Old September 23rd, 2018, 10:07 AM   #1
rustyshackelford
Should there be a hole in the airbox?
Should this be here? it's hard to tell but it does go all the way through and doesn't look like it was drilled or chipped off or anything. Also, it is upstream of the air filter (side with unfiltered air coming in).
If not I am going to plug it with some epoxy I guess.
rustyshackelford is offline   Reply With Quote
Old September 23rd, 2018, 10:25 AM   #2
They all have it. It's been a while, but I seem to remember that it doesn't let air into the downstream side of the filter, so it causes no problem.
Next time try to post a really big photo.
Old September 23rd, 2018, 10:28 AM   #3
rustyshackelford
Haha I just wanted to make sure you could see every individual molecule of plastic.
But thank you I will leave it be then.
Old September 23rd, 2018, 12:02 PM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Could be a liquid drain .
Worlds fastest 250 ninja
Old September 23rd, 2018, 02:49 PM   #5
rustyshackelford
That's what I was thinking.
Old September 23rd, 2018, 05:45 PM   #6
It’s a screw hole for screw that holds two halves of airbox together. Scrape the broken plastic bits away and you can see way down. Count screws, there should 12 of them.
Old September 23rd, 2018, 05:55 PM   #7
rustyshackelford
I don't think so all screws are accounted for plus it's on the opposite side of the screws
Old September 23rd, 2018, 09:54 PM   #8
My money is on liquid drain on the upstream side of the filter.
Small hole in airbox -- how to seal it? Cra1g 1986 - 2007 Ninja 250R Tech Talk 13 May 13th, 2017 10:28 AM
Round front hole on airbox? baz666 1986 - 2007 Ninja 250R Tech Talk 7 March 23rd, 2014 03:21 PM
I'm an a**hole... BlueHairSar Pictures 24 February 11th, 2014 07:38 AM
Is this supposed to be here? (hole in pregen airbox) Insan3guy 1986 - 2007 Ninja 250R Tech Talk 10 July 15th, 2013 04:34 PM
What is this hole..?? davenay67 1986 - 2007 Ninja 250R Tech Talk 14 May 3rd, 2012 06:47 AM
