February 22nd, 2011, 05:26 AM | #1 |
self wrencher
Oil pressure switch
Anyone know what's the Oil pressure switch does? It's located on left hand side right behind the header. I thought it was oil temp sensor but I looked up in the service manual and they call it Oil pressure switch instead. Does it switch on/off something?
February 22nd, 2011, 05:29 AM | #2 |
I believe that is what set's off the "low oil" dummy light.
February 22nd, 2011, 09:52 AM | #3 |
Gearhead
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 242
Yes, it makes the oil light come on if the oil pressure goes below a certain amount. Ususally 2-3 psi. but I'm not exactly sure how low for the Kawi.
February 22nd, 2011, 10:07 AM | #4 |
The oil pressure switch monitors the engine oil pressure. The engine oil pressure ranges from 14-25 psi max. Pressures below the min psi will initiate the warning light. If you ever happen to take the oil hose off you will notice how tiny the banjo holes are and how thin the hose is. I think the upper cylinder could benefit from better oil flow at higher rpms. That was one of my reasons for getting an oil cooler.
February 22nd, 2011, 12:56 PM | #5 |
self wrencher
I replace that switch with an oil temp sensor (Koso)...not sure if that would do any damage...
February 22nd, 2011, 01:02 PM | #6 |
Does the Koso gauge have a low pressure warning light? A switch simply completes the circuit through a light bulb when pressure goes lower than a preset amount. If the Koso doesn't have a low pressure warning light then you'll have to pay attention to the gauge to make sure you don't miss a low-pressure event.
February 22nd, 2011, 01:06 PM | #7 | |
Does the KOSO not have a low pressure warning hook-up?
February 22nd, 2011, 01:12 PM | #8 |
I just confirmed. The KOSO does have a low oil warning trigger. Should be a wire in the KOSO harness to hook to the stock oil pressure sensor or at least tap into somewhere.
Double check your wiring!!!
February 22nd, 2011, 01:19 PM | #9 |
Do not replace the switch with the hose on it. Put the Koso oil temp sensor on the old oil drain plug on the bottom of the engine. The old drain plug location is next to the oil filter cover.
February 22nd, 2011, 01:40 PM | #10 |
self wrencher
Whoops..It looks like I'll be changing my oil tonight
February 22nd, 2011, 02:39 PM | #11 | |
IC2(SW)
That stock switch was only good for oil light and the temp light check. New gauge has no use for it. Unless that koso is different from the instructions I looked at, they didnt even deal with oil pressure??? |
February 22nd, 2011, 07:33 PM | #12 |
self wrencher
Not sure. Koso does have an oil light. I moved the oil temp sensor down to the old oil drain as recommended a d put back stock oil pressure sensor.
I ha e a plug and play wire set so no splicing. Just plug it in and go. |
February 23rd, 2011, 07:41 AM | #13 |
Well I would think the KOSO oil light would be on when the key is turned on and it should go off shortly after the bike starts... just like stock.
February 23rd, 2011, 06:58 PM | #14 |
self wrencher
Yes. That is correct
oil pressure light | contact148 | 2008 - 2012 Ninja 250R Tech Talk | 28 | June 21st, 2018 06:54 AM |
Pressure Switch - Braided lines | Enrgkid | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 3rd, 2015 05:24 AM |
Oil pressure switch and banjo bolt issue | linkinpark9812 | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 29th, 2014 07:36 PM |
Oil Pressure Light on Startup | quicklooker | 1986 - 2007 Ninja 250R Tech Talk | 28 | July 19th, 2013 07:16 AM |
Autogage Gauges, oil pressure? | J Walk | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 21st, 2011 08:49 AM |
