May 7th, 2010, 03:33 PM | #1 |
Idea for reinstalling Carb.
I removed and reinstalled my carb last weekend, and was able to fully appreciate how difficult it is to remove, and even more so to reinstall.
I just had an idea that might help somewhat for the reinstall. Spraying soapy water on the engine side and airbox side rubber boots.... just like we lube tires. Maybe others have done this all along, but I haven't noticed it. |
May 7th, 2010, 04:20 PM | #2 |
It's worth a try.
May 7th, 2010, 04:26 PM | #3 |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
Sounds worth trying. I'll test it the next time I swap the carbs.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
May 7th, 2010, 04:41 PM | #4 |
I use silicone spray or rubber protectorant. Makes rubber parts muuuuch easier to work with and to assemble.
May 7th, 2010, 05:48 PM | #5 |
May 7th, 2010, 06:01 PM | #6 |
MOTM - Sep '18, Feb '16
One more thing it is about the clamps that hold the carbs. You only have to turn the screw a couple turns to get the carbs off.
BUT if you try to push them back on it is very difficult. Try unscrewing the clamp more .it will allow the manifold to stretch and the carbs will go on easier. |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Slight Gap After Reinstalling Fairing | Ralgha | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 22nd, 2014 07:43 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
Couple of questions after reinstalling wheels. | RedOctober | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 24th, 2012 03:44 PM |
HELP?! Reinstalling Carbs?! | SdSy675 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 20th, 2011 12:47 AM |
