Old December 16th, 2014, 06:09 PM   #1
Campos15
Motorcycle(s): '99 Kawasaki Ninja ex250r
Help plz!
I have a 99 ninja 250. The throttle is sticking on a new used carb I got. It's the throttle link on the carb that sticking. Is there a way to change out the spring in the link? On my old carb the throttle worked fine so is it possible to just switch the parts for the throttle?
Campos15 is offline   Reply With Quote
Old December 16th, 2014, 06:51 PM   #2
cuong-nutz
cuong-nutz's Avatar
Lube? or perhaps it's bent and catching something.
HalfFast Racing Team
Old December 16th, 2014, 07:09 PM   #3
Ghostt
Ghostt's Avatar
Use real lube, not WD-40. Use penetrating oil, also lube cables while your in the neighborhood. Make sure all cables are routed properly.
violente et ignorantia
ZX-2R BLOG
Old December 16th, 2014, 10:08 PM   #4
Campos15
Thought about lubing up the throttle link but not really sure what to lube lol I guess all the moving parts I can see. It seems like it's just kinda seized up its not to hard to move it just get stuck where ever I let go and cables are fine
Old December 16th, 2014, 10:09 PM   #5
Ghostt
Ghostt's Avatar
Lube it up like a prom date.
did you verify it worked before installing it?
ZX-2R BLOG
Old December 17th, 2014, 04:00 AM   #6
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
So, from what you are saying, it even stick with the cables disconnected?
If you unhook the cables from the carb, will it return freely or stick? If it sticks in this situation, have a look to make sure the actuator is not bent and catching on anything.
If it does return freely, then it would be either the cables or the throttle tube. The cables are the most likely culprit, as they get older and wear, they don't run as free as when new. Then cable routing can be touchy to get right.
Good luck with it.
Originally Posted by jgcable;
I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it.
baxtc1 is offline   Reply With Quote
Old December 17th, 2014, 06:35 AM   #7
Sounds like you need to remove the carbs and find out why the throttle plates aren't closing properly.
I wouldn't ride it like that.
Plz help me name my excavator! corksil Off-Topic 13 June 18th, 2014 07:18 PM
Need new tire, plz help fmx 2008 - 2012 Ninja 250R Tech Talk 13 March 19th, 2013 07:33 PM
integrated taillight plz MikeJames21 Items Wanted 5 February 6th, 2012 05:26 PM
Throttle issue HELP plz Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 6 July 19th, 2011 08:43 PM
Answer some of these questions for me plz! 00v_Lucky General Motorcycling Discussion 38 March 14th, 2009 01:07 PM
