Old June 1st, 2022, 03:47 AM   #1
[webbikeworld.com] - 2022 Zero S [Specs, Features, Photos]
Click here for full story...
The 2022 Zero S: The Entry Into the Zero Street Lineup
Contents
The Zero S is the motorcycle that started the street segment for the American company. Today, it sits below the more capable Zero SR, SR/F, and SR/S models in the 2022 Zero Motorcycles lineup. That said, it offers modest performance and range numbers, making it an excellent option for everyday commuting.
Unlike the Zero SR models with 14.4kWh battery packs as standard, the Zero S offers half the battery capacity with a 7.2 kWh total capacity. This translates to less than half the range, with a claimed 89 miles in the city and 45 miles (at 70mph) on the highway. A full charge takes 5.2 hours, but you can bring that number down to just 1.5 hours using the Charge Tank (6kW charger).
The Z-Force 75-5 motor produces peak power and torque figures of 46hp and 78 lb-ft, respectively. This isn’t the most exciting EV in Zero’s stable, but the performance is enough to get the bike to a respectable top speed of 98mph.
Zero Motorcycles may have equipped the Zero S with a more humble powertrain and battery pack, but it didn’t skimp out on the hardware. The EV comes equipped with a set of grippy Pirelli Diablo Rosso II tires, fully adjustable Showa suspension, and Bosch Gen 9 ABS that works alongside braking hardware from J.Juan.
Yes, you’re missing out on the neck-snapping torque and acceleration that the SR models offer, but it’s worth noting that the Zero S costs at least $7,000 less than its bigger siblings.
The 2022 Zero S starts at $11,595 USD / $14,895 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero S in one place.
Motorcycle Overview
</p>General Info
  • Price: $11,595 USD / $14,895 CAD
  • Key Features:
    • 89 miles range in the city
    • $0.81 average recharge cost
    • Bosch Gen 9 ABS
    • Pirelli Diablo Rosso II tires
    • Five-year unlimited mile power pack warranty
Main Specs
  • Engine: 7.2 kWh
  • Power: 46hp
  • Torque: 78lb-ft
  • Wet Weight: 313 lbs (142kg)
  • Seat Height: 31.8 inches (807 mm)
Competitors
2022 Zero S Specifications
Engine
Peak torque78 ft-lb (106 Nm)
Peak power46 hp (34 kW) @ 4,300 rpm
Top speed (max)98 mph (158 km/h)
TypeZ-Force® 75-5 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor
ControllerHigh efficiency, 550 amp, 3-phase brushless controller with regenerative deceleration
LubricationDrivetrain
TransmissionClutchless direct driveClutchFinal Drive90T / 18T, Poly Chain® HTD® Carbon beltChassis
Suspension FrontShowa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping
Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound dampingBrakes FrontBosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc
Brakes RearBosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc
Tires FrontPirelli Diablo Rosso II 110/70-17Tires RearPirelli Diablo Rosso II 140/70-17Fuel Tank CapacityN/AColorPower system
Power packZ-Force® Li-Ion intelligent integrated
Charger type1.3 kW, integrated
Charge time (standard)5.2 hours (100% charged) / 4.7 hours (95% charged)Dimensions
Wheelbase55.5 in (1,410 mm)
Overall WidthTrail3.2 in (80 mm)
Rake24.0°
Seat Height31.8 in (807 mm)Curb Weight313 lb (142 kg)
Warranty
Warranty2 years
Extension
2022 Zero S Features
NAKED ELECTRIC
The model that originally defined electric motorcycle street riding is still able to thrill riders all over the world. Stunning acceleration at any RPM, sharp lines and sporty ergonomics transform your daily ride into a thrill. This foundational powertrain delivers ranges up to 89 miles in the city and 45 miles on the highway.
2022 Zero S Photos
2022 Zero S Videos
2022 Zero S Walkaround by Mark’s Motorsport:
2021 Zero S Review by Mark Pulling:
Links
Zero Motorcycles Websites
Social Media Links
The post 2022 Zero S [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Zero SR [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 1st, 2022 03:27 AM
[webbikeworld.com] - 2022 Aprilia SR GT [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 31st, 2022 01:47 AM
[webbikeworld.com] - 2022 Honda CB500F [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 07:42 AM
[webbikeworld.com] - 2022 Ducati Multistrada V2 / V2 S [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 01:27 AM
[webbikeworld.com] - 2022 Honda Metropolitan [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 13th, 2022 10:41 AM
