July 7th, 2011, 03:05 AM | #1 |
Join Date: Jun 2011 Motorcycle(s): 98 Ninja 250 Posts: 45
WTB Carb Screws
I'm looking for some carb screws if anyone has some from a trashed carb. PO stripped out just about every screw head. I am in dire need of the float bowl screws and the 8 on top. Thanks.
July 7th, 2011, 03:35 AM | #2 |
Join Date: Apr 2011 Motorcycle(s): 2001 Ninja 250 Posts: 65
I stripped out 2 of my float bowl screws, I ended up dremeling them straight across so I could use a flat head to get them out and replaced all of them with allen head bolts from Lowes, cost less then $2 and much better then Phillips imho. As for the tops I'm assuming they're the same size and thread pitch so you just need to find the correct length.
Just a suggestion |
July 7th, 2011, 03:39 AM | #3 | |
July 7th, 2011, 03:42 AM | #4 |
MOTM - Sep '18, Feb '16
Go to home depo and get allen. The philips head or more correct pozi drive screws tend to strip. The allens are nice.
July 7th, 2011, 10:05 AM | #5 |
they are trashed because someone used a Phillips head screwdriver to remove them before. the screws are actually JIS screws and using a Phillips on them will eventually strip them out.
replace the stripped screws with some metric Allen head screws/bolts. |
Where to get stainless carb screws? | pilot815 | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 5th, 2016 06:40 PM |
thread pitch size for carb screws | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 17th, 2013 11:49 AM |
WTB: 08-12 Carb!!! | drunyon | Items Wanted | 15 | December 13th, 2012 06:04 AM |
Hex Replacement Screws for Carb bowls and tops | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 14th, 2010 06:52 PM |
Carb screws question | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 1st, 2010 11:32 PM |
