April 16th, 2015, 06:18 PM | #1 |
Jetting help
Been searching the archives for info but still need help.
04 is stock as of now except for two washers under the needles and 3 turns out on the mixture screws, but I will soon be adding a Muzzy and removing the air box snorkel. ASL is 1000'. What jetting should I start with? Thanks. |
April 16th, 2015, 06:39 PM | #2 | |
Join Date: Sep 2014 Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4 Posts: 250
so I guess I'll continue to play mechanic… and start searching here for what to do without buying a "stage 3 jet " kit which for the now I really do not know what or how it works… the bike runs well as it is.. maybe I should not bother for now. |
April 16th, 2015, 08:31 PM | #3 | |
Join Date: Apr 2015 Motorcycle(s): ninja 250, v65 magna Posts: 35
look inside the slide sometimes the washers stick to the slide and you will see it with a flashlight after you pull out the needle. they can stay on pretty good if they are dirty. and ive never bought the jetting kits but the jets and washers separately from jetsrus. its a bit cheaper if you know what size you want. as for op i couldnt tell you what to expect. but will probably have to step up your main jet a size or two. i have pods with muzzy and im - up 1 or 2 sizes on main - 2 washers on needle - 1 size up on pilot - 2 turns of idle screw i believe |
April 16th, 2015, 08:49 PM | #4 | ||
Okay first off leave stock pilot jet alone, 2 turns isn't enough, and stay away from pods.
I will assume for now the carburetors have been meticulously cleaned, and all is okay, including the floats have been set correctly. Now here's my 2˘, Quote:
One must remember what parts of the carburetor are responsible for what.
April 16th, 2015, 09:15 PM | #5 |
i agree with ghostt. but sadly a drunkin mistake lead to my air box being thrown into the fire pit. so to clean up under my bike i just went with pods they were 1/2 the price of a air box and looked x10 better but my bike is naked.
April 18th, 2015, 04:10 PM | #6 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
If he's getting a full exhaust system then he will probably have to rejet. If it was just a slip on then just washers would be alright. Get the factory pro kit instead of the dynojet one and use this guide. Just keep the float height stock and follow the rest.
http://www.factorypro.com/tech_tunin...m_engines.html Also search for the jetting database it's a good starting point. Now you can always get another airbox on eBay because getting the jetting right can be a real pain. I probably wouldn't have fooled with it knowing what I know now but you will get an increase in power at the top end with the right setup. |
help with jetting!!! | Plasma | 2008 - 2012 Ninja 250R Tech Talk | 15 | October 28th, 2013 09:59 PM |
Jetting Question | msebastian | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 5th, 2013 01:11 PM |
Jetting: the right way | alex.s | General Motorcycling Discussion | 4 | July 20th, 2012 05:34 PM |
Jetting ?'s | triton981 | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 5th, 2011 07:38 AM |
jetting | mxnello | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 18th, 2009 05:25 AM |
