Old August 5th, 2009, 08:18 AM   #1
TheAmazingKickstand
Motorcycle(s): yellow ninjette
I Dropped my feeler gauge down into the Engine!!!!!!
Hey all. This is my first post.
I jsut got the little ninja for screaming up and down the Santa Cruz mountains without getting speeding tickets.
Anyway, brought it home ot do a valve adjustment. While doing the last valve Idropped my feler guage down the cam chain area. It went all the way down. I couldn't get with a magnet from the top and i cant get it with the magnet through oil strainer hole.
Is there anything else I can do? Do I have to drop the motor and split the case? Can I get the the bottom of the timing chain anyother way?
Any other Ideas?
Thanks.
TheAmazingKickstand is offline   Reply With Quote
Old August 5th, 2009, 09:55 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
Pull the clutch cover off, should be sitting in there.
Old August 5th, 2009, 11:32 AM   #3
http://www.kawiforums.com/ninja-250r...to-engine.html
Old August 5th, 2009, 11:51 AM   #4
TheAmazingKickstand
Thanks guys....that link is exactly what I did. We even have the same feeler guages.
Off to take the clutch cover off.
To split the case, do I have to take the motor out or can I just unbolt the bottom engine mounting bolt?
Old August 5th, 2009, 11:55 AM   #5
Mike, you have a PM.
Old August 5th, 2009, 12:19 PM   #6
HKr1
IC2(SW)
HKr1's Avatar
You would have to pull the motor to split the case.
Long as you didnt drop the feeler gauge on the cam tensioner side, you should find it behind the clutch cover.
Old August 5th, 2009, 12:27 PM   #7
TheAmazingKickstand
hmmm....now the clutch cover is stuck on.
It's sort of loose but wont come off....
Old August 5th, 2009, 01:35 PM   #8
HKr1
IC2(SW)
HKr1's Avatar
^ is the clutch cable off?
Old August 5th, 2009, 01:53 PM   #9
TheAmazingKickstand
got the cover off.....looked every where and every which way i could with magnets.
Still no feeler guage =(
Old August 5th, 2009, 03:26 PM   #10
HKr1
IC2(SW)
HKr1's Avatar
Thats not good..........
Did it fall between the cam gears, or down alongside the chain?
Old August 5th, 2009, 04:16 PM   #11
TheAmazingKickstand
I though it fell along the chain towards the front of the motor because I saw it stuck in the chain closest to the front. When it went for the magnet, thats when it fell down.
I was thinking it got stuck somewhere along the chain guide but it doesnt look like it so far.
where else could it be?
Old August 5th, 2009, 04:32 PM   #12
HKr1
IC2(SW)
HKr1's Avatar
Do you have a small mirror, like an inspection mirror? So you can kinda see down in there. If it would have fell down the middle, its a staight shot down. Sounds like it might have got caught up in a chain guide.
Old August 5th, 2009, 05:38 PM   #13
TheAmazingKickstand
Im really hoping its somewhere in the chain guide because thats where it was stuck in the first place.
I really dont want to pull the motor.....or more importantly, I dont wnat to pull the motor only to see that it was somwehre up top.
Im thinking of taking off the cams to ge the chain super loose.....
Old August 6th, 2009, 09:59 AM   #14
TheAmazingKickstand
So is it possible its in the oil pan? Is this engine coming out? =(
Old August 6th, 2009, 10:28 AM   #15
HKr1
IC2(SW)
HKr1's Avatar
Think the oil drain back into the case is behind the clutch basket. Has to be in the chain area. No way to look down in there(mirror)??????
Old August 6th, 2009, 03:21 PM   #16
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
sorry to hear that , if it makes ya feel better i allmost lost a nut that fell off my feeler gauge set.
QTRltrPWR
nate-bama is offline   Reply With Quote
Old August 7th, 2009, 02:05 PM   #17
TheAmazingKickstand
Guys, I think Im really ****ed on this one.
I cant find it all. Im going to take the cams off so that I can move the timing chain around. If its not there it has to be in the oil pan right?
I really don;t want to split the case cuz this bike only has 700 miles on it.
If I knew id have to take out the motor, I wouldve bought a dead ninja for $300 =(
I feel so dumb. Ive assmembled at least 30 VW and porsche motors from scratch with out a hitch. Now I do something as stupid as this.
Im kinda worried cuz I work SUPER full time so I don;t have too much time to pull and disassemble engines....
sad ninja owner....
If I can find it in the timing chain area Im really thinking of buying a used engine to drop in until I have stress free time to dissasemble this one and find that stupid guage.
Im not too confident on setting the timing on overhead cams....does anyone have detailed instructipons on how to instal a timing chain?
If youre in San Francisco, youre more than welcome to come over and do it. Ill feed you and get you super drunk .
Thanks,
Mike
Old August 7th, 2009, 03:46 PM   #18
HKr1
IC2(SW)
HKr1's Avatar
Sucks to hear!
Iam hungry and thirsty, but too far away.... If you built other motors, shouldnt be a problem for you. Dont have a manual on the older model. Think its just setting to 2TDC with the mark, the cam gears are marked(lined up with the flat part on the head/vc), remove the cam tensioner, then the cams. You could mark the chain at all three gears to be safe. The bolt on the cam tensioner comes off and you back out the actuator < you have to hold it in place with a pin or plate depending on what it is for install.
Good luck!
Think theres a DIY for the new model, since the cams have to come out for valve adjust. It might help?
Old August 7th, 2009, 04:04 PM   #19
dunno if it will help, but here's the new gen cam removal DIY Kerry was talking about.
http://www.ninjette.org/forums/showthread.php?t=9924
[motorcyclistonline] - Real Mechanics Have a Built-In Feeler Gauge | BEHIND BARS Ninjette Newsbot Motorcycling News 0 March 23rd, 2015 04:40 PM
Help! Dropped socket into engine... CmichRider 1986 - 2007 Ninja 250R Tech Talk 3 July 19th, 2011 03:55 PM
Engine Oil Gauge gophurr 2008 - 2012 Ninja 250R Tech Talk 14 June 12th, 2010 01:37 PM
