Old October 5th, 2012, 07:56 PM   #1
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
Question Tire Cupping/Feathering
I've noticed that my front tire, with about 5000 miles is showing signs of fethering/cupping. I'm soliciting opinions, facts, speculation on the cause and cure...
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Old October 5th, 2012, 08:04 PM   #2
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
What tire is it? I've heard some people have this problem with BT-45s.
Old October 5th, 2012, 11:09 PM   #3
cuong-nutz
cuong-nutz's Avatar
Have you been monitoring your pressure on a regular basis? low tire pressure can cause uneven wear.
HalfFast Racing Team
Old October 5th, 2012, 11:47 PM   #4
DaBlue1
DaBlue1's Avatar
Cupping, which is more accurately described as scalloping , is a natural wear pattern on motorcycle tires and it will always follow the tread pattern. It is not a sign that you have bad suspension parts. It merely shows that your tire is indeed gripping the road when you make turns.
Cupping develops within the side wear bands of a leaned motorcycle. The extreme forces that come in to play when the bike is leaned in a turn are what produce the effect and when the wear becomes sufficient, one will experience vibration and noise when one banks into a turn.
The leading edge of the tread does not flex much as it grips the road and the rubber is scuffed off the tire in that area causing a depression. As the tire rotates, the pressure moves to the trailing edge of the tread pattern where the tread flexes more causing less scuffing so less material is ground off the tire. The more complex the tread pattern, the more complex the cupping pattern will be. The softer the compound of the tire, the sooner this cupping will develop. Radial tires are more prone to cupping than are bias ply because the compound of radials is softer.
Low tire pressure will exacerbate this wear pattern and you will lose many serviceable miles by running low pressures. Improper balance has nothing to do with cupping on a motorcycle tire. Improper balance will merely cause your bike to vibrate within certain specific speed ranges.
You may even notice more wear on the left side of the tire because, you ride farther (and likely faster) turning left than turning right with subsequent increased side tread wear on the tire's left side. The left side of your tire has more miles on it (in some extreme cases, twice as many) than the right side of your tire. And the side of your tire only gets mileage when you are leaned in a turn.
[roadracingworld.com] - Chicken Hawk Racing Tire Warmers To Be The Official Tire Warm Ninjette Newsbot Motorcycling News 0 May 21st, 2014 11:40 AM
[roadracingworld.com] - Dunlop/Race Tire Service Announces Tire Availability For CCS Ninjette Newsbot Motorcycling News 0 October 9th, 2013 10:50 AM
[roadracingworld.com] - More From Sport Tire Services On Losing Its Dunlop Race Tire Ninjette Newsbot Motorcycling News 0 January 12th, 2011 04:20 PM
[roadracingworld.com] - Sport Tire Services Loses Western U.S. Dunlop Racing Tire Dis Ninjette Newsbot Motorcycling News 0 January 12th, 2011 11:10 AM
[roadracingworld.com] - Sport Tire Services Announces New Dunlop Race Tire Distributo Ninjette Newsbot Motorcycling News 0 February 6th, 2009 02:40 PM
