Old October 11th, 2013, 06:12 AM   #41
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
@ZackoFF96 thanks for expanding on that translation. I figured it was the same gist as what you had previously given but with such a long write up i was curious what else it said.
As far as the GB, I'd be in for that but could not be the point of contact. I don't have anywhere to accept that many packages. I'm sure my work would have a cow and I don't trust my neighborhood that much.
Anyone else up for it?
<-- Linky
Old October 11th, 2013, 07:42 AM   #42
ZackoFF96
ZackoFF96's Avatar
no problem guys! it's the least i can do
ZackoFF96 is offline   Reply With Quote
Old October 11th, 2013, 08:11 AM   #43
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
im down but we need to get in contact with the seller....Unless zacko wants to forward all of our information to the seller lol. I know the post in the link i posted in the op says the items may take up to a month..so if people are willing to wait that long, with no real way to contact the seller themselves >_>
Aggrotech is offline   Reply With Quote
Old October 14th, 2013, 12:39 AM   #44
graffity_minimart
Graffity_MM
graffity_minimart's Avatar
Motorcycle(s): Kawasaki Ninja 250-R
hello .. does anyone need me here .. hhehehe ..
i'm the seller ..
Please visit our site www.fb.com/graffityminimart
graffity_minimart is offline   Reply With Quote
Old October 14th, 2013, 12:44 AM   #45
NevadaWolf
NevadaWolf's Avatar
Shipping info!
<-- Linky
Old October 14th, 2013, 02:48 AM   #46
Aggrotech
Aggrotech's Avatar
Hey Don!
I'm Interested in the Ducati tail in black and the Tank Cover Type D, however i was wondering how it actually stays on without moving and was hoping you could elaborate on that. Does it stay secure by the gas tank bolts? Shipping info for those 2 items would be to fresno california 93722
Old October 14th, 2013, 04:42 AM   #47
graffity_minimart
Graffity_MM
Originally Posted by Aggrotech View Post
Hey Don!
The tank cover wont move or slip away when you installed it,
because it will be detained with your side fairings and front seat,
here is the picture:
Just remove your fairings bolts,both side (left and right) beside the gas tank,
and then remove your front seat as well,
apply paper tape to your gas tank,to prevent any scratch when you push the gas tank cover and prevent water absorb,
next step just install the gas tank cover and reassemble the other parts again
So the gas tank bolts doesn't have to do anything with this .. hehehe
about the shipping,we use Pos Indonesia and it will be calculated based on volumetric not actual weight,
example:
1. Ducati tail volumetric about 10kg (after converted the dimensions of size) and +5kg more for wooden packing,total 15kg. (even actual weight for ducati tail only 4kg)
- shipping cost via airmail = USD 356
- shipping cost via seamail = USD 100
2. Gas tank cover volumetric including wooden packing,will be calculated about 10kg (even actual weight only 1.5kg)
- shipping cost via airmail = USD 244
- shipping cost via seamail = USD 74
Old October 14th, 2013, 07:33 AM   #48
NevadaWolf
NevadaWolf's Avatar
i'm the seller ..
First off hello and to Ninjette!
Ok, a little more intelligent thought verses the one i posted last night.
I'm interested in the headlight cover, undertail, and rear hugger shipped to Fallon NV 89407. Can you ship to Post Office boxes or must it go to a physical address?
Rear hugger:
does this attach using the same bolts as the stock chain guard?
How does the piece mount on the other side, behind the exhaust?
Is access to the shock open or blocked when the hugger is in place?
Undertail:
does this replace or just cover the existing undertail?
It appears as if the holes for the mounting bolts and license plate need to be drilled, is that correct.
Are the turn signal wires plug and play with the existing connections?
Ummm, i think that is the questions i have.
<-- Linky
Old October 14th, 2013, 12:51 PM   #49
graffity_minimart
Graffity_MM
Rear hugger:
Undertail:
ups .. sorry i didnt introduce myself before ..
we need your complete address ..
* Answer for rear hugger:
yes .. thats right
on the right side, it was restrained by the swing arm spools .. but actually our swing arm cover already press the swing arm,so it wont move easily even before attach with bolts ..
example with our rear hugger for Ninja 250/300 Fi version:
it will closed the access to our rear shock,so its better to adjust it (if you need it) before install the rear hugger
* Answer for undertail:
it will replace the existing undertail ..
yes .. you need to make the holes yourself on the back side,below the stoplamp .. here's some example if you want to install your license plate
nope,,because we just provide with (+) and (-) cable without socket .. so you just need to connect the wire and use electric tape (dont forget to change your mechanical flasher with electrical flasher so the turn signal will normally light .. its LED turn signal)
*click the image for bigger picture
Old October 15th, 2013, 09:23 AM   #50
NevadaWolf
NevadaWolf's Avatar
Sent you a PM.
<-- Linky
Old October 18th, 2013, 01:02 PM   #51
bandit_fosky
Motorcycle(s): ninja 250 r
oh...my...god... thes...these parts... there just so... AWESOME... I WANT THEM ALL HSDHFHSDF this is a must i shall be in contact
bandit_fosky is offline   Reply With Quote
Old October 20th, 2013, 11:36 AM   #52
bandit_fosky
ow much would postage be to the united kindom for the tank cover e in green ,rear hugger in green, undertail in green, can i have a price for both airways and for ship also would any one of the rear tails fit with the undertail? im guessing no because im also interested in the reartail m1 long but would need to know how to get a seat that would fit it?
Old October 20th, 2013, 07:35 PM   #53
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Those parts are sweeeeet!!! I need a 250
Old October 21st, 2013, 02:50 PM   #54
DJK
Motorcycle(s): 2011 250R
http://www.ninjette.org/forums/showthread.php?t=143685
http://www.ninjette.org/forums/showthread.php?t=143040
DJK is offline   Reply With Quote
Old February 10th, 2014, 09:07 AM   #55
Han Solo 1
Motorcycle(s): Had a 2008 Ninja 250, til some low-life stole it. Now riding a 2013 red cbr250.
Did anyone ever actually order anything from here?
I'm really tempted but I just read a bunch of posts on the Shinto Paul fiasco and don't want to end up the same way.
Han Solo 1 is offline   Reply With Quote
Old February 17th, 2014, 05:42 PM   #56
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
I've got in touch with the seller, here are some prices I got with the shipping. I may take the plunge. Although it's a toss up between these or the vrossi wheels.
Graffity MiniMart
Here's the pricelist after converted into Canadian Dollar:
- Tank cover tipe.C = $38
- Rear hugger = $38
- Front fender = $29
- ZX repl. reartail = $104
TOTAL = $209
Shipping cost for each item:
- Tank cover tipe.C = $55.2
- Rear hugger = $55.2
- Front fender = $55.2
- ZX repl. reartail = $76.6
- wood package = $40
TOTAL = $282.2
Shipping is what you'd get killed on, still seems a lot cheaper than most things here. I may slash the rear hugger and front fender to save some money.
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old February 17th, 2014, 09:22 PM   #57
DuplexUno
Motorcycle(s): CharlesdiubsOB
i'm the seller ..
do you have a website we can order from ?
DuplexUno is offline   Reply With Quote
Old February 21st, 2014, 06:15 PM   #58
Toy_maggotz
Ninja 250 Thailand.
Toy_maggotz's Avatar
Name: Wuttipong Cho-angchan
Motorcycle(s): Kawasaki Ninja 250 R 2009
I love it.
Toy_maggotz is offline   Reply With Quote
Old February 21st, 2014, 06:57 PM   #59
Aggrotech
Aggrotech's Avatar
he has not been active in a few months. Best bet is to go through artie as he's already made contact with the seller. AFAIK there is no official website. I searched for a few days, far and wide through teh interwebs for any and all information i could find.
@william03133 Theyre willing to ship to the US so id say they would have no problem shipping to Honk kong.
Old March 2nd, 2014, 08:03 PM   #60
william03133
Motorcycle(s): ninja 250r
@Aggrotech is there any way to contact with artie?
william03133 is offline   Reply With Quote
Old March 2nd, 2014, 11:32 PM   #61
Aggrotech
Aggrotech's Avatar
@BlownWideOpen
get in here D:
Old March 3rd, 2014, 04:27 AM   #62
william03133
@BlownWideOpen
get in here D:
thank you
Old March 11th, 2014, 05:43 AM   #63
aspenratt07
aspenratt07's Avatar
Motorcycle(s): 2006 Kawasaki Ninja 250R, 2008 Kawasaki Ninja 250R
I found this site:
http://cyber-ninja250r.darkbb.com/t9...e-and-get-some
Now if only it was in English.
If your surroundings are not a blur, then you are riding too slow.
aspenratt07 is offline   Reply With Quote
Old March 11th, 2014, 06:06 AM   #64
mania
mania's Avatar
Motorcycle(s): 2013 250
Originally Posted by aspenratt07 View Post
I found this site:
Original post is 3 years old
But, price list is Oct 2013
Their how to order section is *roughly* translated as follows
Also their contacts are listed near bottom of OP
Good luck but Indo postage is always the killer in my experience.
1. Select the type of item it!! 2. Check the pricelist above!! : Army (remember, the price above is the price of the product only, not including postage costs or charge transfer to the destination) 3. Define its colors!! (We provide all official Kawasaki colors, not custom, such as: white / black / matte / green / red / blue) 4. For those interested to send, directly infokan full address details to our contact person at the post below, so we can directly estimate the cost of postage!! (Calculated volumetric, not actual weight) 5. Do not beat around the bush in sending a message, prospective buyers are expected to have read the entire thread carefully until they run out, do not intend to reduce service to consumers!! Example: Om .. condom message tipe.E tank (Carb ') 1pcs red color, later sent to JL.Merah Jambu-B4 nmr.22 Kelapa Gading North Jakarta, What is the total postage and its norek
mania is offline   Reply With Quote
Old October 21st, 2014, 10:07 PM   #65
CycleNoobNinja
How can I get the tank type E... I clicked that link and it doesnt make any sense to me. Teach me like im 5 please!
CycleNoobNinja is offline   Reply With Quote
Old October 22nd, 2014, 05:33 AM   #66
BlownWideOpen
When I went back and was ready to order, these guys were nowhere to be found. Pretty sure they're donezo. But, with enough effort, you can possibly find something similar through other Indo suppliers.
Old October 22nd, 2014, 06:14 PM   #67
Greasedmonkey
Greasedmonkey's Avatar
Motorcycle(s): 2014 Kawasaki Ninja 300, 1980 Kawasaki KZ650
I just wish some of the stuff was out there for the 300. Id like some fancy wheels and some other stuff.
Greasedmonkey is offline   Reply With Quote
Old October 23rd, 2014, 11:51 AM   #68
BlownWideOpen
It is out there. You just have to look...
http://www.empiremotoshop.com/
It's listed as Ninja 250, but the 300 is the same. Just go by the year.
Old October 24th, 2014, 05:59 PM   #69
Greasedmonkey
Google really doesnt translate that site well. Gah... Found some of what I was looking for.
Old October 26th, 2014, 09:48 AM   #70
CycleNoobNinja
you got links for it?
Old February 1st, 2015, 09:49 AM   #71
ryker
chaos theory
ryker's Avatar
Motorcycle(s): 2012 Ninja 250r SE ; 2007 ZZR600
I have to admit I would like that dual headlight look on my bike.
ryker is offline   Reply With Quote
Old July 14th, 2015, 08:14 AM   #72
johncrist1988
johncrist1988's Avatar
Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke"
It's a shame these guys are gone and such. A lot of that custom work I'd have eaten up!
There aren't any other suppliers out there?
johncrist1988 is offline   Reply With Quote
New Farkles beazy411 2013 - 2017 Ninja 300 Farkles 15 August 21st, 2013 10:47 AM
My next farkles Old Lemon 2008 - 2012 Ninja 250R Farkles 16 October 25th, 2012 06:50 PM
New farkles, and some that I took off algerath 2008 - 2012 Ninja 250R Farkles 6 August 7th, 2011 04:18 PM
Some NEW farkles IndyTwoFiddy 2008 - 2012 Ninja 250R Farkles 26 July 13th, 2011 06:07 AM
Where do you get your farkles? P1NDLESK1N 1986 - 2007 Ninja 250R Farkles 11 July 17th, 2009 11:15 AM
