November 12th, 2009, 06:51 AM | #1 |
Is there an aftermarket exhaust....
....that requires no shimming or jetting? I'm thinking of changing the exhaust just for cosmetic reasons. I like the way my bike runs and the mpg I get so I really don't want to monkey with washers and tuning. I was thinking about a s/o can I seen on ebay but they don't say whether shimming is necessary or not.
November 12th, 2009, 08:56 AM | #2 |
Humble Observer
Join Date: Mar 2009 Motorcycle(s): 2009 Yamaha XT250 Posts: 612
The concensus I have gathered from others is that most slip-ons won't alter your aspiration enough to need a rejet.
Everything I post is "IN MY HONEST OPINION". Why is "Parking Lot Enduro" not a thing? |
November 12th, 2009, 11:05 AM | #3 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r (Fastest Color) Posts: 914
I can't say from experience but I would say to get your bike running smoothly you may. Each of our bikes is different and the conditions (elevation,temp,ect) are all different. That being said, these bikes come pretty lean from the factory as is. Adding a slip on removes back pressure, even if its just a little bit, which will lean the bike out a bit further. If your bike runs perfect and smoothly now without shimming then a slip on shouldn't make a big difference. But if the bike isn't as smooth as you would like but have lived with it because its not that bad, adding a slip on may enhance this issue.
Just my 2 pennies Posted via Mobile Device |
November 12th, 2009, 11:07 AM | #4 |
IC2(SW)
You should toss the DJ needle in your bike either way. I have a modded slip-on in the attic, if you wanna try it and see........ your more than welcome
November 12th, 2009, 12:59 PM | #5 |
Thanks Kerry. I may take you up on the offer. Gonna do a little more research online and see exactly what's out there.
November 12th, 2009, 01:04 PM | #6 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
I believe most of the aftermarket exhausts out are less restrictive than the stock exhaust (therefore running leaner) and the bikes from factory are already on the leaner side so shimming is usually a good idea.
May 29th, 2011, 09:32 AM | #7 |
ALRE all day
Join Date: Apr 2011 Motorcycle(s): 2009 Ninja 250R SE Posts: 107
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
Aftermarket Exhaust | herpderp | 2008 - 2012 Ninja 250R Tech Talk | 9 | November 7th, 2013 06:43 PM |
Aftermarket exhaust | Shano22 | 1986 - 2007 Ninja 250R Tech Talk | 59 | June 24th, 2011 04:15 PM |
aftermarket exhaust? | kenji_808 | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 15th, 2010 04:25 PM |
Looking for an aftermarket exhaust... | tc3jg | Items Wanted | 10 | June 26th, 2009 01:23 PM |
