March 16th, 2010, 04:08 PM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
tune up
i just did a tune up on my bike i have a 2001 250 ninja
i bought 2 quarts of oil is that enough and the parts employee said the spark plugs are already gap is that true let me know |
March 16th, 2010, 04:11 PM | #2 |
yes and yes.
March 16th, 2010, 04:41 PM | #3 |
thanks for response, is there anything else in a tune up forgot i also drained the carb floters
March 16th, 2010, 10:18 PM | #4 |
/moved to pre-gen tech
March 17th, 2010, 06:54 AM | #5 |
MOTM - Mar '13, Jun '14
I always double check the gap on plugs. Although plugs come pre-gapped, if they have been hit on the end the gap could be changed.
March 17th, 2010, 10:03 AM | #6 |
IC2(SW)
March 17th, 2010, 10:14 AM | #7 | |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Brake pads/rotors/hoses Brake fluid - level, hows it look. If it looks dark it most likely old and good flush and replace won't hurt. Tires - nicks, cuts, wear pattern, sidewall cracking Overall fluid leaks - shouldn't be any and indicates potential problems Cables - easy to move, smooth return, no hang ups, frays at the pivot points Good way to get to know your ride.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
May 17th, 2010, 11:57 PM | #8 |
Join Date: May 2010 Motorcycle(s): 2003 ninja 250 Posts: 61
i just had a shop do a tuneup for me and the reciept shows that they put in ngk cr7 s instead of cr8 s is there much of a difference between the 2? i read that the 7s are for colder temps, its in the 80s here
Fresh tune up! | KrazyWalle | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 1st, 2013 07:10 PM |
area p tune | jaybo | 2013 - 2017 Ninja 300 Tech Talk | 8 | March 27th, 2013 09:53 AM |
Need help on carb tune | silentIm | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 4th, 2012 03:51 PM |
Used purchase, tune up | shadowskater | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 20th, 2010 09:28 PM |
Vega V-Tune | Perf_White_Gt | Motorcycle Gear | 4 | June 6th, 2010 03:52 PM |
