May 4th, 2011, 03:59 PM | #41 |
Join Date: Oct 2010 Motorcycle(s): 2009 Ninja 250r Posts: 36
I believe new york is also in north america? Taiwan is beside China
May 5th, 2011, 06:41 AM | #42 |
MOTM - Mar '13, Jun '14
Yes, New York is in North America and they have a Chinatown, so I take it Taiwan is beside Chinatown in New York. I'll have to visit it next time I'm in the city. Do they speak English there, or New Yorkese?
May 5th, 2011, 07:22 AM | #43 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
“here is my comment or concern with it. You are constantly putting oil on the chain which is then flinging it all over the rim and tire... does this not sound somewhat dangerous or at least messy to anyone else? I know after I cleaned and lubed my chain I was cleaning up the "flingage" for days... I couldn't imagine always having chain lube all over the rear of the bike.”
The oil used is 140 so very thick and you adjust the quantity to just a few drops per minute, so oil being sprayed about does not happen not in UK anyway not hot enough. It may become an issue with temperatures over 35˚C but you could go to thicker oil. Steve
Some mistakes are too much fun to make only once. |
June 12th, 2011, 07:45 AM | #44 |
Join Date: Jun 2011 Motorcycle(s): 09 Ninja 250r Posts: 4
I just bought my ninja yesterday after being on an NSR for about a year and a half. I was thinking of getting the standard one because its much cheaper. How are they to adjust the flow rate of the oil, is it easy enough to get right. I know the standard ones work off vacuum pressure from the engine so does that make it harder to set up.
August 11th, 2011, 08:20 AM | #45 |
[webbikeworld.com] - Scottoiler vSystem CARB Compliant Chain Oiler Now Available
New oiler is the first of its kind to meet strict California requirements.
Click here for full story...
December 13th, 2011, 07:20 AM | #46 |
[webbikeworld.com] - Scottoiler vSystem California Spec Review
April 8th, 2012, 09:54 AM | #47 | |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250R Posts: 3
Fitting a vSystem ScottOiler to my 2010 Ninja 250R but I appear to be stuck on the first step. I can't get the rubber bung off the vacuum spigot Am I missing something obvious? I've tried for hours from each side but the damn thing won't budge and I can't get any leverage on it. Input welcome and appreciated. |
April 10th, 2012, 04:18 PM | #48 | |
Took a bit of fiddling but I found it the easiest way. Getting the fairing off is easy enough but getting it fitted back on properly is hard. |
April 11th, 2012, 01:29 PM | #49 |
Cheers for the info. I'll report back after the weekend.
April 11th, 2012, 01:42 PM | #50 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
M13 ring a bell???
THE GOOD LIFE |
May 28th, 2012, 01:09 PM | #51 |
Finally got it sorted a few weeks ago - with the help of a long screwdriver to pry off the bung, and a helping hand from my dad (always the way to solve a DIY problem).
For those not wanting to take the spindle off - daunting - you can get a 10mm adaptor from Scottoiler, and with a paddock stand bolt holding it in place it all comes together quite well ... Last futzed with by gazmanj; May 28th, 2012 at 01:11 PM. Reason: image to big |
February 4th, 2013, 10:40 AM | #52 |
The Luck Dragon
Join Date: Apr 2012 Motorcycle(s): 2013 Ninja ZX-6R B/W Posts: 738
Came Across an Interesting Product - Automatic Chain Lube
I was browsing reddit and came across this interesting product that automatically lubes your chain as needed giving you the best performance at all times and longer lifetime for your chain and sprockets.
I might consider purchasing this for my next bike. http://www.scottoiler.com/us/Kits/Sc...ypage.tpl.html |
February 4th, 2013, 10:45 AM | #53 |
Fancy Farkle. I'll just stick to my little bottle of lube. How lazy can you be.
February 4th, 2013, 10:48 AM | #54 |
The Luck Dragon
February 4th, 2013, 10:55 AM | #55 |
MOTM - Sep '14
@himynameisjoe has one on his bike
February 4th, 2013, 11:23 AM | #56 |
Yeah, it's pretty nifty and convenient but you're still going to have to clean the chain.
February 4th, 2013, 11:32 AM | #57 |
The Luck Dragon
I think if it's always freshly lubricated the frequency that you would be required to clean it to keep everything working smoothly would be less since the lube stays lubricated instead of gunking up. Or would it still gunk up just as much over time?
February 4th, 2013, 12:11 PM | #58 | |
Check these opinions: http://forums.ninja250.org/posting.p...&t=84878&tro=1
February 4th, 2013, 12:16 PM | #59 |
Bass Master General
I like mine, so long as you have oil in the reservoir your chain will look brand new.
No cleaning required so long as you have oil and you ride. They've been proven by time here, lots of people have them, and they are a respected well known product here. The only reason everyone doesn't have them is because they cost a lot, and they require tricky fitting, although the new ones you just plug into the electrics. |
February 4th, 2013, 12:17 PM | #60 |
The Luck Dragon
February 4th, 2013, 12:31 PM | #61 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
Only thing you need to remember is checking your chain slack . Ill be getting the scottoiler for the 1000 since i use it to tour and i can rack up 500miles in a day on some of the trips im planning.
February 4th, 2013, 12:45 PM | #62 |
seems nice for a pure street bike. but i'm paranoid about everything on my race bike and i'm pretty sure these would not be legal for track use anyway
February 4th, 2013, 12:47 PM | #63 |
The Luck Dragon
Some of their pictures it looks like they might be on the track. Couldn't hurt to ask whoever is in charge of those regulations?
February 4th, 2013, 12:50 PM | #64 |
Que Buenos Son!!!
MOTM - Nov '14
Look at the pics on their website. They are definitely showing a track only bike on there with this system installed.
February 4th, 2013, 01:02 PM | #65 |
"scandal!"
Been wanting since I saw it on one of m13's vlogs. But it be spensive.
February 4th, 2013, 01:06 PM | #66 |
/merged a few scottoiler threads together
February 4th, 2013, 01:26 PM | #67 |
Bass Master General
It's interesting to see how eveyone in the states are coming across scottoilers since they pushed into the americas recently.
Seems to be a mixture of doubt, disbelief, amazement, confusion, denial, enthusiasm and excitement. They've sold in britain for years, proven and established. |
February 4th, 2013, 01:54 PM | #68 |
can't imagine how slippery the track would be if a couple hundred riders had these
February 4th, 2013, 01:59 PM | #69 |
it drops 1 drop on your chain every minute....so i dont think it would turn the track into a slip n slide by any means. You can change the amount of drips per minute but thats the typical setting.
February 4th, 2013, 02:00 PM | #70 |
The Luck Dragon
But what if someone crashes, does it have high durability to keep itself from bursting all over the track?
February 4th, 2013, 02:23 PM | #71 | |
I dont have it yet so i cant tell you for sure, but like a few posters have said, this is a normal things overseas where they use their bikes for more than liesure. I think these type of things got a bad reputation in the US from the really old bikes that had built in oilers being very messy. |
February 4th, 2013, 02:25 PM | #72 |
The Luck Dragon
February 4th, 2013, 03:17 PM | #73 |
i'm fairly confident you would not be allowed on a race track with something actively leaking oil. regardless of whether its intentional or not.
February 4th, 2013, 04:50 PM | #74 |
MOTM - Sep '14
February 4th, 2013, 05:05 PM | #75 |
http://www.cvmaracing.com/uploads/CVMA_Rulebook.pdf
you will be black flagged if your bike is leaking any fluids. the bodywork rules also state the belly pan must contain all of the bikes oil and coolant.
February 4th, 2013, 05:14 PM | #76 |
The Luck Dragon
Hmm, weird that they allow them overseas on tracks but not by your rule book here in the US.
February 4th, 2013, 05:19 PM | #78 | |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250(Totaled) Posts: 984
They work fantastic. My only gripe would be that none of their oil is rated under 0 degrees Celsius, so as of recently it's been too cold to pump the oil. But I guess there aren't a lot of people that are ridding in sub 0 temps
"I am a creationist, I believe man created god." |
February 4th, 2013, 05:23 PM | #79 |
The Luck Dragon
February 4th, 2013, 05:58 PM | #80 | |
Bass Master General
[cyclenews.com] - Scottoiler's 30 Years Anniversary | Ninjette Newsbot | Motorcycling News | 0 | February 19th, 2015 11:00 PM |
vacuum point - installing scottoiler | BikersPOV | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 21st, 2014 03:13 PM |
Need help with installing Scottoiler VSystem | tfkrocks | 2013 - 2017 Ninja 300 Farkles | 9 | February 17th, 2013 12:14 PM |
Lubing chains - Scottoiler | Honko | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 14th, 2011 12:58 PM |
[motorcyclenews.com] - Top marks for Scottoiler | Ninjette Newsbot | Motorcycling News | 0 | August 12th, 2008 08:32 AM |
