August 7th, 2015, 10:16 AM | #41 | |
How do your "numbers" compare with this : (lean angle & lat accel calc spreadsheet) : (Specifically his "lateral acceleration" under Turn Conditions) http://www.msgroup.org/forums/mtt/images/bike032210.xls |
August 7th, 2015, 01:26 PM | #42 |
Fighting Texas Aggie '05
^^ that is a neat spreadsheet BTW and it tells you the same story I am explaining. So on the sheet if you leave everything the same and enter 20mph in turn condition speed - you get a lateral acceleration of 21 ft/s^2 and a 321 lbf load on the rear wheel and you need around 34 deg lean at the CoG - if you increase that speed to 30 mph then your lateral acceleration just to 48 ft/s^2 and your at 722 lbf at the rear wheel and you need 56 deg lean at the CoG.
August 7th, 2015, 01:48 PM | #43 |
And if you enter 60 mph for a turn radius of 360 feet, what are the resulting numbers ?
August 10th, 2015, 06:44 AM | #44 | |
In this particular conversation we are talking about relatively low speeds in relationship to lean angle - not low speeds in relationship to corner radius or lean angle in relationship to curve radius. In general as the speed increases, the force increases, and the lean angle has to increase in a physical relationship for a constant set of parameters (bike/rider mass, geometry of the corner, etc etc).
August 10th, 2015, 12:47 PM | #45 |
٩(͡๏̯͡๏)۶
Join Date: Nov 2014 Motorcycle(s): 09 Ninja 250 held together by duct tape and zip ties Posts: 122
Good ol' M13 back when his videos weren't so depressing.
August 15th, 2015, 01:25 PM | #46 | |
August 15th, 2015, 02:36 PM | #47 |
Since we are not obviously on the same wavelength (either I misinterpreted your initial posts/or visa versa ...... or your point is just lost on me altogether as my message has been as consistent I could make it); we can let it die here and just go with a
August 16th, 2015, 01:24 AM | #48 | |
For any combination of speed and radius of turn, same lean angle means that the same force is applied on each contact patch. Consider that gyroscopic effect of high speed makes flicking harder but balance easier. Balance is a little more difficult to achieve a lower speeds, but flicking is easier, due to less gyro. That may be what M13 was referring to. The above posted gymkhana video shows that extreme forces and lean angles can happen at low speeds. Notice how for very small radius (rotation around cones) the speed and lean angles are less extreme. Why?
August 17th, 2015, 02:05 AM | #49 | |
What is your response to this : ? http://www.msgroup.org/Tip.aspx?Num=172&Set=145-180 The only time that balance plays a significant part in the control of your motorcycle is when you are traveling at slow speeds (about as fast as you can walk.) The rider in the first (kart track) video never was going as slow as 20 km/hr, more like 40-60 km/hr. If you agree with the msgroup article, then the "balance difficulty" is not a factor in the kart track video due to the speeds. |
0 out of 1 members found this post helpful. |
August 17th, 2015, 09:58 AM | #50 | |
MOTM - Sep '14
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
August 22nd, 2015, 10:54 AM | #51 | |
In my opinion, balance is always present, during slow or fast riding. Balance means keeping the vector weight perfectly aligned with the line that connects both contact patches. Because the dynamic nature of movement, either the rider or the steering mechanism/geometry brings back that vector over that line after each minute deviation via steering. When we steer, we relocate that line to the opposite side of that vector, making it work to restore balance. If you weld the steering mechanism to the frame, no bike can stay up at any speed. Returning to your question, keeping balance at low speeds requires more dramatic and longer inputs to the steering bar in order to correct deviations from the balance conditions. https://www.ninjette.org/forums/show...1&postcount=13 The rider of the video is using a sport riding style, but other riders would be also succesful by using a supermoto style or a Gymkhana style. Each style has an specific goal, but as long as each bike has enough ground clearance and tire grip and each rider is smooth and gentle with suspension, they can have similar performances on this specific track.
August 26th, 2015, 01:54 AM | #52 | |
Join Date: Aug 2015 Motorcycle(s): Ninja 300, Ninja ZX6r, NSR50, XR50r Posts: 65
"Ride hard. Don't look back." --Strider, LOTR |
Kart Track | nikeeric86 | Ninjettes At Speed | 22 | June 21st, 2015 07:34 PM |
[roadracingworld.com] - Minimoto USA Racing At Apex Kart Track In Lake Perris, Califo | Ninjette Newsbot | Motorcycling News | 0 | July 22nd, 2014 05:50 PM |
The track 300 at time square .... Up close trying to sneak some peeps | Klondike1020 | 2013 - 2017 Ninja 300 General Discussion | 17 | October 2nd, 2012 05:20 PM |
[roadracingworld.com] - News From Phil Herrin's Middle Georgia Kart Track | Ninjette Newsbot | Motorcycling News | 0 | February 17th, 2010 10:10 AM |
[roadracingworld.com] - New Kart Track At CMP May Be Ideal For Mini Racing | Ninjette Newsbot | Motorcycling News | 0 | August 5th, 2009 01:30 AM |
