Old March 9th, 2013, 04:38 PM   #41
LNasty
Daily Jap rider
LNasty's Avatar
Originally Posted by Motofool View Post
Your are welcome
Yes, please, check the play and lube the cable and report back to see if that solves the rpm's issue.
Best !
Cleaned and lubed the cable, play in lever was way too much, after adjusting to barely any pay, just 2 mm the bike ran about 500k less in 6th at 60mph. ran at 8500rpm @ 60mph. Did some more adjusting to give a little less play when I got home, will see on Monday if that brings me closer to 8k @60
Old March 9th, 2013, 09:00 PM   #42
Cool; we are progressing !
Old March 9th, 2013, 09:55 PM   #43
LNasty
Daily Jap rider
LNasty's Avatar
Indeed! I hate having to take the bike to a shop, rarely have to take my car because I have taught myself how to do pretty much everything. With the bike I am hesitant because it all seems like foreign territory to me. If it wasn't for this forum I wouldn't be able to do half the stuff I have done.
Old March 10th, 2013, 01:16 PM   #44
LNasty
Daily Jap rider
LNasty's Avatar
Still not sure if the play is correct, wish I had someone to show me it a video showing correct amount of play, need to see what it feels like. Should you be able to wiggle the lever down by the case cover?
Old March 10th, 2013, 05:00 PM   #45
Originally Posted by LNasty View Post
........Should you be able to wiggle the lever down by the case cover?
Yes, a little bit.
You want zero cable force over that lever during normal operation.
This is one of those cases where a little play don't hurt anything.
Old March 12th, 2013, 07:05 PM   #46
Dirty Mike
Dirty Mike's Avatar
I'm still not used to cruising at such a high RPM, coming from my BMW which in 5th does 85 and about 4800 RPM. Kinda weird having my bike do 60 about 7500. I feel like I'm going to break it! But... then it revs above 10k and sounds like sex
Loving my bike, but i still love cars!
Dirty Mike is offline   Reply With Quote
Old March 12th, 2013, 07:20 PM   #47
LNasty
Daily Jap rider
LNasty's Avatar
What sprocket setting do you have? I also have a 2012 250 with stock setup 14/45. And I am running 8800k rpm at 60 mph. Trying to figure out what is wrong with bike
Old March 12th, 2013, 09:25 PM   #48
sLick415
Im 7k rpm @ 60mph with stock sprockets.
sLick415 is offline   Reply With Quote
Old March 12th, 2013, 09:29 PM   #49
LNasty
Daily Jap rider
LNasty's Avatar
Wtf is wrong with my ****, dealer says its fine, but 8800 is way to high. Clutch is fine. Bike only has 3k miles
Old March 16th, 2013, 11:10 AM   #50
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Elevation may play a role?
TEAM ALFALFA
www.apexassassins.com
Old March 16th, 2013, 12:03 PM   #51
LNasty
Daily Jap rider
LNasty's Avatar
I'm at sea level, down by the gulf
Old March 16th, 2013, 01:56 PM   #52
Coolbpf
Limp Noodle
Coolbpf's Avatar
Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy
Originally Posted by NicoleH28 View Post
I am wondering if this seems right. I have a 2011 250R and when I am in 6th gear traveling at 40mph is it right for the bike to be at about 6RMP's? It seems high to me. I obviously know that I can't shift again. When I get to highway speeds of 55+ I'm assuming I'll be running at 8 or 9RPM's...is this normal? Do these bikes run high like that? I'm new to this so I just want to make sure....
In 6th gear (stock everything) I run 9k at 70 indicated... ad just under 8 at 60 indicated... That's pretty normal... I'm not sure why you're going 40 in 6th gear, I'd be in 5th personally, but I think my bike runs just under 6 at 40 ind when I'm downshifting and such...
Coolbpf is offline   Reply With Quote
Old March 17th, 2013, 09:59 PM   #53
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
ok, you should be close to max potential for the bike then.
TEAM ALFALFA
Old March 17th, 2013, 10:22 PM   #54
LNasty
Daily Jap rider
LNasty's Avatar
So my rpm being at 9000 at 60 mph is normal for down here?
Old March 18th, 2013, 12:09 AM   #55
YunMing
Motorcycle(s): (Sold) 2007 Red Ninja 250r, 2003 Cbr 600 F4i
Just ride it hard like the dirty bike she is.
When I rode my ninja 250 I would ride it to around 12k rpm if I wanted to go quick then I shifted. Otherwise I would cruise around 8 - 9k rpm. I think 9000 rpm at 60mph doesn't sound right but it still has up to 12k which is where it really peaks for power.
YunMing is offline   Reply With Quote
Old March 18th, 2013, 07:47 AM   #56
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
i dont have time now, but a few years back i made a post on another forum about maxing out each gear.
TEAM ALFALFA
Old April 2nd, 2013, 03:23 PM   #57
LNasty
Daily Jap rider
LNasty's Avatar
Took bike to a different dealer they were able to see what I am dealing with with the rpm issue. Kawasaki is having them replace the tach first to see if that does anything, if not then they will move to the next thing, which will prob be cdi. Suck though cause now I won't have my Nike for at least a week, only been three days and I am having major withdraws
Old April 2nd, 2013, 03:32 PM   #58
Try living in OH and going to school almost 3 hours away from home...
Old April 6th, 2013, 12:32 PM   #59
LNasty
Daily Jap rider
LNasty's Avatar
Angry
Just called dealer for an update on my bike being fixed, said that part is going to take a while to come in and to come pick bike up if I want so that I have something to ride. well ****, at least i will be riding again, but now i will have to bring it all the way back over to dealer just so they can put the new tach in, which I already know won't solve the problem, then I will have to wait for another ungodly amount of time before next part (likely a new CDI) comes in. What takes so long for Kawasaki to send the dealer a bloody part? Is it coming from Japan? Do they have to decontaminate the part first from all the radiation? WTF!
Old July 29th, 2013, 08:07 PM   #60
PArider
Motorcycle(s): 2012 Ninja 250R, 2001 Suzuki GZ250
Any update?
Howdy. Any update? Did you get this eventually figured out?
I'm asking because I just purchased a 2012 ninja 250 with 800 miles. After break in I took it on the interstate.
In sixth gear:
60mph is 9,000
70mph is 10,500
80mph is 12,000
Yes, 80 is just under redline!
That seems too high and I can't figure out why. Sprockets are stock, I'm pretty sure.
PArider is offline   Reply With Quote
Old July 30th, 2013, 06:37 AM   #61
In sixth gear:
60mph is 9,000
70mph is 10,500
80mph is 12,000
Your clutch is slipping and heating up the oil too much.
Old July 30th, 2013, 07:18 AM   #62
PArider
If that were the case, the revs would be a bit unstable and oscillate up and down right? I presume it would show up on the tach?
This is totally stable at those numbers, like clockwork, so I don't think that my clutch is slipping. 12k is 80mph, and doesn't go above or below as long as I hold 80mph.
Old July 30th, 2013, 07:40 AM   #63
Not necessarily, it could slip in balance.
If that is the case, revs should go up respect to the speed of the bike for conditions of high torque demand, such like hill sand strong wing.
The difference in noise and vibration between 10K and 12K is evident, but you may not be familiar with either one yet.
It has been discussed here that some bikes have defective CDI that can produce a false reading of rpms'.
The tachometer works based on number of sparks per second that the CDI feels and convert into the input for the tachometer.
Please see post #8 above, as well as this thread:
http://www.ninjette.org/forums/showt...ght=tachometer
Best RPM range at speed... robski11500 Riding Skills 9 December 11th, 2015 11:44 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Highway speed in relation to rpm.. Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 3 August 5th, 2013 04:10 PM
RPM-Speed ratio; Update. blink General Motorcycling Discussion 19 January 29th, 2013 05:48 PM
