Old July 20th, 2011, 06:22 PM   #1
kyrider
kyrider's Avatar
Motorcycle(s): 2006 Ninja 250R
Replacing headlights on 2006 250?
Just noticed my bulb is out and in need of replacement. I have searched but could not find a how to. Will I need to take off a fairing or is there an easier way? Link?
Thnx
kyrider is offline   Reply With Quote
Old July 20th, 2011, 07:10 PM   #2
Snake
Snake's Avatar
Replacing the headlight. http://faq.ninja250.org/wiki/How_do_...e_headlight%3F
Old July 21st, 2011, 07:46 AM   #3
Jinx250
Smoker
Motorcycle(s): Guess....
You only need to take the fairing off if you like your hands. If you don't mind banging the crap out of them and taking 30 - 45 minutes to do what could be done in 15, leave them on.
Jinx250 is offline   Reply With Quote
Old July 22nd, 2011, 03:13 PM   #4
what Jinx should be saying is if you have small hands and a second set of eyes, go for it. it's just a PITA. if you have normal/large hands, take off the fairing as it's a super PITA and potentially painful
Old July 23rd, 2011, 01:38 PM   #5
Timon
Timon's Avatar
Motorcycle(s): Ninja EX250R
The funny part is I've heard everyone say remove the fairings, but I never did. It took me maybe 5 minutes to replace my headlight bulb, and my hands only got a bit of dirt on them from the rubber grommet. I personally do not recommend removing the front fairing unless needed.
Maybe it's because in addition to have small hands these lights are identical to any 7'x6' H4 conversion. My MR2 has the same identical headlights in it and that made doing the process without seeing much very easy.
Timon is offline   Reply With Quote
Old July 23rd, 2011, 01:42 PM   #6
Snake
Snake's Avatar
^^^ My thoughts exactly.
Old July 23rd, 2011, 07:53 PM   #7
yeah It's not super hard, but it's just a pain since the guage cluster is right there and there's not a great line of sight. Plus, if the OP hasn't done it before, it might be tricky to do without taking off the fairings.
Old July 25th, 2011, 06:21 PM   #8
kyrider
kyrider's Avatar
I changed the bulb with my big hands and all. I now have high and low beams!!!
I am gonna have to go back tomorrow when I have some daylight and put on the rubber grummet/seal that somehow slipped my mind and I just plugged her in.
Did not have to take off the fairing just reached up from under for the most part.
Old July 25th, 2011, 06:29 PM   #9
Snake
Snake's Avatar
Did you put in a stock bulb or go with a brighter bulber such as the Sylvania Silverstar?
Old July 25th, 2011, 07:31 PM   #10
kyrider
kyrider's Avatar
Only bulb my shop had in stock. It said Honda on the box.
Old October 19th, 2011, 02:55 PM   #11
Lou
Lou's Avatar
Motorcycle(s): GreenSE 09 250R
Instaled the Sylvania Silverstar on my sis 07 over the weekend, she loves it. Says she can see much much better at night and brights are very strong. Whell see how long they last...
Lou is offline   Reply With Quote
Old October 19th, 2011, 07:35 PM   #12
SV_Hadder
Motorcycle(s): 2001 Ninja 250
Yeah I have read hundreds of threads about the Silverstars terribly short lifespan.. If that bulb blows in a short while, I would suggest the Sylvania Xtravision. I have used that bulb in all my bikes, and its a noticeable improvement. The color is a bit more blue than a standard bulb, but not HID 6000k blue, if you know what I mean. Good luck!
"Nicole" - Pirelli Diablo's front and rear, Two Brother's Exhaust, Apex Custom SS lines , 15 T, UNI Air filter, Fiamm El Grande horns, EX500 fork springs, EX250J rear shock, Fender eliminator.
SV_Hadder is offline   Reply With Quote
Old October 21st, 2011, 11:54 AM   #13
Lou
Lou's Avatar
Thanks for tip! Are those bulbs the same price and can they be found in the same places or special order?
Old October 21st, 2011, 07:03 PM   #14
SV_Hadder
They are far from a special order item lol. Most of the walmarts in my local area carry that bulb, and I think they are pretty cheap, too..... about $10-15 per piece.
Old October 22nd, 2011, 10:39 AM   #15
Lou
Lou's Avatar
Nice, plenty of walmarts here so i dont think ill have a problem. I think ill pic one up and have it as a spare, hope this bulb last though lol
Old October 25th, 2011, 09:51 AM   #16
onizthegnome
certified newbie
onizthegnome's Avatar
Motorcycle(s): 08 ninja 250r blue
heres how i learned to change mine in 3 minutes.
im guessing its about as easy on the older gen if you can squeeze your hands around and mentally visualize whats going on.
locktite ALL the things!!!
onizthegnome is offline   Reply With Quote
Old October 28th, 2011, 04:14 PM   #17
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
Work it in with an oil and filter change, let them get you a Sylvania, and ask about laying off the premium labor charge for two simple functions. You're a steady lifelong customer, they're making money anyway, use it.
coondog is offline   Reply With Quote
Old October 29th, 2011, 08:07 PM   #18
Jninja
NinjaCreeper!!
Jninja's Avatar
Motorcycle(s): ninja 250r 2006
Someone has got to be posing as coondog here,I find myself scowering the forum to read his post's and this could not be the coondog i have come to know!!
Jninja is offline   Reply With Quote
Old November 1st, 2011, 09:13 AM   #19
coondog
coondog's Avatar
When Nurse Ratchett rings the bell i go right to the window now, everytime. Seclusion and/or shock therapy will do that for you. Thanks for keeping me in mind, I can't and eventually will return.
My 2006 Ninja 250. Dserge Pictures 18 August 3rd, 2014 07:21 AM
Replacing Engine in 2007 Ninja 250 superstu101 1986 - 2007 Ninja 250R Tech Talk 19 June 27th, 2014 05:56 PM
2006 Ninja 250 mods aspenratt07 1986 - 2007 Ninja 250R Farkles 31 January 24th, 2014 04:39 PM
2006 Ninja 250 - Florida mrlmd Motorcycle-related 5 November 4th, 2010 10:58 PM
