December 21st, 2023, 10:12 AM | #1 |
[ridermagazine.com] - 2024 Yamaha Ténéré 700 Review | Rider Test
When the Yamaha Ténéré 700 was introduced in the summer of 2020, it was a rare bright spot during the dark time of lockdowns, masks, and toilet paper shortages. It was a new entry in the middleweight adventure bike class, slotting between Yamaha’s WR250R and 1,200cc Super Ténéré. Unlike midsized ADV models from BMW, KTM, […]
The post 2024 Yamaha Ténéré 700 Review | Rider Test appeared first on Rider Magazine. What makes the Yamaha Ténéré 700 such a well-rounded bike is its capability on any surface. (Photos by Kevin Wing) When the Yamaha Ténéré 700 was introduced in the summer of 2020, it was a rare bright spot during the dark time of lockdowns, masks, and toilet paper shortages. It was a new entry in the middleweight adventure bike class, slotting between Yamaha’s WR250R and 1,200cc Super Ténéré. Unlike midsized ADV models from BMW, KTM, and Triumph, Yamaha took a “less is more” approach with the Ténéré 700 – aka the T7 – eschewing electronic rider aids and other costly features and pricing it well below the competition at $9,999. Contributing photographer Kevin Wing attended the T7’s debut in Tennessee, and he took a shine to it. “As someone who spends most of his time on lightweight dirtbikes without any electronic interventions, I felt immediately comfortable on the Ténéré 700 with its light clutch, smooth shifting, and excellent fueling,” he wrote in his test for the August 2020 issue (see Wing’s 2021 Yamaha Ténéré 700 review here). With test rider Thad Wolff at the controls, the Yamaha Ténéré 700 easily jumps tall berms in a single bound. Few adventure bikes are as capable off-road as the tenacious T7. When long-time contributor and dual-sport aficionado Arden Kysley got his hands on our Ténéré 700 test bike in California that same year, he added some factory luggage and other accessories and hit the road for 3,000 miles. “In my local mountains or out in the desert, the T7 has been an excellent partner for exploration, corner carving, and flat-out movin’ down the road,” he wrote in his 2021 tour test review. Kysely liked the T7 so much, he sold his 2009 BMW F 800 GS – which had 65,000 adventure-heavy miles on its odometer – and bought our test bike from Yamaha. Consistent with the no-frills theme of the original, when Yamaha updated the Ténéré 700 for 2024, it didn’t go overboard. The monochrome LCD screen, which Wing and Kysely said required too much scrolling to access key info and was rendered useless when powdered with trail dust, has been replaced with a 5-inch color TFT display with smartphone connectivity. Like the old screen, the new one has a rally-style vertical orientation, and it now has two display modes: Explorer and Street. Related: Backcountry Discovery Routes: Two Buddies on Yamaha Ténéré 700s in Utah and Arizona GEAR UP
Most off-road adventures require miles of pavement to get to the trail, and the T7 is smooth, agile, and fun on curves and reasonably comfortable on the highway. We had been testing a 2023 T7 for several months – that’s the bike you see on the cover and in the action shots, ridden by our capable contributor Thad Wolff – when Yamaha hosted a one-day launch for the 2024 model in December. I rode our 2023 test bike down to Yamaha’s SoCal headquarters, swapped it for a 2024 fitted with a quickshifter, and racked up a few hundred more on- and off-road miles. The CP2 689cc parallel-Twin is a lively engine. New for 2024 is a plug-and-play accessory quickshifter. Modular Motor Sending power via chain to the T7’s rear wheel is Yamaha’s CP2 689cc parallel-Twin, the same compact engine also found in the MT-07 naked bike, YZF-R7 sportbike, and – in highly modified form – MT-07 DT racebike that’s used in American Flat Track. For T7 duty, the engine gets a dedicated airbox, cooling system, ECU settings, and exhaust system. With a 48% front/52% rear weight bias and a 452-lb curb weight, the T7 lofts its front wheel with ease. The Twin’s 270-degree crankshaft provides more evenly spaced power pulses than a 180-degree crank. It also produces a torquey feel and a lively exhaust note yet runs smoothly throughout the rev range. Fueling is spot-on, and power delivery is linear, reaching a peak of 63 hp at 9,000 rpm and 43 lb-ft of torque at 6,500 rpm at the rear wheel, as measured on Jett Tuning’s dyno. There are no ride modes, selectable engine maps, or traction control; just calibrate the twist of your wrist for direct results. Holding the T7 together is a durable steel perimeter frame with a double-braced steering head and removable lower frame rails for engine maintenance, and the steel trellis subframe is welded to the main frame. The long cast-aluminum swingarm enhances rear-wheel traction, and the distance between the axles is a lengthy 62.8 inches. Sitting or standing on the Ténéré 700, it feels very narrow between the knees. The two-piece seat is long and slender, with a flat section that slopes down from the pillion to its lowest point directly above the footpegs and then continues up onto the tank. If the 34.4-inch seat height is too intimidating, Yamaha offers some relief with a low seat ($129.99) that reduces height by 0.8 inch and a lowering kit ($114.99) that drops seat height by another 0.7 inch, bringing the seat down to 32.9 inches. The stock seat is tall, narrow, and firm. For our test on the 2024 model, we opted for the accessory one-piece rally seat ($219.99), which has cover material that’s less grippy than the stock seat and a flatter surface that makes it easier to slide fore and aft when riding over uneven terrain. By eliminating the lower dished section, the rally seat has thicker foam and sits at a lofty 36 inches. The new color TFT dash has two display modes and smartphone connectivity to Yamaha’s Y-Connect app. (Photo by Joseph Agustin) Yamaha Ténéré 700: Perfect for Roads Less Traveled The popularity of adventure bikes is largely due to their versatility. The Ténéré 700 can go just about anywhere and do just about anything, and it’s aimed at riders who place a high importance on off-road capability. Its 21-inch front and 18-inch rear wheels are better for rolling over technical terrain and accommodate a wider variety of knobby tires than the 19-inch/17-inch wheels found on many adventure bikes. Ténéré, meaning “desert” in the Tuareg language, refers to a vast, dune-filled Saharan plain that was a grueling stage in the Paris-Dakar Rally, which Yamaha won in 1979 and 1980. The T7’s Pirelli Scorpion Rally STR tires have a 70/30 on/off-road bias, and they work quite well in the dirt yet also provide decent grip on pavement without being noisy at highway speeds. The T7 also has tube-type spoked rims, which are light and will take a beating, but they make flat repairs a more involved process than with tubeless tires. Furthering the Ténéré 700’s off-road prowess is fully adjustable long-travel KYB suspension, which has good damping and soaks up big hits and dips like a champ. During the off-road portion of our photoshoot, Thad Wolff said he felt comfortable right away, allowing him to slide, jump, and wheelie the T7 like a big dirtbike. During my off-road ride through the mountains of Cleveland National Forest, I had fun jumping the T7 off water bars and lofting the front wheel over small gullies on the trail, maneuvers that were made easier by the bike’s 48% front/52% rear weight bias and 9.4-inch ground clearance. I appreciate the new Off-Road ABS mode because it provides more confidence in the front on sketchy, loose terrain while allowing rear-wheel skids or slides. The T7’s 452-lb curb weight is comparable to other bikes in its class. Though it’s light for a streetbike, its weight needs to be respected when riding off-road. The big “pumpkin” turnsignals have been replaced in 2024 with clear-lens LED indicators. But when the trail ride is done, and you’ve got miles of slab ahead of you – like the 100 miles of pavement on my route home after the press launch – the Ténéré 700 adapts like a chameleon to the new environment. Its rally-style windscreen is small but does a good job of managing airflow. The engine runs smoothly at highway speeds, and the 4.2-gallon tank was good for more than 200 miles at the 49-mpg average we recorded during our test, which included some aggressive throttle twisting. On the downside, there is no cruise control, and the stock seat leaves much to be desired for the long haul. If the taller (and thicker) rally seat isn’t a viable option, there are aftermarket saddles from companies like Seat Concepts. A new Off-Road ABS mode deactivates anti-lock braking at the rear only. Blue anodized spoked rims look trick but require tubes. On twisty pavement, the Ténéré 700 handles with confidence without any untoward turning resistance from the 21-inch front wheel. Its torquey Twin, moderate weight, wide handlebar, and narrow tires help the T7 rail through curves like an overgrown supermoto, and its brakes shed speed competently if not impressively. Related: A Yamaha Ténéré 700 Adventure from Biarritz, France, to the Bardenas Badlands Yamaha Ténéré 700: My Next Bike? 2024 Yamaha Ténéré 700 (Photo by Joseph Agustin) When it comes to test bikes, I’m promiscuous. As a Rider staffer, I’ve tested hundreds of motorcycles over the past 16 years. But when it comes to personal bikes, I’m a serial monogamist. Soon after getting hired, I started borrowing former EIC Mark Tuttle’s Kawasaki KLR650, which is the bike I cut my off-road teeth on. After lots of cajoling, Mark finally sold me the KLR, and the bike and I enjoyed several faithful, adventurous years together. Eventually, having grown tired of the KLR’s finicky carburetor and lack of power, I got the seven-year itch. I sold it and bought our lighter, more powerful 2017 KTM 690 Enduro R test bike. It’s fantastic off-road, but its vibration and lack of comfort on the road get old quick. Related: White Rim Trail on KTM 690 Enduros | Favorite Ride So here I am, at a crossroads, wondering what to do next and seriously considering the new Ténéré 700 for my own garage. Thad Wolff also really likes the Ténéré 700, especially its price, simplicity, and capability, and he could see himself owning one, though he’d like to make a few modifications to improve its comfort and touring ability. I agree on all counts, and Arden Kysely’s 2021 tour test and his long-term reviews of the T7 cover some useful upgrades. Arden now has nearly 17,000 trouble-free miles on his T7, and he’s a satisfied owner – an endorsement that further stokes my desire for the T7. To help me decide, I’ll keep our test bike for as long as possible, tailor it to my needs, and report on the experience. Stay tuned. Check out more new/updated bikes in Rider’s 2024 Motorcycle Buyers Guide 2024 Yamaha Ténéré 700 Specs
[motorcyclistonline] - 2024 Yamaha Ténéré 700 Review | Ninjette Newsbot | Motorcycling News | 0 | December 15th, 2023 01:53 PM |
[RideApart] - 2024 Yamaha Ténéré 700 First Ride Review | Ninjette Newsbot | Motorcycling News | 0 | December 13th, 2023 10:13 AM |
[ridermagazine.com] - A Yamaha Ténéré 700 Adventure from Biarritz, France, to the Bar | Ninjette Newsbot | Motorcycling News | 0 | August 8th, 2023 12:13 PM |
[motorcyclistonline] - 2024 Yamaha Ténéré 700 First Look Preview | Ninjette Newsbot | Motorcycling News | 0 | July 30th, 2023 03:11 AM |
[ridermagazine.com] - Yamaha Announces Updated Ténéré 700, Other Returning 2024 Model | Ninjette Newsbot | Motorcycling News | 0 | July 27th, 2023 12:32 PM |
