July 23rd, 2013, 07:07 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
Valve Adjustment
My bike has almost 12,000 miles on it and I haven't done a valve adjustment yet because I've been worried about messing something up
How difficult of a job is this and how easy would it be to ruin the engine or cam chain tensioner? Is the Hot Cams kit worth it or should I just buy the shims individually? http://www.amazon.com/gp/product/B000WJWTM6/ Also, here's the feeler gauge and caliper I was going to get: http://www.amazon.com/25025-26-Blade...r+gauge+metric http://www.amazon.com/Neiko-01407A-E...gy_auto_text_y Thanks. |
July 23rd, 2013, 07:23 PM | #2 |
Join Date: Mar 2013 Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only Posts: 150
The OEM feeler gauge is like 2 bucks at autozone, I was going to buy one off amazon as well.
Im curious which feeler gauge everyone is using as well, because it needs specific values that dont seem to be on these gauges?
http://www.1000rr.net/forums/showthread.php?t=90412 http://www.8thcivic.com/forums/ http://www.facebook.com/profile.php?id=1209877267 |
July 23rd, 2013, 08:01 PM | #3 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
When I had my 250, having the Hotcams shims were a must to get the job done without having to wait days for shims. They are also cheaper than OEM shims and work just as well.
As for feeler gauges, go to a Sears store and get a set there. The ones they sell there will have the size range you'll need for the job. Also, you will need to replace the gasket that goes between the cam chain tensioner and the engine block. I forgot which part number it is, but it's cheap insurance. I know the how-to on the forums has a certain way of resetting the cam chain tensioner, but it's impossible to do. The way I reset the tensioner is to put the end that goes into the engine on a rubber mat and press down as I turned the screwdriver to reset the tensioner. Once I get it to the reset position, I used an X-Acto blade to hold it in until you get the tensioner mounted on the engine block. A picture hanger also works well.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
July 24th, 2013, 04:57 AM | #4 | |
Also, the one guide says to use molybdenum disulfide grease on a lot of different parts. Where can I buy this? I've searched and haven't really found anything that specifically says "molybdenum disulfide" grease. |
July 24th, 2013, 06:17 AM | #5 |
What would happen if valves were never adjusted? Would the engine just fail after a while and you'd have to buy a new motor for $500-$600? And is synchronizing the carbs after the valve adjustment necessary?
I'm reading all these tutorials and topics on this but I don't know if I'm going to be able to do all this myself. This seems like it's the most difficult routine maintenance to do on the bike. |
July 24th, 2013, 06:51 AM | #6 | |
If you post here, you may find someone local willing to help you: http://www.soflasportbikes.com/forum/
July 24th, 2013, 09:03 AM | #7 |
So am I taking a big risk if I ride another 5,000-10,000 miles without doing a valve adjustment?
July 24th, 2013, 09:20 AM | #8 |
Fast-Guy wannabe
MOTM - Jan '13
I bought my bike with 1500 miles and although I don't know for sure I'm confident the original owner had the 600 miles service done which I think includes valves
But anyways I didn't inspect them for myself until 12000 miles and they where all off just outside the range so I had to adjust each one. Cameron waited till 15000 miles and all of his needed adjustment but a couple were in dire need and probably on there way to burning up. After we adjusted his valves and synced his carbs he said the bike runs like a new machine. Don't wait just get it done before you cause more problems later. |
July 24th, 2013, 10:13 AM | #9 |
make sure you set the valve cover gasket correctly the first time. if you have to redo it, don't let the rubber thing on the water exit tube fall down the water pipe. and if it does, don't reach in with your grubby fingers to try to get it out (use the proper grabber tool), accidentally cramming it down further. also if you do that, when you go to pull the head off (because you have to stick a ziptie up through the bottom water feed tube line), use all the proper tools and don't strip bolts. when you strip a head bolt, i've found using 2500psi 2-part epoxy to bond the newly bought high-torque allen socket to the bolt works well. make sure none of the hardware falls down the cam chain path to the bottom, because taking off the clutch cover always rips the paper gasket.
oh yeah, all of that happened on the last valve job i did. @ally99
July 24th, 2013, 10:45 AM | #10 | |
Fast-Guy wannabe
MOTM - Jan '13
July 24th, 2013, 10:47 AM | #11 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
DEFINITELY not while he's distracted, at least.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
July 24th, 2013, 11:27 AM | #12 |
it's funny. i've done valve jobs on ninja 250s so many times... at least 20 times on 6 or 7 different ninja 250s. but i royally screwed the pooch that time. the time before that, i did my own bike, it took about 30 minutes start to finish.
July 24th, 2013, 11:30 AM | #13 |
Only 30 minutes?
I'm guessing this will take me at least ten hours |
July 24th, 2013, 11:39 AM | #14 |
Fast-Guy wannabe
MOTM - Jan '13
July 24th, 2013, 01:11 PM | #16 |
Which feeler gauges did you guys use?
July 24th, 2013, 01:31 PM | #18 |
Would the one in the OP be considered accurate?
July 24th, 2013, 01:44 PM | #20 |
Fast-Guy wannabe
MOTM - Jan '13
I couldn't find metric so I used a set that has .001-.040 in single .001 steps so its very accurate but you have to be go a using math conversions or your going to get lost. I showed @CycleCam303 how to used the .03937 factor and after the first two valves he was on a roll. |
July 24th, 2013, 01:48 PM | #21 |
Fast-Guy wannabe
MOTM - Jan '13
To be fair to Alex I totally forgot to mark my cam chain and cam sprockets the first time I did mine because I was talking to ****ing Cameron so I had to take it apart and reinstall them like 5 times before I was 100% sure I understood EVERYTHING about how it all was timed and then prayed for the best in total I think my first time was like a 10hr job
July 24th, 2013, 02:32 PM | #22 |
How about this one? http://www.sears.com/kd-tools-metric...94117000P#desc
25-blade gauge measures clearances from 0.04 to 1mm. Blade sizes:0.04, 0.05, 0.06, 0.07, 0.08, 0.09, 0.10, 0.15, 0.20, 0.25, 0.30, 0.35,0.40, 0.45, 0.50, 0.55, 0.60, 0.65, 0.70, 0.75, 0.80, 0.85, 0.90, 0.95 and 1mm. Blade Lengths: 3 in. long |
July 24th, 2013, 02:43 PM | #23 |
Fast-Guy wannabe
MOTM - Jan '13
That'll work so now what do you have to measure the shims?
July 24th, 2013, 02:50 PM | #24 |
July 24th, 2013, 03:15 PM | #25 |
Fast-Guy wannabe
MOTM - Jan '13
Micrometers are better for measuring shims then calipers are. I can't comment on the quality of any of the cheap $30 stuff since I just use what's in my machine shop and that stuff is all like $2-300 and comes with certificates for accuracy. But I totally understand the not wanting to spend $500 on tools to do a $200 job
July 24th, 2013, 03:28 PM | #26 |
July 24th, 2013, 04:12 PM | #27 | |
Fast-Guy wannabe
MOTM - Jan '13
Yes that's a micrometer but that measures in inches, you want to stick with all metric if you can. It may be hard to find an anolog(your link) metric micrometer but I know that make digital ones that you can select mm or inch with the push of a button. |
July 24th, 2013, 05:04 PM | #28 | |
' i bought my micrometer and feeler gauges from harbor freight. i think total they were probably $10 for both.
July 24th, 2013, 05:37 PM | #29 |
This one looks like a bettet/cheaper feeler gauge http://www.amazon.com/Amico-Metric-T...c+feeler+gauge
lade thickness: 0.02, 0.03, 0.04, 0.05, 0.06, 0.07, 0.08, 0.09, 0.10, 0.15, 0.20, 0.25, 0.30, 0.40, 0.50, 0.75, 1.00mm
July 24th, 2013, 05:53 PM | #30 | |
Fast-Guy wannabe
MOTM - Jan '13
But now people like us know more about it because we know the right way as well as the seven other wrong ways |
July 24th, 2013, 08:02 PM | #31 | |
Doing my valves took three days. First day, tear your engine down to the point where you remove the cylinder head cover. Second day, do the measurements and adjust. Third day, put everything back together, sync the carburetors. Also, be absolutely sure you have the correct number of links on the camshaft chain between gears! (Again, the exact number escapes me!) Also, see this post a couple of years ago about the CCT and the gasket (and explains how I reset it): http://www.ninjette.org/forums/showt...ght=CCT+gasket
July 24th, 2013, 08:54 PM | #32 | |
the clearances for the intake are .11mm to .20mm and the exhaust are 20 to 30.
July 25th, 2013, 04:29 AM | #33 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
July 25th, 2013, 05:16 AM | #34 |
Fast-Guy wannabe
MOTM - Jan '13
Well then I was only 4500 late on my first scheduled inspection and nothing was far enough out of spec to worry about long term. I'm on the every 10k miles plan so I checked at 12,20,30 and my next will be at 40. First time I adjusted all 8 valves, second time adjusted 1 valve, third time no valves need adjustment and didn't really seem to move much at all since the prior inspection. Valve inspection with no needed adjustments are nice and fast.
July 25th, 2013, 09:36 AM | #35 |
i think it depends on use. i've seen baby engines already over 0.05mm out of spec, and i've seen 30k engines still on original shims in spec. just depends
July 25th, 2013, 10:25 AM | #36 |
Fast-Guy wannabe
MOTM - Jan '13
So what your saying is everyone needs to ride like me on the weekends. Ride that bitch like you stole it because the 5.0 are right on your ass. This will get you the best engine wear
July 25th, 2013, 10:28 AM | #37 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
No way in hell I'd ever attempt to do this again. I broke the cam lobes (trying to put it back in place).
I'll pay and have paid a mechanic to do this for me.
July 25th, 2013, 10:50 AM | #39 |
CVMA #74 WSMC #750
Dood, I posted and explained how way back. Never again.
Valve Adjustment | quarterliter | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 25th, 2013 05:32 PM |
Valve adjustment ?s | Jewtoys | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 1st, 2012 08:47 PM |
valve adjustment | little fish | 1986 - 2007 Ninja 250R Tech Talk | 8 | November 4th, 2011 10:10 AM |
Valve Adjustment-Really Tight adjustment screw? | mikesova | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 2nd, 2010 04:57 AM |
anyone want to help with a valve adjustment? | diablo250 | Group Rides and Local Events | 2 | March 28th, 2010 02:00 AM |
