Old December 8th, 2012, 01:51 PM   #1
drunyon
drunyon's Avatar
Motorcycle(s): 2010 Ninja 250
WTB: 08-12 Carb!!!
I messed up the threads for my main jet on my carb and I need a replacement now. I've seen some on ebay but I'd rather buy from a legit ninjette member.
I need the 08-12 carb, idc what jet's are in it cuz i'll be putting 112's in it. If its already got 112's i may pay you more.
Please PM me if you have one and the price shipped to zip 62258. I need it by about March or I'll be buying one on ebay to have a shop install.
Thanks
drunyon is offline   Reply With Quote
Old December 8th, 2012, 04:31 PM   #2
headshrink
headshrink's Avatar
Thanks
I don't have one available, but I have bought two full carbs (technically that would be four) from eBay before. Yes, a Ninjetter would be a pretty safe bet, but if careful I wouldn't worry too much about eBay. Many of the used parts are sold from wrecking yards, and are legit businesses. I'm sure I don't need to mention to check eBay rep/feedback before buying. The one thing I learned was too look really closely at the picture (is the picture of the exact item shipped), read description carefully, and don't buy used if you're only saving a few dollars.... but there are fantastic deals there. I've bought everything from single parts, to a barely used engine from eBay. The only part that wasn't really in good enough condition to be used was a pre-gen carb, and the description did say it was pretty messy and needed some serious cleaning. I bought it anyways because all I wanted were the diaphragms and a crappy carb made it an even cheaper buy. All in all, no complaints. So, my point is if you don't get bites here, don't worry to much; just be smart about it.
One more point.... unless you're REALLY uncomfortable with a wrench, or have the money and don't care, you can install it yourself. Also since you aren't running a stock bike, expect that you'll need to re-jet. I found that jetting was not only engine specific, but also carb specific. When I put in a new set of carbs on my old engine (with the same settings), it wasn't happy. Hopefully you'll be close though.
Old December 10th, 2012, 06:53 AM   #3
drunyon
drunyon's Avatar
Well I'm putting 112's in it anyways. What I planned to do is if I have a shop install the carb, which in order for me to get the old one off requires screwing with the cables, then I'd install the jets, and the needles myself in the 'new carb', then take it to a shop and say switch these for me. can't be more than an hours worth of work at all. Cause I dont wanna mess with the throttle cable. f that lol.
I've seen a few on ebay for 100-150, but I know it'll be until Feb when i'd purchase one. Just picked up a 98 S10 Custom that I need to put tie rod ends on and tires.
Old December 10th, 2012, 11:40 AM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Throttle cable and choke is easy, it just slots in a hole
AFM #676
Supersports are for n00bs
Old December 10th, 2012, 11:42 AM   #5
drunyon
drunyon's Avatar
adjustment and getting that screw off the side of the carb. I've tried.
Old December 10th, 2012, 11:44 AM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
The screw? What? You dust loosen the cable and it slides out, then slide it back in and tighten it
AFM #676
Old December 10th, 2012, 11:45 AM   #7
drunyon
drunyon's Avatar
The screw? What? You dust losses the cable and it slides out, then slide it back in and tighten it
the screw that holds the bracket onto the side of the carb
Old December 10th, 2012, 11:55 AM   #8
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Lol you don't take that off. You just loosen the cables and then they come out of the holes, then you put them back in the holes and tighten them up. No loose parts
AFM #676
Old December 10th, 2012, 11:59 AM   #9
should call it a carbie.
Old December 10th, 2012, 12:01 PM   #10
drunyon
drunyon's Avatar
I might be able to do that. Hell it would only cost me like $77 to have it done at a shop. I mean whats the worst that can happen if i do it myself........well if i had a shop do the jetting for me i wouldn't have to be buying a new carb :-/
Old December 10th, 2012, 12:08 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Lol
AFM #676
Old December 10th, 2012, 02:40 PM   #12
headshrink
headshrink's Avatar
I guess we should have asked why you wanted new carbs to begin with. Check out all the DIYs on carbs and jetting. You will learn lots.
Old December 11th, 2012, 06:17 AM   #13
drunyon
drunyon's Avatar
I read a lot on the jetting lately. I just hate that the damn thing broke off inside of it. stupid soft metals.
Old December 11th, 2012, 12:00 PM   #14
headshrink
headshrink's Avatar
What part broke?
EDIT: NM, just re-read OP.
Old December 12th, 2012, 05:36 AM   #15
drunyon
drunyon's Avatar
Yeah and I have a full tank of gas just chillin in my garage now lol.
Old December 13th, 2012, 06:04 AM   #16
drunyon
drunyon's Avatar
Disconnect throttle cables: Leave the cables on the bracket and unscrew the single screw holding the bracket on. You won't have to re-adjust the cables AND it's faster
The screw holding it on seemed very very tight to me.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
WTB: Left over carb needle washers/shims agentbad Items Wanted 5 March 14th, 2015 12:20 PM
WTB : 08+ Ninja 250 carb abhijitz Items Wanted 7 September 4th, 2012 06:27 PM
WTB : 08+ Ninja 250 Carb Part abhijitz Items Wanted 0 July 29th, 2012 08:12 PM
WTB Carb Screws haze5736 Items Wanted 5 July 9th, 2011 09:06 PM
