March 13th, 2014, 06:53 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2011 red ninja 250r Posts: 94
Cam chain rattle noise
Today this morning I noticed my ninja is noisier than usual. Sounds like soft slapping noise that noticeable on lower RPM, that goes to higher pitch as RPM rise. It was louder when RPM goes down. Most noticeable when the engine is under load. I guess it was the cam chain has been stretched.
My mileage so far is 38.000 km (23.600+ miles) with the ninja. Is it the normal lifespan for the cam chain that I can expect? Is there anyway to extend the life of the chain? I read a local motorcycle magazine wrote that the tensioner bolt can be replaced with a longer one. Can this really be done? Is there any guide I can refer to replace the cam chain? I will do this on a shop of my friend, as I dont have the tooling. He is kind enough to guide me when needed and lend me a space and tooling of his shop.
Corner is what the ninjette is made for. |
March 13th, 2014, 06:59 AM | #2 |
Que Buenos Son!!!
MOTM - Nov '14
Are you certain it's the cam chain? Have you checked the valve clearance or done an adjustment lately?
Cam chain stretch is a known problem with these bikes. You can replace the stock automatic tensioner with a manual one. That will give you more adjustment, and allow you to get more life out of the chain.
March 13th, 2014, 07:18 AM | #3 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
The life on your cam chain itself should still be good. The cam chain tensioners that come stock with the 250's occasionally fail to function properly, I've had this happen to two of them.
You can fix this problem by disassembling and cleaning them (there are several video guides on youtube available) or simply by going with a manual CCT as Ryan has stated. I chose the latter, I installed an APE manual CCT on my 2008 and have not heard a single tick come from the engine since.
ATGATT |
March 13th, 2014, 07:22 AM | #4 |
My last valve adjustment was like 6000 mile ago. So i am not sure either. But i plan to check it as well this weekend as i check the chain.
March 15th, 2014, 06:51 AM | #5 |
All right, before I open all the engine, I check the tensioner first. here I have removed my tensioner. I tried to reset the tensioner, but it stuck. I tried to push it by weighting with my body but the pushrod wont retract back. Is my tensioner broken then? Or is there any trick I dont know about?
Here is the photo of my tensioner
March 15th, 2014, 08:05 AM | #6 |
One more thing, do i need to top my camshaft first before i do it?
March 15th, 2014, 12:05 PM | #7 |
it is not supposed to retract by pushing. if it did that it would be useless. you remove the bolt and use a screw driver to 'unscrew' it internally to retract it
don't turn the engine with the tensioner out. don't put the tensioner back in without knowing how to correctly put it in (retract it fully while it is being installed, then allow it to extend) and yes, it was supposed to be at TDC when you removed the tensioner.
March 15th, 2014, 01:06 PM | #8 | |
And I have not turn the engine to TDC when I removed the tensioner. So I need to remove the left cover of the engine and turn the engine to TDC. Correct? Before I started working on the ninja, I put the transmission in sixth, and I use the kickstand instead of paddock stand. I am sure the bike doesn't move. I don't feel any push from the tensioner when I removed it, so I think my timing chain has been stretched already.
March 15th, 2014, 01:22 PM | #9 |
easy way to tell is to slide it back in without screws... if it goes all the way in fully extended without having to push on it, then yes your chain is totally stretched
March 15th, 2014, 11:30 PM | #10 | |
I didn't crank the engine to TDC though, I was afraid without the tensioner the chain will miss a tooth with the camshaft. I shifted the transmission to sixth gear though before working, and I didn't jack the swing arm. Nothing is wrong after I put back the tensioner.
March 17th, 2014, 01:55 PM | #11 |
I HIGHLY recommend getting a manually adjusted CCT. The Kawi automatic ones are crap. I've got to run to a meeting right now, but a search will yield a link to where to get one.
March 18th, 2014, 05:56 AM | #12 | |
ATGATT |
March 18th, 2014, 11:11 AM | #13 | ||
I use aftermarket CDI that can raise rev limiter (BRT Imax super pro, advanced version from i-Dtis, programmable 24 steps, 50 ignition maps stored in memory), I guess that cause the chain life much shorter.
March 22nd, 2014, 11:57 AM | #14 | |
Board Member
March 22nd, 2014, 02:18 PM | #15 | |
1) Break the chain 2) tie a wire to one end of the old chain, and one end of the new chain 3) manually turn over the engine and let the old chain pull the new chain around. Easy peasy
March 22nd, 2014, 02:27 PM | #16 |
Board Member
It can be done, but braking the chain will most likely put metal in the motor. Its not hard to split the cases just time consuming. Besides, based on your miles it might be worth a look.
March 22nd, 2014, 02:34 PM | #17 |
I didn't consider that. You could still do it if you used a rag under the breaking site. This might avoid needing a gasket (assuming you need one there... I haven't looked).
March 23rd, 2014, 02:25 AM | #18 |
Yeah i need to split the crankcase.. It wont be a biggie though.. I consider it as quest for learning something new. i will post my progress in another thread soon as the chain arrive.
March 23rd, 2014, 01:54 PM | #19 |
There you go... making it an adventure is the way to be a life-long learner.
Engine Noise, Cam Chain Tensioner Problem? Pics And Video | az3200 | 1986 - 2007 Ninja 250R Tech Talk | 38 | August 27th, 2013 04:31 AM |
loose gear shifter? (Monkeytofu's quest to defeat the elusive rattle noise) | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 4th, 2012 03:09 PM |
Engine Grinding noise,cam chain? | zzrguy | 1986 - 2007 Ninja 250R Tech Talk | 23 | November 29th, 2011 03:12 PM |
[topix.net] - Japan supply-chain woes rattle earnings | Ninjette Newsbot | Motorcycling News | 0 | April 19th, 2011 05:40 PM |
Engine and rattle noise | Minnesotah | 2008 - 2012 Ninja 250R Tech Talk | 16 | September 13th, 2010 10:51 AM |
