April 4th, 2017, 04:13 PM | #1 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
2002 250 I got for free has engine issues advice needed
So my 18yo son wants to get on the track with me. He found a 2002 Ninja 250 put out by a shop because it was abandoned. We picked it up brought it home.
NO visible signs of engine damage, someone put clean oil in it. Chain is heavily rusted, swingarm and clipons also show signs of rust. Tires are very cracked. My guess is it has been sitting outside for a long time. 22K miles on the odo. I took the cap off the stator cover and tried to rotate engine by hand. Wont budge. Pulled spark plugs and sprayed WD40 and some penetrating oil last night. Still wont budge. I have torn apart my 2009 motor before to switch a crankcase with help from the nice folks here. I have a feeling I will have to drop the motor and crack it open to see whats going on. Anything else I should look at / try before I drop the motor? Thanks! |
April 4th, 2017, 06:50 PM | #2 |
Join Date: May 2016 Motorcycle(s): GPX250-RII Posts: 296
are you sure it was in neutral gear
April 4th, 2017, 06:52 PM | #3 |
April 4th, 2017, 06:57 PM | #4 |
im sure the cylinder is full of rust and the rings is stucked dead in there , the rust had pitted to the point that its budging up taking up all the clearance
April 4th, 2017, 06:59 PM | #5 |
What else are my options besides dropping the motor ? I don't wanna keep cranking on the bolt trying to get it to turn over.
April 4th, 2017, 07:45 PM | #6 | |
you need an oil change after all of this because the solvents will mix with the oil below the pan Last futzed with by juliusmichaelhonrada; April 4th, 2017 at 09:52 PM. |
April 4th, 2017, 08:08 PM | #7 | |
April 5th, 2017, 02:52 AM | #8 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
sweet
April 5th, 2017, 05:36 AM | #9 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
A.T.F/Kerosene
I agree with the A.T.F. and kerosene (I use gasoline). I had a rear axle stuck, rusted fast in the rear wheel of a Honda due to a leaky wheel bearing seal. I tried everything and assuming I was going to destroy the rear axle beating it out with a hammer I bought a spare on eBay. Two days with my A.T.F./gasoline concoction and the axle tapped right out and the axle was OK. I had a friend who had a Yamaha RD350 with about 3,000 miles on it lock-up just like yours. I don't know what happened to the bike but this was before I knew about the A,T.F. concoction. |
April 5th, 2017, 11:37 AM | #10 | |
April 5th, 2017, 12:56 PM | #11 |
A.T.F./Kerosene
The gasoline and kerosene will evaporate and the A.T.F. won't hurt anything. If you are lucky and it works you will have to remove the head and cylinders. New rings are a must and maybe pistons. If the cylinders are badly pitted they will require boring for new oversize pistons. You might take a chance that the crankshaft main bearings and big end connecting rod bearings are OK. The wrist pins need to be checked for pitting and damage. When you are satisfied with your repairs the engine can be reassembled, fresh oil and filter installed and fire it up. Run it at idle for about 10 minutes and drain the oil and replace the filter again and clean the oil pan screen. Install new oil and filter, go to church and pray. Go home and run it.
April 5th, 2017, 12:58 PM | #12 | |
April 5th, 2017, 01:09 PM | #13 |
Another thought
I HOPE NOT but there my be a broken rocker arm floating around in the cam chain tower. Might be a good idea to pull the right crankcase/clutch cover for a look around.
April 5th, 2017, 01:13 PM | #14 |
April 5th, 2017, 03:45 PM | #15 |
I just mixed up some ATF/gasonline and used a syringe to inject about 9oz per cylinder. I will let it set and see what happens. One difference I noticed on the pregen motor is the drain hole on the left side of head. a little came out there, but not much
April 5th, 2017, 06:01 PM | #16 |
I sat here reading this and said to myself, "I'll bet that's a drain for the spark plug valley." My bike's all torn apart right now so I took a piece of 14ga red wire out with my flashlight. I shoved the wire into the hole on the side of the cylinder head and sure nuf' the wire could be seen over the top of the empty spark plug hole. In fact I think the hole runs the entire width of the cylinder head. God, the more I fool around with this bike the more admiration I have for Kawasaki engineers. So, if you have the gas tank off your bike and it rains the water won't puddle around the base of the spark plug. So too at the car wash. Cool! You don't have a hole in the side of your cylinder wall. :-o
April 6th, 2017, 03:40 PM | #17 |
Still not budging, tried acetone/ATF and gasoline/ATF. Will pop the covers off and see whats going on.
April 6th, 2017, 06:04 PM | #18 |
and the bolt broke trying to turn it over. FML
April 6th, 2017, 07:23 PM | #19 | |
A.T.F and . . . ?
In my worthless opinion A.T.F and acetone will make an emulsion if shaken really hard but the two chemicals will eventually separate again. A.T.F. an gasoline will go into solution and will stay that way, The way I see it the gasoline is merely a "carrier" for the A.T.F. and delivers it to all the molecular nooks and crannies - then evaporates. Like the carrier in spray paint. I wouldn't look for "snap your fingers" results. Real results may not come until several days have past. The parts got into the mess they're in over a period of years. I would just give it some time. Maybe it'll be weeks - who knows. My experience with this concoction was over a period of days but I was only working on a stuck rear axle not engine cylinders. I would consider, after a period of time and removing the cylinder head, getting a piece of soft pine 2x2 and a mallet and give the piston crowns some gentle raps to try and crack the layer of corrosion. |
April 6th, 2017, 10:59 PM | #20 |
April 7th, 2017, 12:49 PM | #21 |
the alternator rotor bolt, its not very thick. I am sure I will be able to drill it out. At this point I will be dropping the motor. I will deal with that when I have to.
April 7th, 2017, 01:14 PM | #22 |
With a broken bolt that has the remainder not particularly stuck, sometimes a left hand drill bit will get it out. Of course there's the Easy-Out method. Drilling it out as such can be dangerous unless you have a way to keep the bit lined up and exactly centered.
April 7th, 2017, 01:15 PM | #23 | |
April 7th, 2017, 01:32 PM | #24 |
Industrial suppliers like mcmaster.com have them. You may have a local supplier that stocks them. It's handy to have a set of a few sizes in the shop.
April 7th, 2017, 05:35 PM | #25 |
if you are planning on stripping down the engine , you can lift the whole crankshaft assembly + the flywheel and have it drilled in a machine shop with extreme precision
April 7th, 2017, 07:13 PM | #26 |
Bolt extrator
Try this:
https://www.amazon.com/Extractor-Ais...crew+extractor You will have to drill a small hole in the remaining bolt shank but you won't need to get anywhere near the existing female treads. |
April 7th, 2017, 08:28 PM | #27 |
That's a different brand of the of the "Easy Out" method I mentioned. It's a good way to get the broken part out.
April 7th, 2017, 10:37 PM | #28 |
UPDATE! Got the bolt out by hand. So no big deal there. Got the crankcase split, pistons and rings are fine. The issue is the right connecting rod, is totally seized on the crank.So what do I do? New crank and connecting rods? just replace the one thats seized?
took it apart and look at whats left of the bearing. So don't I have to order a special bearing based on like the colors on the crank or something? I should do rings as well since I am in there , right? http://imgur.com/a/afJK8 http://imgur.com/a/Ke4VX |
April 7th, 2017, 10:48 PM | #29 |
remove the conrod and hope that the crank journal is fine because it will be a painful experience when you try to fix a crank
April 7th, 2017, 10:57 PM | #30 | |
so looking at the manual, my Conn rod big end has a letter and a O around it, on the crank, I don't see any markings where it says there would be one. So if I am reading that correctly, then I need the white/blue bearing. Am I reading that correctly? |
April 7th, 2017, 11:55 PM | #31 |
the mark on the crank should look like this
get a vernier caliper and do a rough measurement of the big end journal that have the broken bearings , should be a micron before 30mm if its far around 29mm im afraid its not useable anymore the maximum service limit of the big end journal is around 29.97mm if i remember it correctly |
April 8th, 2017, 12:00 AM | #32 |
here is what mine look like
I used my calipers and its 29.85mm http://imgur.com/a/0QQzC http://imgur.com/WhybRDl |
April 8th, 2017, 12:30 AM | #33 |
Name: not just yet
Join Date: Apr 2017 Motorcycle(s): 2007 Ninja 250 Posts: 2
Just doubled checked my service manual, and Julius is right that the service limit is 29.97. If you've worn down to 29.85, you won't be able to find undersize bearings (from what I've heard, haven't personally confirmed), and you probably need to source a new crank.
There's also processes for welding cranks and re-machining them, but I can't image it's cost effective to do that in this case. |
April 8th, 2017, 06:49 AM | #34 |
It's hard to imagine that the crank journal isn't at least in need of a regrind after running with a bearing that's damaged like that. It not only has to measure in spec, but needs to have a near perfect, almost shiny ground surface.
Whatever caused the rod bearing failure may have damaged more than just that one, so take a close look at all the journals and bearings. |
April 8th, 2017, 09:36 AM | #35 |
So the Journal is still nice and shiny and smooth. I was measuring the journal on the wrong side, and each time I use my calipers the measurment is a little different, I get 29.92-29.96 now depending on how hard I push the caliper against the journal. Maybe its ok?
took the other connecting rod off, the journal reads 30.02 or so. The other thing thats interesting is the conneting rod cap on the failed bearing, I put it back on and I cant even pull it off even with no nuts on it. Makes me think it got twisted or warped? Maybe I should find a crank/connecting rod set on ebay or something? |
April 8th, 2017, 09:56 AM | #36 |
A rod cap fit should be pretty snug, so that's most likely a good thing.
You really can't measure crankshaft clearance with a vernier, or dial, or digital caliper. You need a halfway decent micrometer that can measure sub-thousandths of an inch (better than 0.02mm). If you don't have one, and don't want to buy one, a local automotive machine shop should be happy to measure it for you. That difference between the two is troubling. |
April 8th, 2017, 10:07 AM | #37 | |
the "good" connecting rod cap comes off freely. Just sent my son to a machine shop to get all of the journals measured. |
April 8th, 2017, 11:32 AM | #38 |
Well, obviously both assemblies (for L and R cylinders) should measure similarly and have caps with similar snugness. Deinitely get some accurate measurements of all the crank journals so you know what you're working with.
At some point an eBay engine is cheaper and easier than buying parts and paying a machine shop. |
April 8th, 2017, 06:45 PM | #39 | |
The gouge runs long ways, its smooth. I am sure it would work in the short term, and this will only be a track bike. Just not sure what else to do at this point. So if I went with a crank off like eBay, what would the process be as far as what main and conrod bearings I would have to use? |
April 8th, 2017, 07:52 PM | #40 |
Can the machine shop grind the journal one size under, and you use matching undersize bearings, and it'll be like new?
250/300 engine tips/advice? | tuscani451 | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 25th, 2015 05:41 PM |
Advice needed on engine work | zzr | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 6th, 2014 07:14 PM |
Advice Needed: Engine Bog @ ~6k 1/4 Throttle | MaxxVE | 1986 - 2007 Ninja 250R Tech Talk | 7 | March 16th, 2014 05:10 PM |
2002 Ninja 250 - issues (spark pugs, dirty carbs, won't idle, etc?) | Pocket Sprocket | 1986 - 2007 Ninja 250R Tech Talk | 12 | May 17th, 2013 11:13 AM |
New fairings needed for a 2008 250, any advice? | tar wheels | General Motorcycling Discussion | 9 | May 16th, 2013 06:49 AM |
