August 16th, 2013, 07:36 AM | #1 |
Join Date: Aug 2013 Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R Posts: 144
Kickstand after it's been cut off?
One of many dumb question threads...
Rule book says cut off the kickstand bracket - it's welded to the frame. Anyone have figured out an alternative way to mount a kickstand solution so the bike will be a) streetable if needed, b) re-sellable if needed as a street bike. Obviously at the track it's all about race stands, so no need for it. I have a welder so in theory I could weld it back on later, but would be nice to have a more flexible solution. |
August 16th, 2013, 07:49 AM | #2 |
Interested also...
I cut mine off in a way that it can be welded back on. The trick I think is to cut it off cleanly and straight just above the bend in the tab. I thought about drilling & tapping some holes to just be able to bolt it on but figured that was more work that needed, since it would require a flange to be welded to the cut off part anyway.
August 16th, 2013, 07:58 AM | #3 | |
Indeed I was also thinking about fabing a flange or a mounting plate of some sort... I wish there was a way to mount enduro style kickstand, but there isn't much down there on a Ninja to clamp to.
August 16th, 2013, 12:42 PM | #4 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
August 16th, 2013, 02:18 PM | #5 |
i use a dirtbike triangle kickstand that fits into the hold created by a crash in my woodcraft rearsets on my 250 race bike. i commute on that bike like that about 2500 miles a month.
August 16th, 2013, 04:38 PM | #6 |
August 16th, 2013, 04:42 PM | #7 |
I was thinking removing the round frame plug and using removable stand would work too. Still, something mounted to the bike that works more or less like stock kickstand would be infinitely better.
August 17th, 2013, 08:38 AM | #8 |
OK so where are options I came up with:
1) Swing arm mount like the setup used in dirt bikes. ~$85, still would have to figure out what clamp size / kickstand length works best. 2) Dirt bike bolt on kickstand designed to use foot peg mounting point. Would likely require a custom mounting bracket. 3) U shaped clamp on, (or weld on) to the flat section of the frame above rearset. Base parts from #1 or #2 with custom clamp or mounting point. Frame mount options are better since they do not add unsprung weight, but I think would be more work. Obviously anything where welding is involved is a lot more work. |
August 18th, 2013, 11:05 AM | #9 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
I don't think of welding as work... It's fun, till ya get a job doing it, but "jobs" are the downfall of humanity
August 18th, 2013, 10:19 PM | #10 |
I don't mind welding, it's the prep and then painting everything.
September 10th, 2013, 12:10 PM | #11 | |||
Kawi Girl
Join Date: Dec 2012 Motorcycle(s): '10 Ninja 250R Green SE, '13 Ninja 636 Pearl White Posts: 245
Possible to get pics of your kickstand mount solutions? @csmith12, @alex.s, @bitaria.
I scraped kickstand mount going around a downhill corner at The Ridge in August. Thought it was only the footpeg until I watched the video and realized that the push back was too great for just the peg. I would like to avoid repeating the same thing but also having the bike available for off-track rides as well. Thanks! Quote:
Perspective: Everything looks better from the inside of a motorcycle helmet |
September 10th, 2013, 12:36 PM | #12 |
I can take a pic of my cut but I haven't welded a side stand mount solution that will work for off track applications yet. If I figure something creative out I will post up for sure.
September 10th, 2013, 12:48 PM | #13 |
Kawi Girl
A picture of the cut would be a help at the moment. Three weeks to track day and I'm leery of catching it again.
September 10th, 2013, 01:03 PM | #14 |
Cut straight as possible to make the weld easy.
September 15th, 2013, 10:27 AM | #15 |
it sits on the kickstand like this... it works really well for dirt.
sometimes it doesn't like physics though. most of the time i leave the kickstand on the tail and simply lean the bike on something
Kickstand | jakek94 | Items Wanted | 2 | March 4th, 2013 02:46 PM |
How many racers have cut off the 2008+ kickstand mount? | samw | Ninjettes At Speed | 39 | April 2nd, 2012 06:05 AM |
Kickstand killswitch. | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 24th, 2010 11:58 AM |
Need an adjustable kickstand. | pucktoplay1 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 5th, 2010 04:46 PM |
