June 15th, 2009, 04:46 PM | #41 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
you always could use 'Liquid nails'
June 15th, 2009, 08:10 PM | #42 | |
Join Date: Jun 2009 Motorcycle(s): (sold)--2008 250 ninja currently 2008 zx6r Posts: 7
the only "bad " thing is that once you cut you cant put back on...but hey i never like the turn signal sticking out so much. great thing about using the silicone sealant was when i painted the bike it was really easy to clean up |
March 16th, 2010, 08:20 AM | #43 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
Great job, I will be doing this when I get some spare time
March 16th, 2010, 05:00 PM | #44 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
here's mine, i shaved the bulb housings to fit inside the lens as suggested by BEELINE - i think it turned out well.
June 26th, 2010, 03:40 AM | #45 |
bump
June 28th, 2010, 01:32 PM | #46 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
all the images has been removed from your post BEELINE ... can you re-upload them ? thanks.
June 28th, 2010, 03:25 PM | #47 |
June 28th, 2010, 03:57 PM | #48 |
Ninjette CPT
nicely done! looks good
August 14th, 2010, 02:17 PM | #49 |
Stealthy Ninjette
Join Date: Aug 2010 Motorcycle(s): 09' Kawi Ninja 250R Posts: 109
Nice mod! I will be doing this when I get some free time and pick up some auto sealant.
One Question, is the sealants suppose to keep the clear lid and crome piece together? I have never used auto sealant/adhesive before so Im not sure exactly what its like but it doesnt seem like much surface area to hold the clear lid on. |
August 14th, 2010, 04:38 PM | #50 |
Ninjette CPT
silicone sealant works fine. reflector and bulb just rest inside the lens (clear piece), it's the lens you're attaching/adhering/mounting to the fairing. easy mod, just takes a little patience.
August 14th, 2010, 05:02 PM | #51 |
Stealthy Ninjette
ahh okay i gotcha, right now I have the fenders off the bike and the lens and reflector/bulb apart, Just have to get some Sealant on my way home from work tomorrow and work on filing down the plastic around the crome plastic
*crossing my fingers*
09' Stealth Ninja 250R Growler Exhaust, Fender Elim, CF LED rear turns, DIY Flush Mounts, & Red Rim Tape My Ninja's Blog! |
August 15th, 2010, 01:06 PM | #52 |
Stealthy Ninjette
So I started the project and so far have one of the turn signals filed down to where I want it. Still need to adhere it but here are some pics of the housing up close and personal.
I went with Beelines method and filed down the outside of the housing to fit inside of the lens. Here it is on the bike (not yet adhered to the bike) And Here Is the First one All Stuck on and Cureing. Just Adhered the second one and used some handy dandy duct tape to hold it on until it drys. hope these pictures help P.S. I'm on my way to the store for some electrical tape to wrap around the ends there so the wires stay on a bit better. P.S.S. Also make sure you put the wire on the turn signal before you adhere it... Don't want anyone to make a stupid mistake UPDATE: Alright The Sig's are all nice and mounted and the fairings went back on with no problems So here some pictures of the final product. And a video of them actually working :P lol
09' Stealth Ninja 250R Growler Exhaust, Fender Elim, CF LED rear turns, DIY Flush Mounts, & Red Rim Tape My Ninja's Blog! Last futzed with by Tofergstaff; August 16th, 2010 at 09:08 AM. |
August 21st, 2010, 01:39 PM | #53 |
Join Date: Aug 2010 Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D Posts: 266
I know what I'm doing tomorrow
July 26th, 2011, 04:10 AM | #54 |
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250r Posts: 14
do you have to take the fairing off? lol im a n00b
July 26th, 2011, 05:09 PM | #55 |
Ninjette CPT
easier = yes
necessary = no |
July 26th, 2011, 09:57 PM | #56 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
Can you still get bulb access?
July 27th, 2011, 10:55 AM | #57 |
ahh thanks man i filed down the crome part im gettin the glue tomorrow
August 14th, 2012, 01:19 PM | #58 |
Join Date: May 2012 Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission) Posts: 482
The adhesive sealant ate right through my paint when i tested it on a small spot.. can i use something else like silicone sealant or something? anyone have any suggestion so it won't eat the paint?
Omoplariangle-bar |
August 14th, 2012, 03:02 PM | #59 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Cool ! I was wondering what to do with my left over rear turn signals after the HBR undertail install
Im going to try this. Thanks
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
September 11th, 2014, 08:43 PM | #60 |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
So I've since come up with a cleaner way to mount it. It involves drilling into the fairing, though, so make sure you're ok with the look and measure 5 times!
First, I used Beeline's method of filing down the chrome section and once I got it to fit snugly I also filed down the two ends of the clear part so that it's level with the rest of the piece (one side has a screw hole, the other has a clip/hinge thing). Then you line up the assembled piece into the hole. The chrome section has 2 parts that stick out - these will actually keep the turn signal from moving. The other side has the screw hole that I used the stock screw to mount into the fairing. I just lined it up and drilled a small hole for the screw and screwed it in. It's much cleaner, no glue/adhesive to deal with, easier to remove/change bulbs and there's no more gap to cover up with foam/wrap. Here's a pic of it (sorry I didn't take progress pics but I'll add them when I do the other side) and a pic of my original design after 5 years. You can see the original design has come loose and has adhesive that needs to be cleaned up. |
September 11th, 2014, 09:10 PM | #61 |
Freedom for Germany
Amazing
March 15th, 2015, 09:45 PM | #62 |
Join Date: Jan 2014 Motorcycle(s): 09 GSXR600 and 08 Ninja 250R Posts: 11
anyway to get the original pictures back? thanks.
DIY: Shorten stock turn signals | Gorilla25 | 2008 - 2012 Ninja 250R Farkles | 4 | November 1st, 2011 02:26 AM |
Flushmount turn signals. | Jacobson94 | 1986 - 2007 Ninja 250R Tech Talk | 1 | July 19th, 2011 11:02 AM |
Why flushmount turn signals? | mikesova | 1986 - 2007 Ninja 250R Farkles | 27 | June 1st, 2011 03:14 AM |
proton flushmount turn signals help | sherjay | 2008 - 2012 Ninja 250R Farkles | 5 | July 6th, 2010 04:14 PM |
Semi-DIY $0 flush mount FAIL! (Need Help) | 00v_Lucky | 2008 - 2012 Ninja 250R Farkles | 19 | July 11th, 2009 01:13 PM |
