June 22nd, 2011, 07:07 AM | #1 |
Forever Newbie
Join Date: Feb 2011 Motorcycle(s): 10' Ninja 250 Posts: 108
Bent Shifter Replacement
Hi All,
I bent my shifter the other day by... parking it in neutral on a hill :X it moved and fell. The entire mechanism works fine but the toe shift is a bent. I ordered the two following parts from bikebandit.com 13242A: LEVER-ASSY-CHANGE,PED 92161: DAMPER,CHANGE LEVER from http://www.bikebandit.com/houseofmot...8858#sch638178 I will be taking it into a non-dealer shop to get other things replaced next week as the parts come in. My big question is, are those two parts enough for the shop to replace? or did I have to order the whole shifter assembly? Thank you
My Riding Videos |
June 22nd, 2011, 07:54 AM | #2 |
Join Date: Apr 2011 Motorcycle(s): 2013 Ninja 300SE Posts: 47
If all that is bent is the shift pedal, then the pedal and rubber damper is all you need. Inspect the linkage carefully. Check and see if the "boots" and tie rod are ok. If they are, the pedal should be all you need. Note: The nuts on the ends of the tie rod are used to make small adjustments in the position of the shift pedal. Replacing the shift pedal will require disconnecting one end of the tie rod. If you want your new shift pedal in the same position as your original one, note it's position before it is disconnected.
June 22nd, 2011, 07:57 AM | #3 |
Bend it back.
June 22nd, 2011, 07:57 AM | #4 | |
Forever Newbie
My Riding Videos |
June 22nd, 2011, 08:01 AM | #5 |
ModMy250.com
Why not just bend it back like Bob suggested? How much is the shop going to charge you to replace it?
The www.ModMy250.com guy |
June 22nd, 2011, 08:08 AM | #6 | |
Forever Newbie
I had ordered the parts along with a bent left handlebar and a clutch lever. I think because of the high cost of the shifter, I may mail it back to bike bandit with the 20% restocking fee, minus shipping and restocking i think it will save me about $30 I think i was a bit over zealous with trying to get those parts replaced. Or should i keep it as spare parts and put it in a tankbag or backpack in case i drop the bike again.
My Riding Videos |
June 22nd, 2011, 08:19 AM | #7 |
ModMy250.com
Personally, I would just replace it if you can't get it bent back into the correct position. I'm pretty anal about wanting certain things to be the way they're supposed to be. If it's in rideable condition, you can always bring it over to my house and we can get that stuff replaced. That would save you some money from paying a shop at least and I have all the tools we need to do it. Are you replacing the bar end as well? Are you still coming out this weekend?
June 22nd, 2011, 08:29 AM | #8 | |
Forever Newbie
I will be coming out this Saturday for the meet! I will be there in Hayward to ride with you to Half Moon Bay for sure.
My Riding Videos |
June 22nd, 2011, 08:44 AM | #9 |
ModMy250.com
Sounds good . Just let me know when you get all your parts and we'll schedule a time. Did your grip get damaged too? I don't see a reason to replace that unless it's torn up.
June 22nd, 2011, 11:26 AM | #10 |
I'm anal too but sometimes small damages like that give the bike some character. I'd just leave it for now unless it changes how it rides/feels.
June 22nd, 2011, 11:57 AM | #11 |
ModMy250.com
yeah, but he may not want to be reminded of how it got bent
bent shifter pedal | reroka | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 11th, 2014 05:59 PM |
Is my gear shifter bent? | eXstasy | 1986 - 2007 Ninja 250R Tech Talk | 10 | November 20th, 2012 05:16 PM |
What is the best way to straighten a bent shifter? | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 5th, 2012 12:33 AM |
Gear Shifter Bent? | avneet | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 22nd, 2012 05:46 AM |
Emergency Shifter Holder Onner Bolt Thingy Replacement DIY | Ytse Frobozz | General Motorcycling Discussion | 7 | June 18th, 2011 07:24 AM |
