Old April 17th, 2014, 09:58 PM   #1
donny99
Motorcycle(s): kawasaki 250r
Unique problem with LED indicator/tail light
Hey everyone! New to the forum, thanks for having me.
I have just spent the last couple of days scouring the forum/google looking for a solution to this problem as well as double checking all my wiring/connections and have found nothing.
Proud owner of a 2008 Ninja 250R, I have just replaced the front indicators with LED's as well as installing an integrated LED tail light. I installed an electronic flasher (tridon 2 prong) and a no cut diode kit from customLED.
At first glance everything is functional, the indicators flash and the relay clicks just as it should except every 10 seconds or so it pauses or ticks double. Then every 30 seconds or so the indicator will just stay illuminated and the flasher will emit a beeping sound. This would be acceptable however as soon as I get the bike moving more than a few km/h it instantly does this and wont flash at all.
When I installed the integrated tail light there was only a single cable for each indicator so I just connected those to the green wire in the bike without a resistor.
Ive been scratching my head over this for hours, really hoping its something little thats easy to fix. Any possible solutions would be greatly appreciated.
Thank you in advance for any responses!!
donny99 is offline   Reply With Quote
Old April 17th, 2014, 10:03 PM   #2
Bad relay.
Old April 24th, 2014, 11:14 AM   #3
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Hey Bill. Welcome to the forums!
I recently started having the same problem. I haven't replaced my relay yet, but I agree with Alex. Most likely bad relay.
broilmebk is offline   Reply With Quote
Old April 24th, 2014, 12:45 PM   #4
kennetht
kennetht's Avatar
Originally Posted by Alex View Post
Bad relay.
Agreed.
This is the relay I use and I have no problems at all what so ever. I would highly recommend it.
http://www.superbrightleds.com/morei...asher/781/835/
Replace your current relay with that one and you should be all set.
kennetht is offline   Reply With Quote
Old April 24th, 2014, 03:50 PM   #5
broilmebk
broilmebk's Avatar
Originally Posted by kennetht View Post
Agreed.
FWIW, that's the one I have too.
Old April 25th, 2014, 07:17 AM   #6
kennetht
kennetht's Avatar
Perhaps your flasher relay has bit the dust?
Tail light flickering problem... skilletmo 2008 - 2012 Ninja 250R Tech Talk 7 August 9th, 2013 04:18 PM
Signal indicator and tail light problems! OfficerLove 1986 - 2007 Ninja 250R Tech Talk 5 December 18th, 2011 02:59 PM
