June 17th, 2012, 06:15 AM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
Is this a leak? Anyhow, I want it gone
hey guys,
For a while I've had what appears to be a leak, but I don't lose oil what so ever. Does anyone know what causes it, and more important, how to stop it? I hate cleaning that up every time.
I can not be a true player by playing around. |
June 17th, 2012, 06:22 AM | #2 |
Mine does the same also I have found 0 proof of oil being lost..
I figured it is from a lubing the chain... degreaser will clean it off your fairing. |
June 17th, 2012, 06:23 AM | #3 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r Posts: 217
It's oil and it looks like a leak to me.
June 17th, 2012, 06:25 AM | #4 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
Can't tell unless I was there, but that would be either oil or stuff coming off your chain.
June 17th, 2012, 06:48 AM | #5 |
chain lube flies off into the inside of my chain guard, and lower case, dripping onto my fairings.
if the oil is sticky and greasy feeling then it definitely chain lube that was over applied, or applied when cold. how much lube do you apply each time you do the chain? |
June 17th, 2012, 07:07 AM | #6 |
I use a motul racing spray tube (white, sticky stuff)
I ride 100kms of highway two times per week and some weekend trips, total 250 km/week Every week I apply the lube by letting the bike idle in first gear on a stand, I spray the four sides of the chain for 1 revolution. So if you think that I use too much lube, than it would be in frequency (once a week) and not how much I put on it when I do it. What do you think?
June 17th, 2012, 07:09 AM | #7 |
Unless you're riding in the rain frequently, it seems like it's way too often. Every 500 - 600 miles is fine (800 - 1000 kilometers).
June 17th, 2012, 07:13 AM | #8 | |
When I find time, I will clean the chain guard and lower case and lower my 'lubing frequency'
June 17th, 2012, 02:17 PM | #9 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Yeah, thats definitely chain lube. Pop the cover off your front sprocket, and clean it out. My guess is that it's SUPER crudded up in there. Then use a little less lube, also....after you lube it...wait 15 min for it to cure up a bit before you ride. It won't sling off as much.
June 17th, 2012, 04:47 PM | #10 |
If it's flinging that much at the front sprocket you'll be lucky if it hasn't thrown it all over the left side of the back wheel, check that before you go for any sharp lefts.
June 17th, 2012, 05:26 PM | #11 |
Your stator cover gasket is leaking. If you look closely enough, you'll see where the cover and engine case meet and where the wires come out. Chances are that silicone sealant (where the wires come out) may need replacing as well. You may want to replace it all ASAP.
If this was wet chain lube it would be all over the kick stand and switch instead |
June 18th, 2012, 02:36 AM | #12 |
That's why I went for the sticky stuff, I had noticed it too
June 18th, 2012, 06:51 AM | #13 | |
August 12th, 2012, 02:14 PM | #14 |
Ok guys, one month later...
I have cleaned it all out, applied lube less frequently and it worked. It stays clean Thanks for all you input
August 12th, 2012, 03:22 PM | #15 |
Lol, I had that issue too at the track yesterday, I was like fuggggg.
August 12th, 2012, 08:32 PM | #16 | |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
This has some pretty graphic pictures. OUCH |
August 12th, 2012, 09:21 PM | #17 | |
Laser Quest
Join Date: Apr 2012 Motorcycle(s): 2012 Black Ninja 250r Posts: 245
August 13th, 2012, 12:59 AM | #18 | |
thanks for your concern though
August 13th, 2012, 05:52 AM | #19 | |
Join Date: Apr 2012 Motorcycle(s): 2008 Kawi Ninja 250R, 2013 Honda CRF450R, 2008 Honda CRF250R, 2001 Honda XR400 Posts: 301
August 13th, 2012, 08:23 AM | #20 | |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
Oil leak | Xaero | 1986 - 2007 Ninja 250R Tech Talk | 11 | November 16th, 2013 06:58 PM |
Motor leak? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 25th, 2013 06:39 PM |
Help, fuel leak. | Stangrider | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 24th, 2013 09:34 PM |
Rear brake fluid leak (container leak?), any advice appreciated. | deaddemon | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 6th, 2011 01:52 PM |
Identify Leak | Cuongism | 2008 - 2012 Ninja 250R Tech Talk | 35 | May 11th, 2011 12:44 PM |
