April 27th, 2014, 01:35 PM | #1 |
New Old Guy
Join Date: Mar 2014 Motorcycle(s): 2011 250R SE Posts: 57
Trying to figure out crappy gas mileage
So I took the bike to the garage and started tearing her apart to see why I'm only getting 30 MPG. Its obvious the previous owner had something done as all fuel lines and throttle cables are labeled with tape. What really blows my mind is when I pulled the spark plugs the gap was so small I couldn't get the gauge under it. Pulling the needles now from the carbs but I'm afraid to see what's in there. Anyone else heard of a gap smaller than .020?
April 27th, 2014, 05:26 PM | #2 |
New Old Guy
So I pulled the carb tops off and found something I've never seen before. The spark plugs didn't look fouled but the gap was ridiculously small and the diaphragm edges had some weird white gunk on it. I fould in on the carb where the edge of the diaphragm sits. The inside of the carbs were OK but it looks like they need to be pulled and cleaned properly. Anyone know what this is from? Bike only has 1200 miles on it.
I did shim the needles with two shims equaling 1mm, pulled the snorkel and put a K&N replacement filter in. (It didn't want to fit). During the first start-up, she started right up without choke. I let her warm up and went for a ride. I like the sound without the snorkel. Power seemed more even throughout the RPMs with no surging or lags. The bike seemed to run decently prior to all of this but I couldn't understand why I was getting 29/30 MPG. So my guess is, with all the cables and hoses being labeled by previous owner that the carbs have been pulled and the jets changed. With the shims in now and the plugs gaped correctly I am hoping to see some improvement until I can pulled the carbs and go through them correctly. |
April 27th, 2014, 05:40 PM | #3 | |
Check for small but steady fuel leak from the carbs up, including the float valves with the engine running (vibration tends to make old valves leak and allow a higher level or even overflow of the carbs' bowls.
April 27th, 2014, 11:33 PM | #4 | |
New Old Guy
April 28th, 2014, 03:28 AM | #5 |
Into the atmosphere.
Small and steady leak = evaporation This could be your problem: https://www.ninjette.org/forums/showthread.php?t=176462
April 28th, 2014, 10:51 AM | #6 |
New Old Guy
She ran well this morning, little choke needed at start up. Let her warm up and checked for leaks, luckily none were found. I think it's the floats as now the oil fill cap smells like fuel. So, looks like a carb removal and tear down is next. I miss fuel injection....
This is some crappy gas mileage | 250rr | Off-Topic | 1 | September 4th, 2013 05:08 PM |
Poor Gas Mileage? | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 47 | April 29th, 2013 01:54 AM |
Impressive gas mileage | A7xschecter6661 | General Motorcycling Discussion | 12 | October 10th, 2011 01:57 PM |
[superbikeplanet.com] - How crappy is the economy? So crappy that Sorrentos Deli clos | Ninjette Newsbot | Motorcycling News | 0 | March 10th, 2010 01:50 PM |
gas mileage | motorcycle_munge | General Motorcycling Discussion | 23 | May 16th, 2009 01:54 PM |
