July 10th, 2009, 09:37 PM | #1 |
Oil Pressure Indicator Question
As you all know, the oil indicator light briefly lights up after starting the engine. When I bought my ninjette from the previous owner, it would turn off within 1 or 2 seconds after a cold start. I'm not sure what oil was in there, but it was fully synthetic. I've changed the oil to Mobil 10w-40 synthetic and switched out the oil filter as well to a Fram CH6012 (or whatever it is that's compatible with the ninja 250). On cold start now, the oil pressure light will stay on for several seconds, sometimes as long as 6-7 seconds after starting. Is this a problem? Any idea why there might be the difference (i.e. weight of oil, characteristics of filter brand, something I did wrong during oil change, etc)
Anybody else have something comparable? |
July 10th, 2009, 09:39 PM | #2 |
did you set the oil level correctly in the sight glass?
July 10th, 2009, 10:06 PM | #3 | |
Join Date: Nov 2008 Motorcycle(s): 2007 Ninja 250 Posts: 469
Now, it's taking a bit longer because you have less oil in there. It has nothing to do with oil type or viscosity. If you want, you can add some oil to the upper line (not past that line) and that will fix your delay. At the same time, while the light is on, DO NOT rev your engine.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008) |
July 11th, 2009, 07:42 AM | #4 |
This is normal. This always happens to me when I change the filter and oil. The oil filter itself probably holds at least 8 Oz. of oil.
July 11th, 2009, 10:22 AM | #5 | |
This will ensure a complete fill and quick pressurization of the oil...or, in other words, the red light will turn off quick.
July 12th, 2009, 08:31 PM | #6 |
Interestingly, I actually put MORE oil in there than was in there previously. While doing the oil change, I did put approx 1.5 L in, started the engine for a few seconds to pull oil into the filter, and then topped it off to about 1.8 L total (judging by the graduations on the oil cans. When I check the sight glass, the oil level is juuuussst below the top line (I check with both wheels on the ground and the bike level / perpendicular to the ground).
Well, it's strange but I suppose as long as it's not doing any damage it's no biggie? |
July 17th, 2009, 10:41 AM | #7 |
Join Date: Jul 2009 Motorcycle(s): 2001 Kawasaki Ninja 250 Posts: 74
As long as it's disappearing and NOT coming back while you are riding, you should be fine.
oil pressure light | contact148 | 2008 - 2012 Ninja 250R Tech Talk | 28 | June 21st, 2018 06:54 AM |
[motorcycle.com] - RightPSI Tire Pressure Indicator to Begin Kickstarter Fundraising | Ninjette Newsbot | Motorcycling News | 0 | February 6th, 2014 05:20 PM |
Oil pressure light question... | Iffita | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 9th, 2012 07:44 PM |
Tire Pressure Question | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 28 | September 19th, 2012 07:50 PM |
Oil pressure switch | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 13 | February 23rd, 2011 06:58 PM |
