March 16th, 2011, 09:51 PM | #41 |
Join Date: Jan 2011 Motorcycle(s): (08 Ninja 250) (07 Suzuki Hayabusa) (08 Suzuki GSXR 1000) (Yamaha dirtbikes) Posts: 33
Stout comes into play when the thing fails and gets lodged in your back wheel. Dont think it could happen think again, a very simaler thing happened to me. Luckily I have had many years of riding expierinance and I was on a residential street and only going around 40mph. My rear wheel instantly locked up and It was almost a disaster but I made it out of it. Just saying, if you are going to mount anything near your wheels make sure it is stout and well engineered. And I think that cheap mount looks cheap and does not flatter the bike at all. Just my opinion.
March 17th, 2011, 06:08 AM | #42 | |
I think that it's going to take an actual pic on a Ninja 250 to convince you, so I advise that you wait before jumping to conclusions. For one thing, it will be mounted horizontally with the plate sticking up where the pic you are looking at has it mounted at an angle with the plate sticking down. FWIW, they also sell heavy-duty L-brackets of the same size with a triangular piece filling out the L-shape but I would rather it just bend flat and have the plate tear off. |
March 17th, 2011, 06:21 AM | #43 |
Join Date: Feb 2011 Motorcycle(s): 2008 Honja Posts: 171
Wouldn't the "stoutness" then pertain more to the hardware mounting it to the bike rather than the mount itself? Yes my mount is very thick and yes it mounts the exact same way as the OPs. I also think it would take quite a stroke of badluck to have it sheer off and into the back wheel. Locking washers all around....I've given myself till April to wrap up the mods on my cafe Ninja and I will have some pictures by then.
March 17th, 2011, 05:08 PM | #44 |
Cazper/Dustin: Can I get an idea of how you routed the wiring between the swingarm and the undertail? IOW, I'd like to see the "jump" point where it leaves the swingarm and enters the undertail. How much excess wire should I give it and how should I leave it so that it doesn't interfere or get caught/broken/shorted? Thanks!
Jojah17: Thanks for the idea, Miyagi-san. *bows* FWIW, the holes you are mounting it to are for optional spools to lift with a rear spool stand (they are unoccupied on a stock bike as well). |
March 18th, 2011, 06:56 AM | #45 | |
meow?
the plate needs to either have lights or reflective tape(red and white ones you see on trucks) bending the plates is illegal and is considered vandalism because its the DMV's property, but cops dgaf about that |
March 18th, 2011, 07:06 AM | #46 |
Anytime my friend. Mine is actually not in the spool location but further up the swing arm towards the front of the bike. Glad it worked out for you! Watch the stoutness!
March 18th, 2011, 09:31 AM | #47 |
Well, my LED bolts don't quite fit in the holes on the L-bracket. What type of file should I look for? Some kind of rod-shaped one meant for use on metal, I imagine (whatever they are called). Would that be appropriate? They only need to be widened ever so slightly.
March 18th, 2011, 09:33 AM | #48 |
Got a dremel with a file cone file bit? That may make it a bit easier?
March 18th, 2011, 05:56 PM | #49 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
I used my dremel to widen the hole for the LED light as well. As far as routing the wires... I ran them down the frame rail all the way down to the swingarm (zip-tying periodically) and then followed the brake line (again zip tying) and that gets you to the axle... there really isn't a whole lot to it.
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
March 18th, 2011, 11:31 PM | #50 | ||
Another thing about the bolt lights are that they have hot glue on the back and the blob is too wide to unscrew the nut. On one I manged to get the nut off but on the other it ended up rippnig the glue out and straining the wire (may have damaged it). Do they expect you to have a hot glue gun and melt it for the installation? If so, why not let the user add the hot glue in the first place? I think it's just poor QA.
License plate bracket | -kj- | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 14th, 2012 03:00 PM |
