM   #4
Sound Wave
Ramen Rider
Sound Wave's Avatar
your set up looks different from this guys one. it seems like he used that center pipe section. is that the same kit as yours?
http://www.newninja.com/modification...ew-(picsvids)/
i don't know. just throwing out crap at this point. i have no idea. lol. but assuming that you and he have the same kit, his is a lot higher up above the tire than yours is. i gotta say that i like the height of yours better though.
edit: gotta say though... based on his videos, that is the best sounding exhaust i heard for the 250 yet.
Old April 22nd, 2009, 12:15 AM   #5
when you installed the system, did you loosely fit all of it on there first or just start tightening from the front to the back and now you're finding out the back is off?
have you read the DIY for the area P quiet core I installed? I know they are different, but actually, it's all mounted the same way.
Old April 22nd, 2009, 01:41 AM   #6
hzrnbgy
hzrnbgy's Avatar
it should be the same kit. the center pipe is just the heat shield but mine doesnt come with one (they must have forgotten it). I noticed it too that his is way higher than mine.
the installation was quite terrible, i have to cut between the pipe to open it up as it will not fit initially on the header no matter how i push it. nonetheless, connection between header and muffler is perfect (end pipes are flushed with each other). i assume thats how its supposed to be. but then when i try to install the clamp/holder, the bolt centers wouldnt align. i tried rotating the muffler but that didnt help. i do notice that the guy from the other site setup is higher than mine.
as for now, only the clamp between pipe and header is preventing the pipe from slipping. i made sure its damn tight so as it will not fall off in the middle of nowhere. I checked it to on every stop light to make sure it didnt move.
Old April 22nd, 2009, 01:49 AM   #7
have you tried talking to the people who you bought it from to see if they can help?
Old April 22nd, 2009, 02:10 AM   #8
hzrnbgy
hzrnbgy's Avatar
i sent them an email already but i havent got any replies yet
Old April 22nd, 2009, 08:01 AM   #9
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
looks like the piece that fits over the stock header is different than the one posted on the other site review.
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods
Cali619 is offline   Reply With Quote
Old April 22nd, 2009, 08:12 PM   #10
bikermunda
Ninja World YAY
well i am very curious to know how this goes because i am looking into buying the same one
bikermunda is offline   Reply With Quote
Old April 22nd, 2009, 10:56 PM   #11
hzrnbgy
hzrnbgy's Avatar
installation is a major PITA! thats for sure
performance wise, you wont be disappointed. im feeling like 5-7% increase in torque and power. didnt do any re-jetting or shimming yet so that may still go up. i can actually "twist" the throttle now
Old April 24th, 2009, 05:51 PM   #12
250RBond
250RBond's Avatar
Motorcycle(s): 2008 250r ninja
Have you got an reply back from them. I'm having the same issues with mine
Called them at motorworldonline they asked me to seed them pictures then they will see what they can do.
250RBond is offline   Reply With Quote
Old April 25th, 2009, 01:51 AM   #13
hzrnbgy
hzrnbgy's Avatar
not yet
not only that, im missing the heat shield too.
oh well, thank god the performance is top notch or ill be over their a** really bad
Old April 25th, 2009, 10:18 AM   #14
how are you measuring that... with a butt dyno or do they actually have a dyno chart of the results on their website?
Old April 25th, 2009, 11:05 AM   #15
hzrnbgy
hzrnbgy's Avatar
just a thing im feeling i guess. i cant be sure about the numbers but definitely there are some improvements
by the way, im hearing some popping sounds from the exhaust whenever i release the throttle abruptly from high rpms. does that mean im running lean now? i think i should shim the needles ASAP
ill check back later, geading for work
Old April 25th, 2009, 11:08 AM   #16
yes, you should shim the needles for more low and midrange power. To get rid of the popping, you need to do the Kleen air delete.
Old April 28th, 2009, 03:48 PM   #17
bounceya
Motorcycle(s): 2008 kawasaki ninja 250r
I have the same slip on,what a pain in the butt to slide on.It took forever to get it on. Leave it loose till you get the clamp on.I had to muscle it a little bit.
bounceya is offline   Reply With Quote
Old April 28th, 2009, 03:50 PM   #18
bounceya
Oh yea,shim it,what a difference.
Old April 28th, 2009, 05:53 PM   #19
hzrnbgy
hzrnbgy's Avatar
ive been meaning to shim it but i cant find time. i usually do my mods late at night (9pm onwards)
is it fairly easy to take off the gas tank? im pretty good with the side fairings already
and where do i get those 4mm (#4 washers)?
Old April 28th, 2009, 08:02 PM   #20
Sound Wave
Ramen Rider
Sound Wave's Avatar
yeah, like i was telling you, it is REALLY easy to take off the gas tank. the most complicated part, which is still easy, is taking off the carb needle covers. it is easy to strip those screws if you are not careful.
the washers... i found them at radio shack. they sell it as an assortment of 100. i think 20 of them are #4's. city mill and home depot didn't have them. i didn't check lowe's since it isn't really close to my house. since it is by you, maybe you could check there first.
oh, and they are #4. not 4 mm. big difference. if anything, they are 3 mm.
Old April 29th, 2009, 01:26 AM   #21
bounceya
I bought #3 and #4s,the #4s were to big.I got em at a hobbie shop .
Old April 29th, 2009, 01:43 AM   #22
Sound Wave
Ramen Rider
Sound Wave's Avatar
i think you are confusing #3 and #4 with 3mm and 4mm. it is confusing and it is a common error. if the whole world just switched over to inches, miles, gallons, pounds, etc, it would make everything so much easier.
we need to use the #4 washers which are basically 3mm.
Old April 29th, 2009, 02:04 AM   #23
bounceya
Maybe that explains the big size difference in the washers.The 3mm fit perfect.The #4s he gave me were way too big.
Old April 29th, 2009, 02:14 AM   #24
Sound Wave
Ramen Rider
Sound Wave's Avatar
maybe he himself got confused and when you asked for #4 washers, he gave you 4 mm washers instead? idk.
because #4 washers are the correct one.
Old April 29th, 2009, 11:59 AM   #25
250RBond
250RBond's Avatar
Did yours come with a mid pipe?
Old April 29th, 2009, 03:41 PM   #26
bounceya
no it did'nt
Old April 29th, 2009, 06:23 PM   #27
250RBond
250RBond's Avatar
Here is mine
Old April 29th, 2009, 06:25 PM   #28
hzrnbgy
hzrnbgy's Avatar
mine wouldnt even align to the bolt
im relying on the clamp for now to hold the slip on in place
Old April 29th, 2009, 06:41 PM   #29
250RBond
250RBond's Avatar
Im doing the same
Old April 29th, 2009, 10:53 PM   #30
bikermunda
Ninja World YAY
hey i have a question for you guys ?
how is the performance of the bike with the slip on ? and also how is sound of the exhaust i hope it does not sound very loud where it gets a little annoying ?
Old April 30th, 2009, 12:33 AM   #31
hzrnbgy
hzrnbgy's Avatar
its pretty loud (deep throaty sound)
i have a simple video clip to show the sound
click here for sample
as for performance, im feeling about 5%-8% improvement over stock using my dyno butt
Last futzed with by hzrnbgy; April 30th, 2009 at 12:35 AM. Reason: url
Old April 30th, 2009, 10:58 AM   #32
250RBond
250RBond's Avatar
I don't feel any dead spots and it's a deep throaty
oh and i did not do any shiming
Old May 15th, 2009, 05:15 PM   #33
bounceya
Here is mine
Mine is about 4 inches from the beginning of the slip on, i had no problem with the clamp But i just looked at mine it looks like its on a different angle than yours.
Old July 12th, 2010, 05:39 PM   #34
reaper1281
did you get a new band for the exhaust or are you sticking with it as is?
reaper1281 is offline   Reply With Quote
New HMF Exhaust slip/on & Carb. question Wicked808 2008 - 2012 Ninja 250R Tech Talk 12 March 1st, 2012 02:03 AM
HMF Slip On Exhaust adri99an Videos 35 April 20th, 2011 10:52 AM
HMF Slip-on Raos Videos 1 December 1st, 2010 09:41 PM
WTB: 2bros,HMF,yoshi, or any slip on for 09 250r NinjaSmallz Items Wanted 1 March 20th, 2010 04:13 PM
