September 1st, 2009, 02:25 PM | #1 |
Join Date: Dec 2008 Motorcycle(s): 09 250r (*sold*), 2010 Daytona 675 Posts: 301
New fender elim option
Haven't seen this one around before (so I hope it's not a repost!) but while I was scanning for an exhaust I came across this. Looks pretty clean to me.
http://www.jardineproducts.com/produ...productID/1215 Description: 08-09 KAWASAKI NINJA 250 No Cutting required! These kits offer the simplest way to rid your Sportbike of the bulky rear fender assembly. Bolt-on installation. Utilizes stock turn signals. Up to one pound lighter than stock. Gives your machine that tail high? style of a true AMA Superbike. $68 is a little pricey IMO, but hey, it's another option for a fender elim right? Looks like you have to order the license plate light seperately too.. Part number 46-0001 |
September 1st, 2009, 04:15 PM | #2 |
thanks for the heads up! You'd think they'd at least have pics that are in-focus though!
September 2nd, 2009, 10:14 AM | #3 |
Join Date: Aug 2009 Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R Posts: 868
You think?!?
September 2nd, 2009, 10:49 AM | #4 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
I still prefer the DIY.
The thiker wallet distracts people's view enough that they can't tell the difference between a chopped fender and an elim kit.
Addicted to anything that has an engine and rolls. |
September 9th, 2009, 09:32 AM | #5 |
Join Date: Sep 2009 Motorcycle(s): 2009 Yamaha R6 / 2008 Green Ninja 250 (Sold) Posts: 103
hmm not bad, but it doesnt seem like theres even enough room for a license plate light
September 25th, 2009, 12:01 PM | #6 | |
This looks to be as simple and elegant a solution as there is. I was going to order a fender and do the chop (when I do sell the bike I insist on having all the original parts either on the bike or included...just my personal thing) but the cost is close enough to this that it made sense to just order the bracket. |
September 26th, 2009, 02:17 AM | #7 | |
As for there not being enough room, sure there is. Some kits eliminate the light and, if needed, expect you to buy one of the ones that attaches TO your plate ($10 and under at Cycle Gear). They can just as easily attach to the bottom and shine up as they can attach to the top and shine down. http://www.cyclegear.com/spgm.cfm?L1...&item=MRX_LPL1 The classic 250 had a removable rectangular segment in the tail light which, when removed, would cast white light right onto the plate. |
September 26th, 2009, 05:29 AM | #8 | |
I have some stainless led bolts that appear to be good quality... time will tell http://www.cyclegear.com/spgm.cfm?L1...=TUC_48-0808_G |
September 26th, 2009, 05:53 AM | #9 | |
I really like the option of colored LED bolt lights, especially because I'd be replacing my blue reflector bolts. Did you need a resistor for those bolt lights or did they already come equipped for 12v operation? |
September 26th, 2009, 06:21 AM | #10 |
I think they're ready to go, and the instructions are quite clear...they don't show the need for one. I'm not going to install them until the fender eliminator arrives... do it all in one shot.
September 26th, 2009, 06:48 AM | #11 |
I see. Thanks! I was thinking that the batteries in the retail package would indicate that they'd be running off of disposable batteries in the package (not likely 12v; probably 2.5v), though it can still be wired on the LED side of the resistors to still include them.
September 26th, 2009, 03:46 PM | #12 |
2012 is here,let's ride!!
Join Date: Sep 2009 Motorcycle(s): 2009R,'12 suzuki +500 Posts: 354
I installed mine couple of days ago looks clean w/ little issuesthe rear fairing does not sit well w/ the product so you will notice gaps and it will expose the whole brake light too.
September 26th, 2009, 03:50 PM | #13 |
Got any pics?
The ones on the Jardine site aren't very good. I made my decision based on the illustrations in the installation instruction PDF. I figured there'd be some gaps, but I'm intending to make some filler pieces if needed. Shouldn't be difficult. |
September 26th, 2009, 04:04 PM | #14 |
i dont know how to post pics straight from my hard drive
September 26th, 2009, 04:30 PM | #15 |
October 18th, 2009, 10:46 AM | #16 |
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250R (red) Posts: 39
Did you ever get this installed? I'm thinking about ordering this kit as well and wanted to know what you thought of it.
October 18th, 2009, 12:19 PM | #17 | |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
October 18th, 2009, 12:26 PM | #18 |
thanks a bunch.
October 18th, 2009, 01:07 PM | #19 |
i like it overall if you are not to picky in terms of precise fit.
Homemade Fender elim kit | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 30th, 2012 06:06 PM |
is it me or the fender elim that is wrong? | Liquidtoon | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 15th, 2010 03:04 PM |
new fender elim kit | tinng321 | 2008 - 2012 Ninja 250R Farkles | 12 | June 11th, 2009 05:35 AM |
Crappy Fender Elim | JaeL | 2008 - 2012 Ninja 250R Farkles | 5 | April 11th, 2009 08:56 PM |
Best fender elim? | CrzyFstMnM | 2008 - 2012 Ninja 250R Farkles | 43 | March 20th, 2009 06:32 AM |
