Old May 16th, 2012, 08:02 PM   #1
x only performance
x only performance's Avatar
Trouble Shooting a couple things
So my bike has a hesitation when i give it throttle...doesnt matter the rpms...also it feels like its vibrating with the rpms...anyone have any clue for these issues?
x only performance is offline   Reply With Quote
Old May 16th, 2012, 09:07 PM   #2
cuong-nutz
cuong-nutz's Avatar
What's your idle set at? Is bike fully warmed up? Has the bike been sitting for a few weeks to a month? How many miles does it have? Air filter, spark plugs?
HalfFast Racing Team
Old May 16th, 2012, 10:31 PM   #3
x only performance
idle-1700
bike-warm and ridden every other day or so
miles- close to 9000
air filter- clean
spark plugs- unknown
Old May 16th, 2012, 11:11 PM   #4
cuong-nutz
cuong-nutz's Avatar
Are you the original owner? Might be that if you are not the original owner let the. Ike sit for some time and your carbs are dirty and could use some cleaning. Have the needles in it been shimmed? your spark plugs will tell you how your engine has been running by its color.
Old May 16th, 2012, 11:56 PM   #5
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
idling at 1700 seems a little high no? carbs in sync?
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Old May 17th, 2012, 12:41 AM   #6
cuong-nutz
cuong-nutz's Avatar
Don't know how I missed that. Highest it should be idling at is 1500. Factory is about 1300. I have mine set at 1500.
Old May 17th, 2012, 09:28 AM   #7
x only performance
Lightbulb
So far I've got that I need to:
Check spark plugs
Sync Carbs
Adjust my idle to 1300-1500 range
Clean Carbs
I noticed that I didn't put in there that I have the Hotbodies MGP Growler Slip-on...Would that have anything to do with it.
Old May 17th, 2012, 11:56 AM   #8
first make sure you dont have a tight spot in the chain then check valves then sync carbs.
Old May 17th, 2012, 06:45 PM   #9
edxmon
edxmon's Avatar
well, valve checking in pretty involved. Shouldn't he check off the simplest of things before ripping the valve cover off?
Old May 17th, 2012, 11:54 PM   #10
x only performance
i really like that idea
Old May 18th, 2012, 12:50 AM   #11
no
Old May 18th, 2012, 03:48 AM   #12
edxmon
edxmon's Avatar
no
ok
In that case...
make sure to rebuild your transmission and install a new clutch while your at it, it'll make alex happy
[kropotkin thinks...] - Things To Do At Indy - There's A Lot Of Things To Do At Indy, Ninjette Newsbot Motorcycling News 0 August 14th, 2013 05:50 PM
Really Weird carb Issue need more trouble shooting ideas Virustech 1986 - 2007 Ninja 250R Tech Talk 11 September 24th, 2012 06:35 PM
a couple things I gotta have beqwarrior 2008 - 2012 Ninja 250R Tech Talk 6 February 11th, 2012 11:09 AM
Trouble-shooting Autoswitch/GD opener headshrink 2008 - 2012 Ninja 250R Tech Talk 11 September 8th, 2011 09:12 PM
Did a couple things today Tofergstaff 2008 - 2012 Ninja 250R Farkles 6 August 16th, 2010 06:08 PM
